Question about Magellan Maestro 4040 GPS Receiver
I turned on my 4250 and all the colors have changed. Can I change the colors. I used to have water showing blue now it is showing as brown.
  • 32 Answers
I had the same problem with my 3210 (especially below 10 deg C)You can press the RESET button . this may help but Magellan eventually had to replace the unit
Posted on Jan 21, 2009
Replacing Thermostat I'm replacing our current battery-operated Honeywell thermostat with a wifi Honeywell thermostat. Our current one does not have a c wire hooked up to it but it does have two unused...
The c in the furnace that is white is going to your condenser, it must stay. ADD the blue that goes to the tstat OR brown, which ever and then use that color on your new tstat and you will be fine. Always turn power off when changing stat
Sep 26, 2017 | Honeywell Heating & Cooling
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
This will show you how to wire trailers with seven, six and four pin connectors
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs (Large trailers with a battery and electric brakes):
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 2004 Dodge Ram 2500
Tip
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Columns are Color, Function, Mark on the plug.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 1981 Ford F 150
I have a 2000 VW Passat GLS that I'm trying to install a Dual stereo system into but I can't figure out what the wire colors on the car are for each thing (power, ground, etc.). I've looked online through...
First of all I would highly reccommend you use a wiring harness such as the Metra 70-1784 or the Scosche VW01B for two reasons; 1) it will make things 10 times easier for you and 2) it will keep all your factory wiring intact.
If you want to tackle this without using a wire harness do not just go and cut off your factory plugs, leave them on in case you ever need to change out the radio to a different model/brand of if you ever decide to sell the car or trade it in you can put your factory radio back in and keep your nice new radio for the new car. Just tap into the wires behind the plugs and make sure to insulate your connections really well so you don't pop fuses or worse.
Here's the wire colors and what they do:
12 volt constant wire - Red/blue
Ground wire - Brown
Radio ignition wire - Red (thicker red wire)
Radio illumination wire - Gray/blue
Front left speaker - Red/green (+) and Brown/green (-)
Front right speaker - Red (+) and Brown/red (-)
Rear left speaker - Blue/white (+) and Brown/white (-)
Rear right speaker - Blue (+) and Brown/blue (-)
If you're using a amplified antenna adapter that has a blue wire attached to it, connect that blue wire to the thicker red radio ignition wire.
Hope that helps.
Apr 02, 2011 | Car Audio & Video
My magellan back ground changed from light blue to brown...why?
It could be the default settings when it goes to the night mode.
Dec 25, 2009 | Magellan Maestro 4250 GPS
Magellan Maestro 4220.....color of screen changed on it's own.
On the bottom of the unit there is a reset button. The button is recessed, so you have to use a the tip of a ball point pin or something similar to reset. Mine did the same thing and that fixed it.
Feb 01, 2009 | Magellan Maestro 4250 GPS
No service
What color wires were there ???
What kind of jack, a new one that had...
white blue/blue
white orange/orange
white green/ green
white brown/brown
If so, the white/white blue would go to the same wires.
If you had red/green and black/yellow, the red/green should go to the white blue/blue.
Jan 13, 2009 | Lands Phones
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Magellan Maestro 4040 GPS Receiver Logo
79 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
