After 3 rings the answering machie goes on.i like to increase the # of rings
Follow the instructions on page 25 of this manual.
SOURCE: LINE 3 RINGS ON ONE PHONE- AND DOES NOT RING ON THE OTHER 3...
You will have to get into the programming mode and change Memory Block 4-01 for the port of each phone you want to ring. The corresponding light for the button is OFF for no ring, GREEN for ringing, and RED for delayed ringing.
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
SOURCE: rings only 3 times then message
I did not see what model uniden phone you have. check here for a manual http://www.uniden.com/index/manuals_results.cfm?cat=1
SOURCE: Nortel M7310 phone
Feature **266344, PW: 23646, Press top arrow until you can enter your ext. Press the top arrow again until you see "Fwd no answer" and press top arrow again until you see "Fwd to: None" and choose change. Enter your VM box. Press the bottom arrow (down) on right and see "Forward Delay" and change that number then press rls.
SOURCE: ge phone/answering machie model #27851FE1-B
Press and hold the skip button. You will hear a voice telling you that the answering machine has been changed to English.
