Question about Canon CanoScan 8600F Flatbed Scanner
Canon 8600F does not scan.
When using either the toolbox or the buttons I, all of a sudden, get "Cannot scan Code 2178,0" . This happen after I have used the scanner for over two years. Plse help, I called Canon and they said there was something wrong with the hardware and suggested I try a service or purchase a new scanner - they gave me a Canon Loyalty number. I would rather see if this can be fixed. Thank you for answering.
  • 1 more comment
  • hirschle Jan 18, 2009
    Canon 8600F. When using either the toolbox or the buttons on scanner, all of a sudden, I get
    "Cannot scan Code 2178.0. This happened after using scanner for over two years. Called Canon and they said there was something wrong with the hardware. Suggested I try a service or purchase a new scanner.I would rather see if it can be fixed. One of your suggestion did not work. Please try again.
  • hirschle Jan 19, 2009
    Same problem after I recalibrate buttons.
    By the way it is the Canon scanner 8400F and not 8600F - sorry.
    Please help.
    8400F. Taran, I get into Scangear from having clicked on "copy", becase I checked the scanner driver. When in Scangear-advanced mode-image settings-calibration settings-execute at every scan: ON. Is it supposed to be ON or OFF ?
    This is what I did to calibrate but still 2178.0. My lamp is on but no sound comes from it.
    Pls help. Alex
  • 4,889 Answers
I am Assuming you have tried what others have suggested ..Canon has a diagnostic tool embedded into the scansoft omnipage. I would suggest that you run it. It runs a series of tests and automatically fixes any glitches. Just run every test and don't skip anything. I own a canon scanner myself and this worked for me more often than not. Try it and let me know if it worked.
Posted on Jan 20, 2009
  • 4,806 Answers
Hi there
Uninstall the scanners drivers and software, restart the PC and reinstall the scanner again. If there is a problem with the scanner itself this way of troubleshooting will verify it, lets hope its just a communication problem between the computer and the scanner.
Good luck and thanks for using Fixya
Posted on Jan 19, 2009
  • Canon Master
  • 19,396 Answers
Release the lock switch, detach the USB cable, and re-install drivers, starting driver installation with USB unplugged.
If standard drivers on Scanner CD do not work, install drivers from here:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
Driver Downloads
If still no luck, and you already checked lock switch and calibration, then this is an hardware fault, in that case you need to have it repaired or replaced.
Regards.
    President:
  • 1,990 Answers
Welcome to Fixya! Unplug all the Cables and Power from the Printer. Uninstall and Reinstall your Printer Software. Restart your PC. Plug cables and Power Back in. Run your Software. Run Setup and it should be good.
  • 916 Answers
Go to the "settings" section in Scangear and click on calibration.
  • machadojr_fe Jan 19, 2009
    This information was found here
    Use the scangear advanced version
    Genius:
  • 1,011 Answers
Sir,
I think the problem is related to main board. This can't fix by yourself so, better contact the canon for replacement.
Also check the software it is updated one. Try to reinstall the software and system motherboard driver. Better reinstall the OS. Update the OS also helps....
Tips:
Scanning is only performed through a computer and not with the printer alone.
Thanks
good luck
Posted on Jan 18, 2009
    President:
  • 1,257 Answers
After much tinkering today trying to reinstall drivers about 100 times I think I found the answer:
I hadn't used my Canon 8000F for scanning slides/film for quite a few months, but had been using it for regular platen use. I got the 2,178,0 error. I found to get past it was to go to the "settings" section in Scangear (advanced version) and to click on the calibration. The top bulb in my scanner burst into light again and the scanner calibrated itself. After this I could scan slide/film!
    Sergeant:
    Scholar:
  • 199 Answers
Its a problem with the scanner assembly .may be because it is bit misaligned or the moving belt is faulty.
  • 153 Answers
The closing door of scanner has a button somewhere benith check if the button is alright
  • 10,515 Answers
Though this is an issue with most of the cannon scanner's...
And i am not sure why the cannon executive told u to replace on the basis of this error...
Its a combination of 3 error codes 2,178,0.
now ,
Read the below link, though its is for a diff. scanner but it wld wrk for the 8600 as well
http://photo.net/filters-bags-tripods-accessories-forum/00DhH8
Thanks.
  • 565 Answers
Go settings and use the calibration in every scan so the error dont shows up
    President:
  • 2,110 Answers
On the top of the slide holder is an empty space seperate from the 2x2 spaces. make sure that space is clear of anything. this is how the scanner figures out what its doing.
other than that I have no idea., had mine 2 months and haven't had a problem.
try a simple level scan in the toolbox and see if it works
CODE 162,0,0 ON CANON D1350
This happens across the range of Canon Printers. The fix is to push the right button! Yeh I have a differing model, but the answer is the same. Go to the printer and select remote scan. Then invoke computer program. Some one has to be boss either the printer or the computer for scanning.
I can make the scanner printer the boss and issue a TIFF scan to the computer. Just push scan on the printer and select computer (it does a push data)
I can make the computer the boss by selecting the steps below:
Please choose what option you require. Ignore the model number.
The error codes 162,0,0, or 255,0,0, usually indicate that you have not selected a scan type at the machine. Please follow the steps below to perform a scan from the image I-SENSYS MF8230Cn:
Verify that MF Toolbox is closed on the computer and press the [SCAN] button on the printer.
Highlight [Remote Scanner] and press [OK]. The screen will show, "Remote Scanner. Waiting online...".
On the computer, open the MF Toolbox and select [PDF].
Click the green [START] button on the [PDF] window. The machine will start processing the scan.
