Question about Refrigerators
Icemaker stopped making ice. Replaced icemaker. Still no ice
Any ideas?
  • Refrigerators Master
  • 8,220 Answers
Pour some water into the IM. If it kicks out a batch then replace the water valve. If it don't then get a refund. The IM is it's own master. It has a thermostat to determine when to initiate harvest and it is the one that calls for water. If your freezer maintains 28 degrees F and the water valve, water filter (if applicable) and ice maker are all ok then you should have ice.
Posted on Jan 17, 2009
Ice cube tray won't stop making ice.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
Thank you
Rick
Mar 12, 2012 | Refrigerators
Ice maker stopped making ice
Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Icemaker quit making ice; water works
is there ice in the maker but will not droup out?
Jul 23, 2009 | Whirlpool GS6NBEXR Side by Side...
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Standalone icemaker sounds like a Harley Davidson
check and make sure you don't have a piece of scale in the intake of the waterpump. the pump stops when the unit goes into defrost to dump the ice onto the cutter grid. also check the fan under the icemaker for lint buildup on the condensor
Dec 19, 2008 | U-Line Icemaker
Frigidaire Side by Side Icemaker
The icemaker evaporator system that releases the cubes is faulty , and must be replaced.
Apr 02, 2008 | Frigidaire FRS-26DR7D Side by Side...
Icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Oct 25, 2007 | Whirlpool ED2FHEXN Side by Side...
Ice maker is not getting water.
check and reset the temp in the ice maker freezer coils them self's
Aug 08, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
