Question about Electrical Supplies
Honeywell xls1000 fire panel sounding
Reading ''smoke maint alert'' reads on panel. panel is silenced , but comes back after 24 hours and reset doesn't restore to normal.
  • 565 Answers
It will probably keep doing that until u run a maintenance routine on the smokes from the panel. Look in the panel main menu and you should find a maintenance (or similar entry). Run it.
Posted on Jan 25, 2009
How to reset the maint notice in a murano 2004?
Pressing the maint button twice silences the indictor until the next time the car is restarted. You have to hold down the maint button until the mileage is reset to zero (similar to reset the trip odometer) for both oil and tirerotation.
Aug 16, 2015 | Cars & Trucks
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
House alarm beeps every 45 seconds
Not knowing what brand makes it tough, most of the time if you push any key it should silence it.
Dec 26, 2013 | Honeywell Ademco 6160 Alpha Keypad Vista...
The sensor Honeywell TC807A 1036 (Smoke Detector), is compatible with a NFS-320 Fire Alarm Control Panel?
I don't know if that particular smoke is compatible or not, but the NFS-320 is a commercial rated UL864 Revision 9 fire panel, which means the documentation is part of the UL listing. This means that in order for a device to be compatible with the system, it must be listed in the Installation Instructions as compatible. I couldn't find any mention of that particular smoke in any of the documentation I found for that alarm panel.
Oct 23, 2012 | Honeywell Tc807a1036 Smoke Fire Detector...
How do I reset "Maint
First open your ingintion and make sure dash reads odometer, then close ignition press and hold trip-odometer buttom open ignition odometer read out will show --------------- flashing lines wait until they dissapear and odometer reading is back 69487 or else then release buttom reset is done.
Jan 13, 2011 | 2002 Toyota Camry
"maint reqd".
That is for oil changes. It come on when the oil change is due.
When you have your oil change done, the lube tech should reset the this light every time.
If you need help resetting the light, let me know.
Apr 02, 2009 | 2005 Toyota Corolla
Honeywell T8011R
Check for either an in-line fuse in the heating unit or a fuse on the control board also in the heating unit.
Nov 06, 2008 | Honeywell Programmable Thermostat Heater
Ademco 15P Check Fire Alert
Check means it is not seeing the smoke detector. This usually means a broken wire or even a nail or staple through the wire. Does the smoke detector use two or 4 wires?
Oct 21, 2007 | Eagle SeaChamp 1000c Recording Sonar...
Electrical Supplies Logo
1,197 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
