Question about Whirlpool LSB6200KQ Top Load Washer
Um..... not quite sure....
When i was washing clothes the washing machine started to make a squealing noise (continuous), smelled like smoke, and wouldnt drain or spin. took out clothes tried to start a mock load with nothing in, and noise started again after water filled and wouldnt agitate..... what is the possible problem? and solution....
  • Anonymous Apr 20, 2009
    Is the cost of repair worth having it fixed?
    Problem Solver:
  • 14 Answers
Most likely the transmission on the motor has seized and will need to be repaired. Look under the washer, if there is black grease on the floor then its time to replace the motor and/or the transmission. If you have seen smoke then its probably the case.
Posted on Jun 20, 2007
SOURCE:
Hav3460aww
It sounds like the motor is heating up and tripping the overload. The squealing is probably coming from you pump. Tilt the washer back and turn the pulley for the pump by hand and if it make the squeal, replace. If it does not you may have a bad transmission.
Apr 28, 2014 | Maytag HAV3460AWW Top Load Washer
Washer started to smoke during spin cycle then a cracking noise began after that.
You may just have a defective drive belt. The motor itself will smoke under certain failing circumstances. Can you give me a model # ?
Jan 07, 2013 | Washing Machines
Cabrio washer door won't open!
if you plug it back in.... set at any cycle it should release then unplug asap. the aggitor/drum belt is what you are smelling.
Feb 14, 2018 | Whirlpool WTW5700XW Cabrio HE Washer
Shorting out when you turn the dial on front ,was making funny noise the other day too
Please post a model number. What do you mean by 'shorting out'? Was there a pop, or spark, smoke, or burning smell? What was the funny noise? A hum, a clanking, a squeal? And what area of the machine did it come from? Does the machine agitate, spin, or fill? Thanks.
Mar 11, 2011 | Washing Machines
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine makes squealing noise during the
when belt was changed did you find the old belt to be oiley . it maybe leaking oil from trans . and the belt will keep failing till oil leak is corrected.. mm
Dec 14, 2009 | Washing Machines
I have a quite normal front load whirlpool washing machine and the feeling when I clean my clothes is that the smell is that fresh smell anymore, does not smell like softener or any soap but a horrible...
Oh angel!
a rose by any other name!
If your clothes smell worse after washing then the machine is full of gunge from all the previous washes. One of the worst things that puts a gluggy deposit inside machines is of all things Softener!
You could try putting a generous two cups of Sugar Soap Concentrate into your machine and filling it with warm water. Then let it stand for 24 hrs, Then start the wash cycle.
This may clear the gunge. If not the only sure remedy is a strip down and degunk and that will cost you a few dollars.
Oct 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Squealing noise during wash cycle
yes thats a belt slipping may have something in the pump maybe a coin or a small item like that.
Aug 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool LSB6200KQ Top Load Washer Logo
265 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