If you receive any errors or need further assistance with the I-SENSYS MF8230Cn, we recommend that you contact us at 1-800-OK-CANON (1-800-652-2666).
Sep 29, 2014 | Canon imageCLASS D1350
Scan from in to Microsoft Word
To be able to do that without problems you have to have installed the whole program for the scanner..I mean the driver and the software to manage it ..This can be downloaded from canon support site in case you do not have it on a disk ...or in the computer ..
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_8600f#DriversAndSoftware
here is the link where you can download the canoscan toolbox..which is teh software I was talking about ..
So , the procedure is to initiate the scanning from the toolbox in the computer ..and during the wizard ..select the preferences to scan document ..and not photo ..This will probably give you the possibility to select the program to be scanned into ..or will scan in word by default..remember to select the option to scan document ..and not picture..otherwise will scan as a photo and will end up with a jpeg of gif file ..
Please do not hesitate to ask more questions in a comment if you have something you did not understood..and please rate my answer cause it affects my work here ..
Oct 31, 2011 | Canon CanoScan 8600F Flatbed Scanner
HI, I just purchased a Canon LiDE 110 scanner. After installing the software I did a test scan. The scanner scanned the image then a window popped up that says Canon MP Navigator EX has stopped working,...
1. Open up Image Capture
2. Go to Preferences and click the option under "Scanner" that says "When Image Capture is launched, open scanner window"
3. Then in the Scanner window, click on the "Options..." button
4. Then click on "Buttons"
5. Make sure "CanoScan Toolbox 5.0" is specified for "Application to launch when scanner button is pressed" I did all this and what (incorrectly was always happening when I pressed any button on the scanner was that Image Capture started up (along with the Scanner window), and that was it. What was supposed to happen was CanoScan Toolbox was supposed to launch and initiate the action associated with the button. Here's how I fixed it: 1. Followed the instructions in the 1/2/2008 posting here, (I think he means Jan 9th Canon install tips, which several other Canon users found useful.-Mike) uninstalling both the driver and toolbox (including any of their pref files I could find, emptying trash, and restarting as specified) and then reinstalled the toolbox first then the driver. 2. At first I didn't do the "Save" step (open toolbox, and then click the "Save" icon) and the behavior of the buttons was unchanged (and incorrect). 3. Then I did the "Save" step, but only clicked on "Apply" on the dialog box that then pops up. The behavior was still unchanged (and correct). 4. then I did the "save" step again, but this time followed it through until the end, clicking on the "Save" button in the dialog box and letting it save the scanned image in a file. This time, the buttons worked as they are supposed to!!! Hitting any of the buttons launched Toolbox and performed the correct actions associated with the buttons. In fact, it worked better than the Canon tech support people told me it would work. They told me that only the 3 right-most buttons work with a Mac and the 4 left-most buttons would only work with Windows. I've found that all the buttons work. However, Toolbox doesn't seem to reflect the mappings of the 4 right-most buttons in its user interface (and doesn't let you change the mappings, like you can for the 3 right-most buttons). Anyways, in summary, the key for me was doing the "Save" step, but doing it completely (by letting it save a file). I don't think this was clear from the other comments. Hopefully this info will help someone else.
Jul 06, 2011 | Office Equipment & Supplies
I have a CanoScan 8600F. When I want to scan I get the not enough space on the target disk
This seems to happen quite often with the Canon scanners. If you know you have enough space on your hard drive, open the CanoScan Toolbox, then click on Settings and change the folder where the temporary files are stored to another folder of your choice, or create a new one in your documents.
Dec 06, 2010 | Canon CanoScan 8600F Flatbed Scanner
Re: Canon 8600f scanner. How do I get this to file in jpg rather than pdf? How do I control scanned picture size? I get a full page (8.5" x 11.0") with a real size scan on top. Peter
My cannon 8600F was ori=ginally connected to my old laptop & I could scan any document and save as a jpeg file. This was with Windows XP Prof.
Mow my new laptop has Windows 7 & I downloaded Primo from the web. But now I am not able to scan a picture and save as Jpeg file.
Please help.
Aug 07, 2010 | Canon CanoScan 8600F Flatbed Scanner
Won't scan - says not enough disk space.
I had the same problem. Solved it by going into the "CanoScan Toolbox" - "Settings" - and pressing the "Defaults" button in that panel - and then "OK" button. Afterwards everything worked fine. Hope this helps you.
Dec 18, 2008 | Canon CanoScan 8600F Flatbed Scanner
CanoScan LiDE 50, error code:2,7,0
When you say the error occurs as soon as you press "Scan", is that the button on the scanner, or is it the Scan button inside of Toolbox or ScanGear?
If it is the one on the scanner, try accessing the driver through an application such as Toolbox. If you didn't download that when you got the driver, then go back to the Canon download page and download & install the CanoScan Toolbox. Once that's installed, lauch Toolbox from Start|All Programs|Canon|....look for Toolbox from here. Once you have Toolbox open, click the 'Save' option. Next, check the box that indicates to Use the scanner driver. Click the Scan button at the bottom. This should open ScanGear. Attempt to Preview scan.
May 11, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Will not scan photos, only slides
Where are you scanning from? Do you get an error? If scanning from Toolbox, check the box that says to use ScanGear or use the Scanner driver. Then make sure it is not set for Film as the select source.
May 05, 2008 | Canon CanoScan 8600F Flatbed Scanner
Cannot scan film and slides
Check the cable that connects to the lid of the scanner. If it is disconnected, you won't get the Film options.
Jan 21, 2008 | Canon CanoScan 8600F Flatbed Scanner
Canon CanoScan  8600F Flatbed Scanner Logo
273 people viewed this question
old marine
old marine
