Question about Kenmore 24032\24036 Top Load Washer
Leaking washer The washer is leaking right where the shaft goes into the white pump. I haven't taken it apart yet but i want to see if it is the white disks or the acuall pump it self. I can't tell yet until i have it completely apart. The same happened with the motor trying to turn but wasn't. It finally broke free but now it started this leak.
  • jaburman Jan 17, 2009
    how do i get the back off
  • Kenmore Master
  • 8,220 Answers
Those top loaders are pretty dang simple and easy to repair. To access the pump motor and that pesky drive coupling you must remove the cabinet and expose the innards. Start by removing scews on either side of the control panel, flip it upwards on its hinges and pop the S clips that hose the case to the rear. Unplug the lid switchleaking washer - a82e1c7.jpg and tip the case forward . Remove it from the base. Now you can work on the machine. Add a little water to the machine and look for obvious leaks. Defeat the lid switch (jumper it) and run a whole cycle with the case off so you can determine where the leak is coming from.
Posted on Jan 17, 2009
Water leaked out from under washer while it was running. No leaks visible from hose connections at hose bibs, nor where water supply lines (hot and cold) thread on to the top right at the back. No leaks...
I would open the door and puled up the bottom. Part were that fan twister spins on the bottom.. and check that the ida filler is not gonskie or may be blokidge right there So water would v come out. And clean it all there. It prolly never been done ????. Hope that helps ?? Tony
Apr 19, 2017 | Kenmore 24732 Top Load Washer
My washer is leaking from the white plastic housing right beside the motor. Is this an easy fix or will I just have to get a new washer?
if the white plastic part your speaking of is in front of the motor and has 2 hoses into it,then this is the drain pump and yes you can replace it for about $25.00,remove power,then 2 hoses from pump,then there are 2 clips one on top and the other on the bottom,remove these and the pump will slide off the motor shaft towards you,if its rusted on the motor shaft you may need to pry it off carefully so as not to damage the motor
Mar 18, 2011 | Whirlpool Ultimate Care II GSQ9669L Top...
Leaking from the bottom back
Hi, If not a hose leak, check for leakage around the water pump. On our top-load Kenmore, the leak showed up at the front right of the machine. Water was leaking where the pump slides onto the motor shaft. Replacement of pump consists of: (1) unplug power cord and then remove 2 screws at corners of the dial/control panel to tilt it back, (2) unplug wiring harness, (3) remove two spring clips holding white metal console to the frame then tilt console forward and remove, (4)pump was in front of machine with two black hoses attached via hose clamps - remove the spring clips at top & bottom of pump and remove the two hose clamps, (5) slide new pump onto shaft and reassemble in reverse order.
Take care
Jun 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
17 year old maytag washing machine leaking water under washer towards the right front.
The pump is at the right front. When the seal goes bad the pump will leak down the shaft. Check the hoses too.
Feb 02, 2010 | Maytag Washing Machines
Water leaked from bottom of washer
Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Amana lw8252w2 changing belt
there are 3 screws that hold the pump to the moter but sometimes it is rusted so you may need to pri it off
Nov 29, 2008 | Amana ALW480DA Top Load Washer
GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
Nov 22, 2008 | GE 24 in. GSD980X Built-in Dishwasher
F2 code
go back to drain pump.. pull pump out ckd the impeller on motor pump shaft there should be a slight resistance when the impeller is turned by hand ..have seen impeller come loose of motor shaft and free wheel
Aug 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
LG Front load washer
I JUST FOUND THE LEAK ON MINE JULY 5. THE DISCHARGE HOSE ON THE BOTTOM SLOWLY ROTTED THROUGH. THIS GOES FROM THE TUB TO THE DISCHARGE PUMP. ABOUT $9-10 ONLINE- BE SURE TO FIND AND DOWNLOAD THE PDF SERVICE MANUAL. TELLS YOU HOW TO TAKE THE MACHINE APART THE RIGHT WAY.
Jul 04, 2008 | LG WM-2277HW Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
24 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
