Refillable ink cartridge problems with Epson R285 printer
I have a Refillable Ink Cartridge System which my Epson R285 printer is having seversl problems with:
1) Often fails to recognise that a newly filled cartridge has been inserted.
2) Is failing to recognise the correct collouration or images being printed ie, blue is more like purple, red is like orange, yellow hardly shows, etc.
3) Fine detail is missing from prints, which look rather bland.
Any help would be grestly appreciated.
  • blayney19 Jan 20, 2009
    Dear visualverses - Thanks for the response.
    After further exhaustive testing, it finally became apparent that it was the ink I'd been sold that was causing the problem.
    Problem Solver:
  • 5 Answers
1. Check the ports that the cartridge sits on. Compare the ports of two of the cartridges. Look for anything that might on the outside of the port that is different from the one that seats properly. If you are skilled with a light touch, use a wooden toothpick to remove the offending particles. Be gentle, don't scratch the plastic. If you have a heavy hand, take it in for service.
2. Hopefully this is just a dirty print head, Acts like empty cartridges which are now refilled, run the Epson Test page and the print head cleaning routine. This might take two, three runs to clear up. Keep printing the test page until the each cartridge's color section prints without streaks.
3. Symptoms of wrong paper type, mismatch with printer settings or dirty print head. Remove issue 2 first.
Posted on Jan 17, 2009
    Genius:
  • 2,120 Answers
See MY MOTTO
I have some Refillable to refill my cartridge and
The refill holes are situated in the top of the cartridge, usually under neath the label.... make sure you seal the holes after refilling.
Feb 14, 2010 | Epson Stylus NX400 InkJet Printer
Tip
Ciss and refillable cartridge systems
Depending on printer brand and model, there are lots of ciss (continuous ink supply system) solutions to buy.<br /><br />Bare in mind, though, if you are planning to use printer heavily, there are other considerations you should think about:<br /><br />1. If not used regularly, an air bubble may occur and it takes a while to pop it up. Also ink may dry in certain area and it's a mess to resolve.<br /> <br />2. The ink supply (depending on supplier) may not be good as the original; color depth and durability wise.<br /><br />3. Cartridge recognition problems may occur from time to another, so it must be removed and inserted again.<br /><br />4. CISS system usually have a chip to fool the printer and it may fail with any liquid contact.<br /><br />5. ink pad inside printer fills quickly on heavy use, thus its wise to direct the pipe into an external tank (found inside and in the back of printer for Epsons) <br /><br />In conclusion, if you intend to have more than 100 pages/month, consider compatibles or refillable cartridges. ciss is good for +200 pages/month.<br /><br />e.g. (epson rx685 blanks out all 6 cartridges except for the black after 10x15 photo's in with high quality enabled)<br /><br /><span style="font-style: italic;">Please note that these tips are based on experience with 4-6 cartridge systems for Canon and Epson printers.</span><br /><br /><br />If you find this informative, kindly <span style="font-weight: bold;">vote positively</span> for me to continue sharing. Good luck and thanks.
on Nov 26, 2010 | Office Equipment & Supplies
Refilled the ink and it is still saying it needs
Unfortunately, you may need to buy new Epson manufactured ink cartridges. Some of the ink cartridges and/or printers have a setting that says this cartridge is empty and refilling the cartridge does not clear the empty code.
(It is annoying but the cheap printers are paid for by the ink purchases after the fact.)
Dec 13, 2009 | Epson Stylus CX9400 Photo Printer
Epson R285 need service utility
It sounds a lot like you have managed to reset the printer using the R290 adjustment utility and it now thinks that your printer is an R290 printer.
As a result it's rejecting the yellow cartridge (presumably the first to read empty since you reset the printer) and expects you to provide R290 consumables.
The only fix that I've heard suggested (and I'm still waiting to hear if it worked) if to get someone with a valid R285 to use the same adjustment utility to make a backup of the EEPROM data (nothing else), save this file, send it to you, and then for you to restore that same data to your own printer EEPROM.
As I said, I haven't heard if it works and I could be wrong about the cause but as I provide waste kits myself and have already had quite a few people report a similar issue I suspect I'm about right.
Hope that helps.
Martin
Jul 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I need a new CHEAP printer
Epson with Continuous Ink Supply System (CISS) is my choice, you'll no longer injecting ink to your cartridge that will make your cartridge live short.
Mar 31, 2009 | Office Equipment & Supplies
Continuous ink supply system for epson r285. Printer will not recognise the cartridges as full. have used the reset button on the cartridge but still no luck. any ideas?
Resetting the Epson Ink Monitoring System -
Even though the CFS maintains a constant level of ink in the cartridges, the Epson monitoring system will signal that the cartridges are empty after a cartridge full of ink has been used. This ink level information is stored on the Intelligent cartridge chip. These cartridge chips have to be reset with out lifting the cartridges. This is done with Inksupply.com Auto Reset Chips. On older Epson printers, before the Intelligent cartridge, it is done mechanically by removing and re-inserting the Inksupply.com switch activators. CFS cartridges must be reset without lifting them.
Previous Reset Methods -
The resetting methods have evolved over the past couple of years. First the Swedish Reset method was used, then the Equalizer Program, then the F-16 Chip Resetter, and now the Auto Reset Chips.
Hope this helps you. Good luck!
Oct 23, 2008 | Office Equipment & Supplies
My epson r285 wont recognise compatable inks
My Epson R285 will not recognise compatible cartridges,mainly the black.I ran out of black ink and installed a compatible cartridge but it did not recognise it.To get the printer running I had to buy a genuine one which worked.I then ran out of all the other colours soon after and installed compatible ones which were accepted.I have now ran out of the black again but the printer will not accept the compatible cartridge.How can I solve this problem as the printer has accepted black compatibles before.
Thanks Padgy
Oct 09, 2008 | Office Equipment & Supplies
Epson Stylus Photo R285
You can buy a Chip Resetter for around £5.00(Try E Bay)
this will reset the chips on the cartridge. Or you can buy refillable
cartridges which are self (Chip) resetting
Aug 15, 2008 | Office Equipment & Supplies
825 people viewed this question
jasbo
jasbo
