Question about Cadco OV-250 Electric Single Oven
Oven touches cabinet inner wall of cabinet. Fire hazard or not?
I bought an cabinet mounted oven and the back of it touches the cabinet wall after installation. I am afraid that the heat might cause a fire. Is there a minimum distance from cabinet walls or sheetrock to respect when istalling ovens? Can I install a fire rated material?
    Problem Solver:
  • 13 Answers
The rear of the oven has approx 3" or better insulation you are ok
Posted on Mar 25, 2009
New element touching bottom of oven. Two small holes in over.
The element should not touch the bottom of the oven. I would call up the person that did the repair and tell them about the small holes. This may be a fire hazard. You should not be charged for work that was done improperly.
Oct 28, 2015 | Ovens
I need to replace a wall mounted microwave oven. It needs to mount only to the back plate - there is no access to mounting holes in the top. I have replaced this oven once before, but now I cannot find a...
I just replaced one of those myself. New one had totally different back plate which had to be replaced. Both new and old ones were bolted to cabinet above.
Oct 29, 2013 | GE JEB1095 Electric Single Oven
when it burnt off it fell somewhere between the oven chamber and the back panel.once finding it,its just a matter of splicing a new wire terminal end and attaching it to the element. The problem lies in thats its a built in wall oven and may be needed to be removed from the cabinet to find and repair this wire. Depending how tight it fits into the cabinet it may not come out easily and even break the wood around the cabinet. which of course you could face in pulling it out to replace it with a new oven. ONe thing to keep in mind is that all wall ovens are slightly different in size and the replacement oven needs to be pretty close to the size of existing one or the cabinet will need to cut or filled in so their wont be a gap left when new one is smaller leaving a gap in cabinet up to 2 inches on either top or side walls
Aug 13, 2011 | Amana Ovens
How far does wall oven need to be from drywall and side kitchen cabinets?
well they can be pretty close because there alot of insulaion in the side and back of the oven. about a 1/2'' is okay really i've been in houses where it's touching the cabinets
Mar 22, 2011 | Maytag Ovens
Jenn air wall oven control panel not working properly
You will need to replace the front control board and the touch panel
Mar 28, 2017 | Ovens
Hi my rbs305 heaters not working?
Yes, there is one for both units together. It's in the back of the oven, and you will need to remove the oven from the cabinet to get to the fuse. Turn off the power to the oven first - the fuse is connected to a live wire L2. To get to the mounting screws you'll need to remove left&right trim pieces: open the oven door and you'll see the screws on the trim pieces, they are near the door base. Remove screws and remove trim pieces. The mounting screws are in front of you. The oven is HEAVY, and you'll need to secure it somehow while working on it. The fuse is on the back wall, and looks like a disc, attached with 2 screws, has 2 terminals with 2 or 3 wires coming to them. One of the wires will be red in color. If there is no continuity between the fuse contacts - replace. Good luck.
Oct 12, 2009 | Ovens
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
I have a microwave oven that I need to take out.
These are mounted thru the cabinet above. there should be two bolts which you need to remove in the cabinet abobe. remove these while you have help holding the unit. it will not drop but is kind of hinged on the wall (a lip sits on a bracket on the wall) After removing the two bolts tip the unit forward and lift off the bracket on the back wall.Don't forget to unplug it and pull cord thru cabinet as well Good luck...
Jan 19, 2009 | Jenn-Air JMW8330DAS Stainless Steel...
Wall Oven
Hello zultar777,
The oven will fit however it will stick out a few inches beyond the front of the cabinet. If that looks ok to you, then go for it.... Is ther any way you can open up the wall behind the oven to allow the new oven to recess in deeper? You may want to investiaget that option. If the wall behind the stove is a non- weight bearing should be able to cut it opne and remove a section of the wall studs.. also..check to see if the new oven uses any mounting tabs to lock it in place.. if it does and these are close to the front of the oven, you may have to jury rig something to secure the oven.. It may or may not use them thou so check with the manufacturer..
Good Luck
Dec 04, 2008 | Maytag CWG3100A Gas Single Oven
Cadco OV-250 Electric Single Oven Logo
317 people viewed this question
Top Cadco Ovens Experts
Dan Webster
Dan Webster
Are you a Cadco Oven Expert? Answer questions, earn points and help others
