Question about Husqvarna Viking 1
Thread keeps wrapping around bobbin
I was sewing - using a straight stitch - without a problem and for no apparent reason my thread started wrapping itself around the bobbin and created a giant clump! I had to work to cut the clump off. Afterwards I could not get the machine to sew properly again.
I'm in the middle of project and really need my sewing machine...HELP!
  • turtleshe325 Jan 18, 2009
    This worked beautifully! Naturally I was eager to complete my sewing project and I was happy your suggestion worked.
    Thank you for your help.
    Shelly
  • 22 Answers
Frustrating huh?  it happens!  even to us that have been sewing for 50+ years, but the solution is very simple.  Top thread tension is the culprit.  pull the spool all the way off and rethread the top, follow the threading path precisely and make sure the thread goes down into the tension discs.
one more thing - when that happens often times the piece has to be removed from the machine by cutting those annoying loops on the bottom.  if this is the case, make sure you have removed all the thread clippings from in and around the bobbin case.  sometimes one little piece of thread will make you want to use swear words.
good luck and happy stitching.
Posted on Jan 17, 2009
I have a janome 6600. The stitches started jamming up and breaking.What might be causing the challenge with the stitches?
Difficult to say without really seeing what's happening and which thread is breaking. If the top thread is breaking, check to make sure the thread is not wrapped around the spool pin or a thread guide.
Just some things to try:
Install a brand new needle.
Be sure to clean and remove all the thread pieces, lint, etc from under the needle plate, around the shuttle, etc. Oil as instructed in the owner's manual.
Remove all the thread from the machine. ALWAYS RAISE the presser foot when threading the top and rethread the machine from the beginning. Check that the thread path is correct and the bobbin is loaded and threaded correctly.
Be sure to use good quality thread--no Old or bargain bin threads!
Solve Most Sewing Machine Problems With These Simple Tips
Why Does My Sewing Machine Keep Jamming Sewing Made Simple
Feb 11, 2018 | Janome Sewing Machines
Thread balls up885-v60-v61v63-v64- v65 ce1100prw sewing machine brother sewing machine modelCE1100prw
If it is creating a thread mess (thread nest) under the fabric, either the machine is not threaded correctly or you have forgotten to lower the presser foot before beginning to stitch.
Make sure you are starting with a brand new needle!
Check that the bobbin thread is smoothly wound onto the bobbin and that the bobbin is inserted and thread properly in the machine.
ALWAYS RAISE the presser foot and rethread the upper thread. Check that the thread path is correct.
Set the upper tension to the midway point on the dial--this is usually the factory setting but may alter over time with use. Once you get your machine stitching without a mess, you can gently alter the upper tension until the two threads meet in the middle of the fabric.
Remember to lower the presser foot before beginning to stitch.
It also helps to pull the bobbin thread up to the top of the fabric and either wrapping both thread tails around a finger on the left hand or gently holding the thread tails between the left index finger and thumb. Then SLOWLY begin stitching.
How and Why to Bring up the Bobbin Thread
You can search the internet for:
YouTube + Make + Model
and hopefully you will find some helpful videos.
Sep 26, 2016 | Sewing Machines
My Janome MyStyle 16 keeps jamming - thread bunching in the bobbin cavity. Have tried everything but keeps happening... How can I fix this??
PDF]INSTRUCTION MANUAL - Janome
janome.com/siteassets/support/manuals/.../inst-book-7318-english.pdf
making any other adjustments mentioned in this owner's manual. ..... 16 q w e r t. SECTION 3. BASIC SEWING. Straight Stitch Sewing. Machine setting: q Stitch ...
How to Thread a Janome Sewing Machine - YouTube
? 6:55
https://www.youtube.com/watch?v=NUsT0plWt6Y
Mar 1, 2013 - Uploaded by Easy Sewing for Beginners
In this video I show you how to thread a Janome sewing machine ... I've unwrapped it and started reading the manual and it wasn't easy to see ...
Nov 26, 2015 | Janome Sewing Machines
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
How do I set a straight stitch? What is causing the top thread to break?
You do not say which machine you have. As for a straight stitch, make sure the needle is central and not in zig zag mode.
The thread can break for several reasons, such as. Incorrect tension.
:Wrong thread for the material.
: Thread in bobbin different from the top thread.
:Old thread.
: Not threaded correctly.
: Needle not inserted correctly, or incorrect needle.or the thread could be wound around the spool holder pin,
Try removing the spool and turn it around.
Hope this helps.
Mar 02, 2015 | Sewing Machines
Why does my thread knot on the back when stitching in place?
Several things to try:
Pull thread tails (both bobbin thread and upper thread) straight back and when you lower the presser foot, make sure they are held down straight back. This may or may not be enough to solve the problem, but it is simple to try, and often works. You might want to hold the thread tails while you start sewing.
Use a starter--folded piece of fabric scrap about an inch long--and begin sewing oink middle of starter. Push the fabric you want to see right up to the starter and keep sewing from the starter right onto your project without lifting the presser foot or cutting the thread. When you finish sewing, cut the little piece of thread between the starter and your project.
Before lowering presser foot, use wheel to lower your needle once and then pull up bobbin thread to top surface of your project. Then hold both bobbin and upper thread tails, lower your presser foot, and begin sewing. Release the thread tails after a few stitches.
Hope this helps. Those nasty "thread nests" are a real pain.
Jul 13, 2014 | Janome Sewing Machines
Why does the shuttle hook grab the spool thread instead of the bobbin thread? It wraps the thread around the bobbin and binds the machine up.
The shuttle hook is suppose to hook the needle (spool) thread and loops it around the bobbin case to form the lock stitch. Is it possible that something was adjusted without proper clearances as to allow the thread looping around the bobbin case to do so without catching up where it should pass through freely?
~<Ray>~
Nov 13, 2010 | Necchi Sewing Machines
My Memory Craft sews great until I start to quilt or use one of the different stitches and then the stitches either skip or become so tiney I can't pick them out.
Skipping could indicate you need to use a larger size needle.
Tiny stitches could be save reason, or the top thread is hanging up.
Sometimes the thread can wrap around the spool pin or catch on a rough surface on the end of the spool.
Be sure to use the correct size spool cap and if the thread is wrapping around the pin, a thread net can help.
Give the machine a cleaning according to the maintenance section of the manual for your machine, including cleaning the feed dogs, bobbin case, shuttle and surrounding area.
Make sure the feed dogs are up unless you are free motion quilting and the presser foot down.
This may seem elementary.........just trying to cover all the bases.
May 02, 2010 | Janome Memory Craft 9000 Computerized...
Janome Sew Mini bobbin problem
Hi, Usually wrap-ups in the bobbin area are caused by the lack of tension on the top thread. The slack arm ( shinny lever that moves up and down while sewing) has to pull the loop around the bobbin case and it does so only if the tension on the top thread is sufficient to keep it from pulling more thread of the spool.
Try this: Thread the top of the machine all the way just short of the needle eye. When the presser foot is up the thread should pull through easily. Now drop the presser foot (this closes the tension discs) and pull the tread while adjusting the upper tension control.
If everything is working correctly you should feel the drag on the thread change if not something is keeping the discs from closing.
Most Janomes aren't too difficult to remove the nose cover, usually just one screw and you can get a look at the thread path. Look for thread wrapped around the mechanism.
Sorry, no easy answer but I hope this helps.
Mar 16, 2017 | Janome Sewing Machines
Sewing Machines Logo
296 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
