Question about Toshiba Satellite 1415-S173 Notebook
TOSHIBA MODEL 1415-S173 AC LIGHT KEEPS FLASHING W/CHARGER ON
ONLY LIGHT IS THE AC POWER FLASHING USING ORIGINAL BATTERY ALL ALONG W/ POWER SUPPLY
I have a Toshiba 1415 S173 laptop I'm working on for a friend. On AC power, plugged in light comes on, stays green. Battery light will glow amber/yellow while charging, and then glow green when it is...
Hi
Once before I had a similar Toshiba come into the shop. Try turning the unit on without the battery installed and on the good Toshiba charger. The computer batteries have a minimal current level and once power has gone below this level they will cause all kinds of problems. If the Toshiba now works, you're home free - just replace the battery. If it doesn't work then it will have to see a reputable repair person who can troubleshoot chip issues. I've seen these clone power supplies do all kinds of things to computers.
Mar 13, 2010 | Toshiba Satellite 15" Flat Panel LCD...
I have a Toshiba Satellite 1415-S173 with a bios password I don't know (original owner is deceased). How can I bypass or remove?
Remove the CMOS battery from the motherboard. Turn it over, open it up, and look for a little watch battery.
Oct 31, 2009 | Toshiba Satellite 1415-S173 Notebook
Toshiba Satellite 1415-S173 not powering up
Take out battery then try it.. if that dont work and it dont turn on then you might have to go inside..
Apr 22, 2009 | Toshiba Satellite 1415-S173 Notebook
Toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
Mar 03, 2009 | Toshiba Satellite 1415-S173 Notebook
You Tried Helping Me Wiht The Toshiba Laptop.
you may need to go into the controll panal and look at the power supply. and change the setting. Toshiba web site has lots of help with Toshiba problems
Sep 23, 2008 | Toshiba Satellite 1415-S173 Notebook
Power supply
You need to charge the battery asa long the charging icon will fully charge , unplug the power observe the condition of the PC if minutes the PC goes off battery need to replace .
Dec 30, 2007 | Toshiba Satellite 1415-S173 Notebook
Toshiba cmos battery disconnect
on a Satellite 1415-S115 You will have to open up the clam shell and remove all of the B25 and F6 screws from the bottom, as well as the B16 and B6 screws under the keyboard. To remove the keyboard, pry up the trim piece that holds the power button with a sharp nife a stanley blade is always usefull remove the three screws. mind the wireless wire leads there a pain.
The CMOS battery will be under the right side of the hand rest, next to the mouse. It has two leads and the battery is in a blue bag.
simply replace the battery and reassemble your laptop.
Dec 07, 2007 | Toshiba Satellite 1415-S173 Notebook
Toshiba Satellite 1415-S173 Notebook Logo
513 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
