FixYa.com
Tags:
DeLonghi Pinguino PACL90 Portable Air Conditioner
Delonghi PAC L90 (by 4 users)
posted by BB62 on Jun 20, 2007
I need installation directions, mine lost in move.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by arnie429, posted on Jun 06, 2008
Never received instrutions when purchased item. Need to down load copy of operation manual in order for product to work correctly. How do I get these instructions?
Comment by Guest, posted on Mar 25, 2008
the pf alarm on the control panel is activated,unit fan will run but will not activate the compressor-"pf" probe failure not what means and where its located on unit.
Comment by barkley1, posted on Dec 14, 2007
power cord has power but start push button won't start unit
Best Solution
posted on Jun 08, 2008
FixYa! (100)
dgdurango18
Rank:Apprentice Apprentice
Rating: 98%, 8 votes
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 06, 2008
FixYa! (100)
1skull
Rating: 100%, 4 votes
fe means the water tank is full of condensation you need to take out the tank and empty it
Solution #3
posted on May 10, 2008
FixYa! (100)
Senex
Rating: 100%, 2 votes
The probe is located on under the main board low inside the only silver metallic box on the bottom w circuit board under it.Remove cover and immediatly you see a 4 inch black wire connected to the main board tucked under and mounted.Unplug the white connector from board, power on, then carefully plug the white connector back on, turn unit off and back on, you should see all 3 mode lights now on steady , no pf error and it doesnt turn off,and you can change modes and temps.Took an hour to take it part and dig around, mine works fookin great now.
Solution #4
posted on Jul 04, 2007
FixYa! (100)
Guest
Guest
Rating: 0%, 0 votes
Solution #5
posted on Aug 12, 2007
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
Try www.delonghi.com, or go to Lowes and see if they still have one and ask the service desk to copy the english portion.
Solution #6
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Not exactly true. My unit not been on for 6 months (ran last time it was on), got PF msg upon power up after long power off spell, tank is bone dry, and been that way for months, and when I transported it to fix it, it was laying on it side in my car and nothing spilled, inside our out, nothing sloshes around.
Can you Help with these Air Conditioners problems?
DeLonghi Pinguino PACL90 Portable Air...
how do i empty the tank
fe shows in the display how do... Answer This...
My AC is not cooling the air
My AC was flashin FE, so I read... Answer This...
Hot Air
doesn't seem to cool Answer This...
PAC L90 water tank capacity
With the PAC L90 how long will... Answer This...
Full Tank
Our unit is flashing ft, so we... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
