Question about Sony Handycam DCR-TRV900 Mini DV Digital Camcorder
Auidio drops I was taping my cousins wedding of all things when my audio began to drop out at irregular intervals. The actual video contains no video indications of bad digital information (pixilated frames etc), but the audio track contains quick glitches of silence. These drops began to occur after a few months without using the camera. The audio drops out both when using the camera mic and when using an auxiliary mic. Do these cameras have a history of bad audio connections? Is this a hardware problem? Is it possible to fix on my own?
    Champion:
  • 287 Answers
While your monitoring the sound when recording it cuts out or while you playback the tape it dropps out? if it's noticed during playback it's one 3 things. the heads are dirty, the tape tension is low or the heads are bad. send it to video tech service in sacramento. that guy is super cool.
Posted on Sep 18, 2007
SOURCE:
My cousin dropped my controller several times and before that it was working and now that he has dropped it it wont cut on anymore
Try taping the batteries in place before putting the cover on and disabling the vibration in the controller.
May 31, 2011 | Microsoft Xbox 360 Controller
My tapes that are approx 2 years old playback really wierd. The sound drops in and out every 1 or 2 seconds and the image looks stable then goes fuzzy for the same amount of time. My honeymoon and wedding...
This is usually caused by an oxidized ,misaligned or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
Aug 13, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
Audio drops out every few sec.(3 sec.) then ok for about 5 sec. it seams as i shake camcorder lightly side to sides the intervals changes too +1 -1. i have red here problem as tape misalignment which is...
Thats a possibility. I don't know why it costs so much since all you have to to is take a small screw driver and adjust the audio head. You might try cleaning it with a DV tape cleaner and see if that makes a difference. It's cheaper than the repair shop.
Jun 24, 2008 | Sony DCR-VX2000 Mini DV Digital Camcorder
Dropped my camcorder
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Feb 11, 2008 | Video Cameras
Luxman DAT Recording problems
If the tapes you are using are "tight" it may be causing both the drop out and rew problems. Always a good idea when you buy fresh recording media to ff then threw it through to ensure that the tape is layered flat. they can tighten up in transit sometimes in shipping from manufacture. The unit will need some service work done also. A head clean could also help with the drop out. Use a Chamois tipped head cleaning tool to do thisusing iso alchol only AND A VERY GENTLE APPROACH. The drum heads themselves are very small and VERY FRAGILE!! Easily broken if you do not clean the correctly. Take it to a vcr/video camera tech for a clean and service of the tape path.
Jan 29, 2008 | Audio Players & Recorders
Plez help
Never store your tapes or camcorder near anything magnetic. Sounds like it could be a dirty tape head (the one that reads the tape) or a loose connection with the wires. Try a different cable first if you can, then go on to cleaning the tape head with a Q-tip and 99% alcohol. The tape head is located on the shiny round metal thing that the tape runs on. Questions? Don't hesitate to ask. Your tape should be fine as long as it wasn't near a magnet.
Oct 28, 2007 | Video Cameras
Audio dropout
take it or ship it to video tech service. they will clear it and go from there. it may need some tension adustments in addition. The guy there is super cool.
Aug 18, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Sony Handycam DCR-TRV900 Mini DV Digital Camcorder Logo
436 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
