When I turn on the computer at the mains everything seems as normal, although when I switch on the hard drive.. the L.E.D flashes red and green, and the monitor L.E.D goes from green to orange instead it should be green. The hard drive sounds like its running as normal. The problem began with the system freezing and crashing, please help
  • IQUIT May 11, 2010
    please post the BRAND and Model of the system and the version of the Operating System (Windows XP home, Windows 98 etc)
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Could you explain the steps you are using to "switch on the hard drive"..thanks
    Genius:
  • 1,102 Answers
Have you tried a virus scan
Posted on Jan 17, 2009
My playstation turns on and the green light comes on but it turns to flashing red in about three seconds. It never comes up on the screen
It could be a failing hard drive...Try to remove the hard drive from the system and restart it without the hard drive if you can at least get to the main menu then it is your hard drive that is causing the problem.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
Photo 1290 Changing ink cartridge
You may have to reset your printer, for when the green an red are flashing. Please do the following in order to reset the printer;
1-switch off printer itself
2-switch off at socket for 20 seconds
3-hold down both black buttons on front
switch on at mains
4-switch on printer itself
green and red flash together
5-now switch off at mains and leave for 3 seconds
6-while holding down both front buttons again, switch on at mains
both green and red flash together so release
7-quickly hold down the left botton, the one with the scroll icon above it.
Hold this until it resets itself, - the print head will re
charge and it will be obvious.
Restting by unpluggin rather than turning off at mains tends not to work.
This must help you as it worked for me.
Regards,
Anirban Mazumdar
Jun 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
The players red and green light keeps flashing and wont come on
THIS CAN BE SOLVED BY CHANGING THE MAIN POWER SUPPLY BOARD OF YOUR DVD PLAYERS. The main problem should be the Main Capacitor in the circuit. The safer side is to change the whole board.
Apr 23, 2009 | Televison & Video
Solid red light, flashes green when i turn it on then it dies.
Pretty much the only thing worth trying is starting the PS3 without the hard drive.
If it doesn't work it's more than likely a GPU problem that only Sony can fix.
Either way check out my guide here for tips and details.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 28, 2009 | Sony Playstation 3 (PS3) Console
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
External drive seems to freeze up everything, including desktop when USB plugged in
Do not panic. The problem is with the controller in the external case and not the HD itself. Open the case and remove the hard drive. Bring it to circuit city or best buy and invest in a new HIGH QUALITY external case for your hard drive. An associate at either of these stores will be able to tell you the exact case you will need.(SATA,E-IDE,IDE,ect...) DO NOT BUY the cheapo $10 cases you can get on the net. There is a reason some cases cost more then others and the main reason is the quality of the internal components and the durability of them. Install Your HD in your new case(very simple) and you will be up and running in no time.
I Hope this helps you out and you appreciate my help enough to remember to rate me FixYa when you are all fixed up.
Feel free to contact me with any of your other technical needs,
as always my help is free...This is my hobbie...
George
Jul 19, 2008 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Light doesn't turn blue at all
Plug it into another computer if possible, clear ALL files on it.
You must of been sending something to it when you flicked the switch, they would normally go off straight away.
(Backup on the other computer first)
If this does not work then you may want to see if you can see a usb stick in your USB ports. If you can it's a fault with the harddrive, nothing else you can do.
Mar 31, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Flashing red and green light in xbox
You have a major failure on the motherboard. If it was your hard drive the system will boot up, but freeze on the main screen and you will hear clicking coming out of the hard drive. Red and Green flashing lights means there is a problem on the motherboard. Sometimes you can fix the problem by reflashing the Bios on the main motherboard.
Nov 11, 2007 | Microsoft Xbox Console
No video
does the 320gig hard drive have an operating system on it?
Nov 08, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
