Question about Mitsubishi WS-55859 55" Rear Projection Television
Mitsubishi ws 55807 have the blinking lights problem and not powering on
I appreciate your description on how to fix the DM board but the illustration is totally different to the mitsubishi ws 55807 rear projection. I desperately need your help on how to fix this power on issue.
  • asolor8067 Sep 25, 2008
    yes i have the same problem the blinking light and is not powering up. thanks
  • Anonymous Mar 29, 2014
    ws 55807
    President:
  • 3,130 Answers
Yes on some sets are a bit differant depending on the model number there is still a DM board. The disassembly is a bit different and the service manual will describe how to take apart the TV set to get to the DM board. The repair is the same for the DM board. I am sorry but I do not have the the service manual but one can be downloaded here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=WS55807 Good Luck
Posted on Jun 20, 2007
I have a Mitsubishi Ws-65511 65" and the green light on front panel blinks continuesly and the tv will not turn on with the power button or the reset button on the front panel. If we unplug the power cord...
The Bulb in the unit needs to be replaced. To confirm, look in the manual for the set and it will explain the flashing lights by the numer and duration of flashes. Hope this helps.
Jun 07, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi tv model ws-65315, when i turn the set on, the green light comes on for a second then the set turns off what could it be
Check the voltages at the test points on the power supply. If the voltages are correct and all the fuses are fine, check for swolen capacitors on the format and the DM boards and replace them
May 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green led light after power outage will not reset set is approx. 6 years old model mitsubishi w55511
had same problem with my tv.Technician told me to remoe front cover and unplug the 2 plugins going to the buttons then try the mistubishi remote to turn tv on.Did this and worked fine with remote.
Apr 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
Feb 19, 2009 | Mitsubishi WS-55807 TV
MITSUBISHI BLINKING GREEN LIGHT
replace the dmv pcb, replacing just the cap is a temp fix, that is if it works location number is c9624
Jan 11, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Dm board (power supply) for mitsubishi rear projection tv (ws-55807)
Good day,
mohiuddin;
If the indicator stays on then you may have an DM PCB problem and to correct this do the the folowing:
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 22, 2008 | Mitsubishi WS-55807 TV
I've got the blinking lights also. Model # WS-55613. Does anyone know what the problem is?
Dec 27, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55859 55" Rear Projection Television Logo
170 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
