Question about Philips HDD1630 MP3 Player
My philips 30gb wont play my songs!!!
Ok one night i was using it and everything waz ok and i erased all da songs and put new ones on and i went to da songs and tried to play da songs and i press play and it wouldnt play and da timer at da far bottom left cornor stayed like this 00:00 and nutin would play and couldnt hear nuthing i got so mad i started to cry.. if u can giv a file of da cd dat cums wit da philips gogear 30gb dat would be kewl cuz it repairs problems dont it or if sum1 could giv me a solution dat would be kewl also :) r.i.p philips 30gb for now i hope :(
  • 8,596 Answers
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
When deleted songs, I have deleted everything. so now I have no
you can get a data recovery program to get the songs back do a google search
Mar 29, 2009 | Visual Land VL-340 MP3 Player
What to do
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 19, 2008 | SanDisk Sansa e260 MP3 Player
Deleted songlist! e260 MP3
Try pressing f5 for refresh in Windows Media Player first (with your Sansa player connect)
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 07, 2008 | SanDisk Sansa e260 MP3 Player
Songs will not show up in the mp3 player!
something is wrong with the format of the new songs
Feb 19, 2008 | SanDisk Sansa e260 MP3 Player
Samsung Juke Music Issue
Had the same problem with being able to load MP3 songs onto the phone but they would not play. Elapsed song time indicator remained at 0.00.
In Windows Media Player, select Sync Menu......then Samsung Juke........then Format. The warning states that you will lose all data. This only pertains to the songs that you cannot get to work anyway. Your stored phone #'s will still be there after the reformat.
I reformatted and reloaded the MP3's and everythings now works just fine.
Jan 28, 2008 | Samsung SCH-u740 Cellular Phone
New songs= black screen
try to remove the battery, wait 30 seconds and replace it
this should reset your sansa,
a real hard reset isn't possible,
you can format it though
warning, this removes everything
To format your Sansa E200 series MP3 player:
1. Open "My Computer."
2. With the player plugged into the USB port, right-click on the player (if in MTP mode) or the drive letter for your player (if in MSC mode) and select "Format" from the right-click menu.
3. Press "Start."
4. You will receive a warning that the format process will erase all data on your device.
IMPORTANT: Make sure you have backed up all of your data from the device before continuing with the format. Procedure will erase everything off the player. Agree to the warning.
5. The format will complete. Close the format window and your player should be ready to use.
After the format, please install the latest firmware update for your player. Please visit the following link to download and upload the Firmware on your Sansa E200:
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00...
PLEASE NOTE: All files will be deleted. Backup your files. Your MP3 player must be in MSC mode before installing the Firmware update.
To set your player in MSC mode, please do the following:
1. When the player is turned on, press the “Menu” button.
2. Navigate to the “Settings” menu.
3. Navigate to “USB”.
4. Under the “USB” menu, go to “MSC”.
After changing the player to MSC mode, reconnect it to your computer. The screen on the MP3 player should read “USB Connected” and "MSC”
You can now complete the Firmware update download from SanDisk.com on your device.
Installation Instructions:
1. Unplug any other USB flash drives that's connected to any of your USB ports.
2. Download the firmware to your PC
3. Plug in your e200
4. Double-click on the downloaded firmware (e200fw01.00.12.exe) and follow instructions
5. Unplug your e200
6. Device will do it's own update process and will restart.
The device should be ready to be used again.
Dec 16, 2007 | Audio Players & Recorders
Won't play certain songs
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
or
-Tha Mp3 Doctor
Oct 31, 2007 | SanDisk Sansa e260 MP3 Player
Playing
I had the same problem and it took me while to figure it out, but I did. Thanks to a website telling me how to re-format the whole thing. I went to "my computer" and right clicked on "removeable device" and clicked on format. It should read "fat" not "fat32" then I clicked "start" and then when I loaded stuff on it worked. Good luck!
Feb 18, 2007 | Finis Swi MP3 Player
Philips HDD1630 MP3 Player Logo
93 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
