Question about Toshiba Satellite 1135-S155 Notebook
AFTER GETTING THE ERROR MESSAGE TO BACK UP MY DATA THAT MY HARD DRIVE WAS BAD, I REPLACED IT AND INSTALLED WIN XP ONTO IT. NOW I CANNOT GET MY WIRELESS TO WORK. TOSHIBA SATELLITE 1135-S155
  • 3,940 Answers
Dell bootmgr is missing
Most likely cause is that the boot order in the BIOS is set up for the HDD first. When turning on the unit, press the key needed to enter setup. Once in setup, search thru the menus for the boot order. Choose the CD drive as the first boot device, then the hard drive as second. Save and exit the setup. When rebooting, ensure the WIN XP CD is in the drive. When the screen says, "press any key to boot from CD", press a key and the WIN XO CD should take over and start the install. Once WIN XP starts installing, follow directions. On each restart after that, DO NOT press the key to boot from CD. WIN XP setup will handle everything until the reinstall is complete. After you are done, you may choose to go back to setup and change the boot order back, but it is not really necessary. The only time you will get the "press and key to boot from CD" message is when there is a bootable CD/DVD installed in the drive. Otherwise, it overlooks it and goes to the next boot device (HDD).
Sep 07, 2014 | Dell Inspiron 2600 Notebook
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
I have the same problem the toshiba recovery disk i get error message 10f8060017.its a toshiba A105-2194 win xp media edition. i have tried everything wiped the disk to all 0's. Used a win xp original disc...
You have tried all possible solutions and troubleshooting.
My Suggestion is to check the Warranty of the Hard Disk and get it replaced. this possible shows a mismatch between the Laptop and hard drive.
Feb 15, 2011 | Toshiba Satellite A105 Notebook
PLEASE, I HAVE A DELL D610 LATITUTUDE LAPTOP AND I WAS WORKING WITH BEFORE A BLUE SCREEN APPEARED WITH SOME ERROR MESSAGE, AND NOW THE HARD DISK IS NO LONGER RECOGNIZING, WHEN IT DOES IT ODSN'T ALLOW ME TO...
Blue screen error may generally appear for three important reasons : 1.If you system is infected with some viruses and your hard drive has bad sectors in it.
2. If your memory card has gone bad or not properly pluged.
3. The OS has gone corupt due to virus attack.....
Resolution: 1. Go ahead and do a complete format on your hard drive and then install the OS, i.e., Win XP.
2.Try replacing your Memory Card in your system.
3. Change your hard drive or conatct Geek Squad @ 1-800-433-5778 for data recovery.
Jul 29, 2010 | Dell Latitude D610 Notebook
When i try to install win xp or microsoft office error message about missing files and lost drivers ??? compac nx9110
If you try to install from cd/dvd drive, your optical drive lens can't read data well and resulting to delay transfer of data or error installation.Try cleaning the lens with cotton or lens cleaner and try again. Or maybe you have bad installer.
Apr 04, 2010 | HP Compaq Business NX9110 Notebook
Install Xp on Acer Asprie 5735z
I'd reccomend backing up data and formatting your hard drive. Then install XP from disk and put data back on hard drive. You could use external hard drive or jumpdrive. It stands to reason that SATA works with XP, because the new computers I have seen have SATA and XP working conflict-free.
Feb 13, 2009 | Acer Computers & Internet
How can i desable sata hard drive in laptop for installing win XP
in the BIOS you should change the following option
sata native mode should be disable.
Feb 02, 2009 | HP Pavilion dv2000t Notebook
Re-installing xp
A cyclic redundancy check (CRC error) is an error checking program that is used to verify data and can be caused by hardware or software. The most common causes are bad CD disk, hard drive or memory. To run diagnostics press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. Examine the Windows CD and see if there are any scratches or smudges on the media, try another CD disk if you have one.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 13, 2008 | Dell Latitude D600 Notebook
Problem installing windows XP
This is going to be either a bad disc or a bad hard drive. Do a hard drive test in the bios, if any part of it fails, then you will need to replace the hard drive. If the hard drive passes, then try a different operating system disc.
Aug 13, 2008 | Dell Inspiron XPS M140 Notebook
Installing win xp from external hard drive
Umm...is your laptop crashed??? Usually ntlldr issues ****. try to delete the former installation so a new ntldr file can be installed so as to not conflict with the damaged ntldr file that is on the pc blocking the install. It sounds like your setup is ok...at the very least get another xp cd to make sure the disk is not damaged that you are loading windows from.
Aug 01, 2008 | Computers & Internet
Toshiba Satellite 1135-S155 Notebook Logo
87 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
