Question about GE Profile JB988 Electric Kitchen Range
GE JB988/JB968 won't stay hot after successful preheat
Our oven operates properly in convection mode, but will not maintain temperature in standard mode after it has successfully preheated to the set temperature. That is, it will heat to 375 but will then cool back down.
4 Suggested Answers
SOURCE: GE OVEN DOES NOT WORK PROPERLY JBP69SGH2SS
I am not an expert, but this has happened to me. Examine your circuit breaker and see that it provides the amps that your oven requires. If it just barely provides it, then it could be that your circuit breaker is tripping if you have anything else on that line and it is being used. Especially hair dryers. If your circuit breaker is not tripping, you should contact GE or repair service because you may have a "power module" problem. Good luck.
Posted on Aug 24, 2007
  • 180 Answers
SOURCE: The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Posted on Jan 30, 2011
richroth
  • 9472 Answers
SOURCE: Ge profile convection oven 164d3871p001 stays on but does not heat up by itself after preheating
You will need to replace the "cycling thermostat". Here is the part to order.
Posted on Nov 27, 2012
I have a hotpoint gas oven the will preheat , but not maintain temperature
That pretty much sounds like a weak igniter thats causing your troubles, while the igniter first comes on to preheat the oven its seems to be ok,yet once it has been on for a while the igniter is getting weak and not allowing the gas to flow properly once its hot. By replacing the igniter the oven will maintain tempature.
GENE
Sep 28, 2011 | Kitchen Ranges
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
GE oven, F2 message but fault is with broiler element staying on?
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked - If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F2
Note: Also see fan thermal switches - Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem.
· Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
Good Luck
May 26, 2009 | GE Profile JB968 Electric Kitchen Range
CRG9700 - OVEN TEMPERATURE BIG FLUCTUATIONS
biggest issue with any gas oven is a faulty ignitor, not maintaining oven temp, too long to preheat, taking too long to cook, possible slight gas smell during operation, all signs of a bad ( or going bad) ignitor
Nov 10, 2008 | Kitchen Ranges
Preheat gets to temp but oven drops 20 d+/- after food goes in. Is this normal
You may have already solved this but either your convection motor is not on or you have an air leak. I would get the repair man out since it is probablt still under warranty.
Oct 24, 2008 | Frigidaire PLCS389DC Dual Fuel (Electric...
Temperature problems in Bosch range
I would check to make sure you are using a 220 plug.
Jan 09, 2008 | Ovens
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
GE oven
Yup...I believe this may have been an issue with some GE models. I seem to remember a problem where some models had problems staying lit after preheating. The fix was replacing the oven thermostat. Now...the normal cycle for an oven lighting is just what you described. The glow igniter will glow first, followed by the gas valve opening, followed by ignition. Once the oven reaches optimum temperature it is normal for the gas to shut off and come back on to maintain oven temperature. However, if this is going on in a frequent fashion with the oven never getting warm, your guess is probably a correct one. Good luck to you.
Jul 31, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile JB988 Electric Kitchen Range Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
