Programms rotate without stop
I've got a ARISTON Margharita Front Loader
The machine was washing and after it stoped and the programmer starts rotating wall the programms without stop.
  • pedrobasilio Jan 17, 2009
    My washing machine programmer doesn't stop rotating
  • Washing Mach... Master
  • 3,463 Answers
Check your instructions, and see if there is a reset point or function, if there is not ,then it has a control unit malfunction, and unfortunately, this is not something you can fix yourself.
Plz rate my solution.
Thanks.
Posted on Jan 17, 2009
I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Jan 27, 2010 | Ariston Technologies AW149NA Washer
My Ariston front loader washer does not spin when it suppose to. I could hear the motor is running but the tub is not rotating. I also tried to rotate the tub by hand and there seems to be some friction...
Remove the rear cover and check the drive belt has not come off.
If the belt is off, there should be no resistance to turning drum, if there is, then there could be something trapped inside, or the main drum bearings could be failing.
Jan 11, 2010 | Ariston Technologies Washing Machines
Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
Jan 05, 2010 | Ariston Technologies Washing Machines
Ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Aug 31, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Jul 06, 2008 | Ariston Technologies AW149NA Washer
Ariston Margherita 2000 (Advantage) Model A1435UK
Ariston Washer Dryer Margharita 2000. I have inherrited this machine but there is no user manual, does anyone know where i can get one from??
Mar 25, 2008 | Washing Machines
Problem in starting
Try to replace the doorlock with a new one. Worth a try.
Jan 24, 2008 | Supra SW5L65D Front Load Washer / Dryer
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
