Question about Nintendo Wii Console
Nintendo wii console
Hi there
is it possiable for a tiny sticker ( the sticker is a sticky paper) to ruin a wii drive and have to have it replaced
i sent my wii back and that was the problem it cost $120 to get it repaired now im wondering if it was the case as the sticker is no bigger then a 5c peice
thanks for your help
katie
  • 903 Answers
Anything that gets jammed in the drive can cause damage, if the wii has to be disassembled to repair it then this is probably correct.
Posted on Jan 17, 2009
I accidentally inserted a disc the wrong way in our Wii console and cannot get the disc out now - the eject button won't work, what should I do?
Check if you can see a small hole on the media drive or optical drive. Use a paper clip to manually eject the disc.
Hope this can resolve your concern.
Jun 26, 2011 | Nintendo Wii Console
Tip
Wii remote buttons are sticky or stuck down
Try cleaning the buttons of the nintendo Wii Remote using the cleaning instructions below, being sure to follow the directions carefully.
    What you will need:
  • 1 clean toothbrush (no toothpaste on it)
  • 1 cup of warm tap water
  • 1 paper towel
    Instructions:
  1. Remove the batteries from the Wii Remote.
  2. Get a clean toothbrush (no toothpaste) and a cup of warm tap water (not too hot). Do NOT pour or submerge the Wii Remote in any type of liquid.
  3. Slightly dip the toothbrush in the water (the toothbrush should not be dripping wet) and scrub the area of the Wii Remote around the buttons.
  4. Work the bristles down around the sides of the buttons.
  5. After cleaning the Wii Remote, dry it off with a paper towel.
  6. Let the Wii Remote air dry with the buttons facing down for at least a couple of hours.
  7. Test the Wii Remote for proper response.
  8. Repeat the steps if necessary.
If the buttons are still sticky after cleaning, the Wii Remote will need to be replaced. Our experience shows that this type of problem is usually caused by physical damage and not covered under Nintendo's warranty. You can purchase a replacement at retail stores that sell Nintendo products.
on Mar 04, 2010 | Video Game Consoles & Games
Tip
Repair game systems that have problems reading disks
The Trick is to disassemble the console and open the disk drive. DO NOT use alcohol to clean the lense as this will ruin it. to clean your laser lense use eyeglass gleaner and a eyeglass cloth. I do this whn I repaire xbox 360's and it works Great.
on Mar 16, 2009 | Nintendo Big Brain Academy: Wii Degree for...
MY SISTER HAS THIS WII AND SHE JUST CALLED ME AND I EXPLAINED TO HER TO GET ON THIS SITE... WHAT SHE WANTED TO KNOW WAS IF HER WII WAS ACTUALLY BURNT OUT, WHERE DOES SHE PURCHASE THE NEW FUSE?
The fuses are VERY difficult to replace even if you have the part. you will need to be very comfortable working with electronics and very good at soldering to replace the tiny surface mount fuses. If you have someone with the skill here is a guide:
http://www.ifixit.com/Guide/Repair/Repairing-Nintendo-Wii-Drive-Board-Fuses/4029/1
fuses can be obtained here:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=478-2860-1-ND
Mar 18, 2011 | Nintendo Wii Console
Wii disk will not stay in the console
Has anything been jammed inside the Nintendo Wii to cause this?
Has the Nintendo Wii been dropped?
There are usually 2 causes for this.
The Nintendo Wii disc drive could be damaged and/or something is jammed inside the drive causing the discs to automatically eject.
Also, your firmware could have malfunctioned, causing the drive not to work.
If you have experiencing opening the Nintendo Wii up, I would recommend you do so and look to see if anything is stuck inside.
if you're not comfortable doing so, I would recommend for you to send this system in for repair.
Apr 19, 2010 | Nintendo Wii Console
Grandson put a ds game into the Wi where the disc
Does this unit have a tiny hole, similar to those found on CD or DVD drives, which allows the insertion of a large paper clip?
By pushing a straightened out paper clip into this hole, you can push with a certain amount of force, which will then allow the drive to open, and from there, you might be able to remove the disk from the ds game.
Good Luck,
-a.
Jan 06, 2010 | Nintendo Wii Console
Hi my wii will not turn on but I have a game disc inside. How do I remove the disc without power? Is there a manual eject?
since the Wii has an optical drive, what you need to do is to insert a straightened paper clip into a tiny hole that is located on the front of the drive, typically right next to the eject switch. Once you’ve inserted the clip, the stuck CD should be easily ejected.
Jun 24, 2009 | Nintendo Wii Console
Is it possiable for a little paper sticker to reck the wii drive for it to be repaired
If you get anything foreign in the drive, you stand a chance of it getting caught-up in the mechanism and damaging the drive. If it's a sticker, that can be even worse. If you think you have something in your Wii, I would contact Nintendo to get it repaired.
Jan 17, 2009 | Nintendo Wii Console
My wii spits my disc out after i put it in system
I've found that this is usually caused by a problem with the small plastic gears that operate the loading mechanism. Sometimes they break, need to be realigned, or get stuck.
If one or more of them have a problem then the loading mechanism never allows the disc to drop onto the motor to spin. Then the Wii realizes that the disc did not load properly and kicks it back out.
But the only way to see is to take the Wii's cover off.
Jan 13, 2009 | Nintendo Wii Console
Wii is showing Disc could not be read error
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jul 05, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
32 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
