Question about Tascam Quantegy 120 Minute Digital Audio Master for DA-88
Tascam meters are all overloaded to the maxs will not cut off
When i turn on the tascam all meters are sky high as if it crashed
    Problem Solver:
  • 6 Answers
Digital input is engaged with a clock mismatch.
Posted on Aug 16, 2009
Why did power outage cause complete failure?
Sorry for late answer. It usually means the batteries were flat or faulty and the memory could not be supported during the power cut. Also, a high voltage surge can come down your mains if high voltage lines cross yours (say in a car crash with power pole) which can cause a serious overload in equipment.
Nov 19, 2015 | Royal Alpha 1000ML Cash Register
My 150 MAX menu says it is overloaded but there is no paper or other objects in the shredder.
After an overload condition you are required to wait approx 20 ~25 mins for the motor to cool down. If after this time you have tried all the usual, unplug, plug back in, switch off/on again and it still indicates overload then you have lost either the pcb inside or the motor itself. Motors can be checked with a multimeter to see if there is either an open or shorted coil... the pcb is harder to fault find with a meter...would suggest you contact Royal parts..they are very helpful..1-800-524-0799.
Feb 01, 2011 | Royal 150MX Cross-Cut Shredder
1989 f150 302 V8 fuel injected emissions problem. Installed new engine from Ford, blew SKY HIGH on low and high idle emissions. Emission numbers were 10-20x max legal limit (over 3000). Replaced the...
the O2 sensor works on one volt .5 is around the running voltage, i would refit the air hose as it will run the converter hotter at idle.
Apr 26, 2017 | 1989 Ford F 150
I have a ingersol compresor model 2475 everytime it builds up and cuts off we haft to go out to it and push the blue reset button on the electric box thats mounted to it to get it to restart once u push...
Jamie It sounds like you have a check valve thats bad or possibly high amps causing the over load to trip. If its a check vale you should have air blowing from the copper line that attaches to the pressure switch. Also you can disconnect the tube at the hp head. If its blowing air the check valves needs replacing. Now if the over load is tripping you will need to check the amp draw with an amp meter. A 7.5 hp motor should be pulling approximately 35 to 40 amps if its single phase 230 volt. if not depending on voltage the amps will be less. Pull the disconnect before Removing the starter box cover. Find the bottom of the overload where the motor leads connect. just above will be some metal strips that have a number like E68 on them. There will also be a sticker in the starter box cover that will have numbers like E68 and a corresponding amp range. Your max amp draw should correspond to the amp range in the cover. If amps are out (higher) of range you need to install larger heaters in the overload. Ex. you May need E69 or E70 overload heaters instead of E68 heaters. Hope this helps you
Dec 27, 2010 | Ingersoll Rand 2340/2475 Electric Air...
I installed my tascam mk2.under Cubase LE4. Midi tracks work good.In "set-up devices" I see the Tascam inputs and outputs.Monitor VU-meter is not moving in this audio track and consequently there is no...
Have you clicked the little "monitor" icon (looks like a speaker) on the armed audio track so that it goes orange? Once on, you should see a signal on the VU meter (assuming the line in has a good signal etc). Once recorded, turn the monitor off again to listen to the track with all the others.
Jan 26, 2010 | Tascam US-144 Sound Card
Tascam 122MKII - press play no sound, meters don't move
Look for small leaver or any contact switches. They might have become bent out of shape or broken, or have dirt in them, cutting off the sound. Also check the leads coming from the head, they might have become detached or at least you can trace where they join the PC board. If you touch where they join you should get a buzz on either channel.
Jul 22, 2009 | Tascam 122MKIII Single Dual Cassette Deck
Speaker will not turn on
Actully the problem is your speaker which is shorted. The speaker assembly or the one who crashed out always, when you excited the volume to max it feedback to amplifier Ic to cut the fuse blown. The amperage goes up and sent to either left or right amplifier power supply.
Even you replace the fuse with a new one it will repeat the situation and story.
later sooner it will damage more.
r_ic7
Nov 28, 2008 | Alesis M1-Active MkII Main / Stereo...
Sound
No sound during recording ? No sound during playback ? Both ?
Do you have signal levels on the meters at stereo/ main out ? If yes then make sure master fader is at adequate level then check to see if there's a headhone on/ off switch or a headhone volume level  knob, if so then adjust ( be careful not to have the master fader at a high level when you turn on the headphones, it hurts )  If you don't have signal on the stereo/ main out meters or you do and the above steps didn't work then we'll take it from there.
Jun 21, 2008 | Tascam DP01 All-In-One Recording Package...
Crashing every minute
I have found that the tascam 144 freezes the system evan when using other software than Live. It looks up with Cubase and other stuff evan Windows media player running sound thru the tascam. The problem is erratic and acts like an IRQ conflict and I still believe Tascam has fallen real sort of the mark by abandoning the customers. They are without a dought responsible for this problem and should step up and FIX it NOW. We are many having problems it is no fluke and I for one am discusseded with the total lack of support for what they have released as a viable and workable unit. LIES just to sell their stuff. I feel that Tascam's support should be in on this forum and start to work out the diffinative answere.
Anyone want to buy a cheap Tascam US 144 that won't do what you want. I achive move by plugging into the MIC or Line in on my system sound card than I get from the great Tascam device I bought in good faith and can't use.
THANKS FOR NOTHING TASCAM.
May 20, 2008 | Tascam US-144 Sound Card
Electronics - Others Logo
122 people viewed this question
Top Tascam Electronics - Others Experts
Glenn Mayer
Glenn Mayer
Computer Links
rjivaro
Are you a Tascam Electronics - Other Expert? Answer questions, earn points and help others
