SOURCE: my Toshiba Tecra touchpad is not working. the
try uninstalling the touchpad driver from your device manager then reboot...
SOURCE: Where to find driver for touchpad scroll toshiba
To Enable the Pointer Device, go to, Control Panel, click (Mouse) in the Hardware and Sound category. Go to, Device Settings, in the (Devices) block, click on, and Highlight; the item you want to (enable) this being the Pointer Device. Click the Enable button, just below. Be sure to (Click) on the Apply button, click OK. You may need to Update Drivers. Click on Hardware, click Properties, click, on Driver. If the, Update Driver (block) is not Grayed-out click Update Driver, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. I hope this Fix it. paul7of9
SOURCE: my touchpad scrolling doesn't work, what to do?
“Hi let’s see if we can fix this problem”
I. “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse”) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.”
III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver”, click (OK), this will ensure that the application take effect.
Hope this Fix it.
SOURCE: forgotten bios password on toshiba tecra a10. How
Hi
Just reset it, to do it just open the memory compartment and look for the bios battery number 2025 or 2016 and take it out the battery for 1 minute just to be sure it will reset. Just feel free to ask. Hope it may helps.
Regards,
kaybicks
SOURCE: Hi How can i remove
Depending upon the model of the Toshiba, you may be able to remove the BIOS password with this hardware device. Please click on this link and follow my instructions :-
Normal
0
http://www.fixya.com/support/r4350719-remove_toshiba_bios_password
