Question about HP cp1700d InkJet Printer
CP1700 Alignment I have misplaced my manual and simply need to know how to do an alignment on my printer! Thank you So much for your help!
    Problem Solver:
  • 7 Answers
Control Panel > Printers & Faxes > right-click on the printer and select Properties. Depending on your printer make and model, the option to align your printer should be in that menu somewhere.
Posted on Jun 20, 2007
SOURCE:
Print quality problems
Sir/Madam
I Suggest You Visit Below Link And Follow The step Written For HP Printer,I m Sure You Fix Your Hp Printer Problem,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01177917&lc=en&cc=uk&dlc=en
In Case You Still Having HP Printer Problems Hen Follow Us For
HP Printer Support
Jan 16, 2014 | HP Office Equipment & Supplies
I put in a new ink cartridge and I can't print....it keeps saying..."align printer". This has never happened to me before. What should I do? Thank you for your assistance.
You need to align a printer everytime you put a new cartridge in. It is a 2 step process
1 the printer will print an alignment page - usually coloured squares. 2 You then scan this page back into the printer - alignment is then complete.
this is the link to the manual page 42 through 44 explain about installing a new cartridge and the alignment process.
Dec 14, 2010 | Lexmark X2470 All-In-One InkJet Printer
Why is my printer only printing color and not black ink while there is a black ink cartridge installed? When I looked at the printer after printing the alignment page, it said alignment problem but there...
This happened to me as well. Take your alignment page (or print another one) and put it in your scanner. The AIO printer will use the scanned alignment page to reconfigure your alignment.
Oct 15, 2010 | Dell 926 All-In-One InkJet Printer
Alignment Issue
Browse through the menu, there must be a head alignment test/function. Also inspect the printer driver and/or utilities installed on your computer and find a head alignment function.
It's not complicated, either it's fully automatic, or you'll have to look at a printout and choose the best-aligned lines, depending on printer model.
Nov 01, 2009 | Lexmark X7350 All-In-One InkJet Printer
HP 5510: "Press OK to print Align Page" appears permanently, even after performing the alignment. Fixya advised removing power to reset the printer, but that doesn't help. I removed and reinserted ink...
To simply bypass alignment, do the following:
Press and hold the Setup button.
Press the Up Arrow button. The printer should be ready to print.
If print quality is unacceptable after bypassing alignment, troubleshoot the problem as follows:
Make sure the printer is loaded with clean, unused, white paper. If the paper is not feeding properly, check the paper path. Click here to see how.
Remove and inspect the cartridges. Click here for instructions. If the cartridges are new, make sure the protective tape covering the nozzles has been removed.
Reinsert the cartridges into the printer. Press Enter to align the cartridges again if prompted.
If the problem continues, check the cartridge ink levels. Click here to see how. Both cartridges must have ink in them for successful alignment, so replace empty cartridges.
Watch the area inside the front of the printer as the alignment procedure runs. You should see a blue light below the cartridges as they move back and forth. If you do not see the blue light, click the link at the top of this page to contact HP. The printer needs to be serviced.
Compare the alignment page produced by the printer to the illustration below. If any of the colors are missing, run the Clean Print Cartridges utility. Click here for instructions.
Abbildung 1: Alignment page
If the problem continues, clean the contacts. Click here to see how.
If none of the steps above solve the problem, replace the cartridges or have the printer serviced. Click here to see how to decide whether to replace the cartridges or service the printer.
Let us know if that was helpful,
Thanks
Shiv.
Aug 23, 2009 | HP Officejet 5510 All-In-One Thermal...
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
My lexmark printer alignment is off and I can't fix it. Please help.
To align the cartridges:
  1. Press the Options button nine times until MAINTENANCE appears on the display.
  2. Then press the right arrow (+) twice; you should see the word Align.
  3. Press Select. The alignment page will be printed out automatically.
If this doesn't solve the problem please send me a comment Thank you.
Jan 12, 2009 | Office Equipment & Supplies
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Align cartridges
Why don't you just show the manual. I must have misplace mine. I have replaced the cartridge and want to check the alignment. I have an alignment page printed, but what do I do next.
Aug 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer alignment
Based on the description of the issue, it is difficult to determine the exact nature of the alignment problem you are experiencing. Please see http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065257&cc=us&lc=en&dlc=en&product=3311793 regarding printer alignment issues. If this does not address the specific issue you have, the manual for this model is located at http://h10032.www1.hp.com/ctg/Manual/c00905267.pdf.
Particularly since this is a relatively new product, you can get very timely support from HP's online support - free chat. See the link at the left on this page:
http://h20179.www2.hp.com/HPCC_tutorials/home/home.html
The HP staff will help you work through any issue relative to your product, and have access to tools that are not generally available to the public as well.
Please post back with further detail regarding your issue if you need additional help, otherwise, thanks for rating FixYa!
May 28, 2008 | Office Equipment & Supplies
HP cp1700d InkJet Printer Logo
59 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
