Question about Kenmore 74602 Gas Dryer
Dryer runs then stops.
My dryer starts running, and after 1 min. it stops.. .it is almost as if there is too much friction and the drum can not overcome it and forces the motor to stop...
  • 51 Answers
IF LESS THAN 10-YEARS OLD/CHECK THE TUMBLER BELT AND BAND.IF 10-YEARS+ REPLACE YOUR MOTOR OR BUY A NEW DRYER.***ALSO UNPLUG THE DRYER AND MAKE SURE ALL YOUR WIRES ARE TIGHT.
Posted on Jan 17, 2009
My whirlpool estate dryer just stopped running about 5 min after I started it. Checked outlet that is fine. Door switch fine. Timer ticks.
Is the inside of the drum very hot. My guess is over limit thermostat is reporting overheat. Check for lint build up in hoses or even birds nests.
Oct 03, 2015 | Whirlpool Dryers
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Oct 02, 2011 | Kenmore 63942 Dryer
Start button buzzes when pressed, dryer doesn't start.
I assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Apr 26, 2011 | GE DVL223EBWW Electric Dryer
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Mar 13, 2011 | Dryers
When the dryer starts it makes a quick grinding noise like it is having trouble starting. After only 1 second that noise goes away and the dryer appears to be working fine. It will stay running anywhere...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 09, 2011 | Whirlpool LER4634J Electric Dryer
The dyrer will not turn on. The dryer makes a humming noise but will not turn on.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Also, check the blower on the dryer to see if a article of clothing may have gotten stuck there and preventing the motor from running.
Jan 22, 2011 | Whirlpool Dryers
My gas dryer has started making a metallic screeching sound after its been running for a bit. Its coming from the rear of the dryer. I'm concerned that it might be the motor. It kind of comes and goes and...
Could have been that the alignment is out of way andis rubbing on when in a particular direction or with the load.
As you have observed the motor could be the issue , it will be good to open and look for the movement of the motor.
The suspensions can be a little out of alignment . also place the dryer in a level postion.
Check for uneven running due to any friction of the drive. If so it can agitate and make it rub on the sides.
Aug 31, 2010 | Dryers
Drum or blower will freeze up while tumbling
If it is an old dryer, or maybe you put a lot of clothes in it at a time, sounds like the friction pads are maybe worn. The drum is open on the front side and just has some teflon or plastic pads that the drum rides on. Maybe you are dealing with metal to metal, which doesn't slide too well. You can order those pads and replace them. Don't ignore this, check it out, because if it is metal to metal, that creates hot, glowing sparks, not good to have in your home.......
Jul 11, 2010 | Kenmore 64712 Electric Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Will run for about 1 min then stops
might be that the Drum is stuck, can you turn it by hand...it is possible that the drum has just got stuck, or maybe you have a drive belt problem . I hope this helps
Sep 27, 2007 | Amana DLE330RAW Electric Dryer
Kenmore 74602 Gas Dryer Logo
328 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
