Question about Toshiba Satellite A105 Notebook
How can i use a number pad commands on a laptop
-i need it to use commands
  • Anonymous Apr 30, 2009
    i have no numlock and the Fn key doesnt work for the function i need please help
  • 114 Answers
Either by pressing and holding the Fn key while using the numeric keys. Or use the Num Lock and you don't need to hold down the Fn key.
Posted on Jan 17, 2009
I need the subnet mask number
go to your computer open command pad type ipconfig/all hit enter and look for your subnet will be the same for your xbox.
Oct 27, 2012 | Belkin Wireless Surf Router (F7D2301)
I dont know where to find my wifi configuration setting
To see the most information and be able to change it you need to follow these steps. 1. Open command pad (click start and search bar type cmd) 2. In the Command pad type ipconfig/all 3. Look for default gateway and remember that number. Will look something like (192.168.1.1) 4. Open a webpage and type that number into the address bar and hit enter. 5. It should ask you for username/password default uername is admin and password is 1234. 6. after that you should be in your route and navigate around it til your find what your looking for. Hope this helps Lot of bad talk about Edimax routers.
Oct 22, 2012 | Edimax BR-6226n nLite Wireless Broadband...
I need serial number for command & conquer red alert 2
please help lost the 22 digit serial number to command & conquerred alert 2 to install on my laptop
Nov 23, 2010 | West Wood Studios Command and Conquer Red...
When typing the letter U the number 4 pop in same for I-5 O-6P-* .
This laptop has a number pad as an alternate assignment of these right hand keys. When this is active, the Num Lock light should be lit. To unlock the Numpad, press Shift and NumLk. (There are three status lights related to the keyboard status: Scroll Lock, Num Lock (which has a 1 inside the Christmas Tree profile icon, and Caps Lock.) With Win2K and WinNT, resetting this setting requires logging out of the account after changing the setting and then logging back in. The more recent Windows OS versions should handle this without rebooting or logging out and back in.
I hope this helps.
Jul 01, 2010 | IBM ThinkPad T23 2647 Notebook
How to disable touch pad in asus k40IN series? I do not see touch pad settings?
This happend to me on a Asus U81 (Best Buy version of the U80) which has the Elantech mousepad
9.10 includes an X configuration utility called xinput. It is a command line tool. To see the many things you can do with this simply type xinput at a shell prompt.
Start by typing in:
Quote: xinput list This will show you all the input devices attached to your computer. You will need to know your mousepad's id to continue. On My Asus laptop the internal pointer was found as a "ImPS/2 Logitech Wheel Mouse". The Id I get after booting my system with my external mouse attached is 10.
Next you need to know how to disable the mousepad. So you need to know what properties it supports. the command is "xinput list-props" followed by your mousepad's id number, which for me was:
Quote: xinput list-props 10 The "Device Enabled" was what I needed to be able to use to switch it off. On my laptop this line was "Device Enabled (97): 1". The parenthesized number is the properties id number, the 1 that follows it is the value (0 will turn it off).
So now I need to set it such that the mousepad is disabled. My mousepad id is 10, property id I want to set is 97 and I need to set the property value to be 0. The option for xinput is set-int-prop which needs deviceid, propertyid, format of the value (8, 16, or 32 bit), and the value itself. For me this is:
Quote: xinput set-int-prop 10 97 8 0 To turn it back on:
Quote: xinput set-int-prop 10 97 8 1 Since this does its work on the X in memory it is not persistent. If you log out and back in the mousepad will be active again. This is desired behavior for me as I occasionally need to be able to use the laptop without my external mouse.
When I get a little time, I will write a small shell script that can toggle it on or off based on a grep of the output of "xinput list" and bind it to a key combination so I can do this without having to drop out to a script. (EDIT NOTE: See post #15 in this thread if you want the scripts)
One last note, xinput interacts with X. It will not be able to function at a normal terminal screen not running under your X. It will work just fine in an xterminal (the one under accessories menu).
Hope this helps.
Feb 19, 2010 | ASUS K40IN Notebook
Acer 5517 mouse pad does not work. is it just a
First you should check if the button that enables and disables your touch pad is on. It's the button left to the power button.
Feb 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
Number pad
You can't make the alternate characters like °, ®, ♂, σ etc with a combination number pad. You need to have a seperate number pad. I use a $20 plug in keyboard.
Oct 29, 2009 | Dell Latitude D505 Notebook
This numpad script at uberullu.com will probably work with your system as well. It uses Autohotkey to remap the keyboard keys.
Apr 30, 2009 | Computers & Internet
Whilst typing the cursor moves to another part of the document
If your laptop has the option too you can turn off touch pad through a switch above the touch pad.
If you can't find this, or you don't have one, simply go to the run command and type in devmgmt.msc, ok.
Once in the device manager go "Mice and Other Pointing Devices"
look for your touchpad, right click on it and select disable.
Please note, some laptops wont let you disable to the touchpad, mine wont, but mine has an on and off key.
ON/OFF Key
Touch Pad On
Touch Pad Off
This will keep the mouse from moving whole you type, but I suggest you get a regular mouse, especially if you have to disable the device with the Device manager.
Jan 05, 2009 | Computers & Internet
Toshiba Laptop "Enter" and touch pad not working
This screen should have a 30 second count down, then start Windows normally. If yours doesn't do this, then she may have keyed the automated recovery and interrupter it causing an operating system error or glitch. If this is the case you will need to run a system repair with your recovery or operating system disc. If it does start Windows after the count down, then run a system restore. One of these will take care of your problem. Also, there is no locking command for the touch pad or enter key.
Aug 01, 2008 | Computers & Internet
Toshiba Satellite A105 Notebook Logo
107 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
