Question about Toshiba 53HX71 53" Rear Projection HDTV-Ready Television
Remote don"t work
The problem i have. the remotes does"t work. i know the remote itself works.the problem happen when the speaker wires and the remote wire got turn around.any help would be appreciated. thank you/
  • cjackson14 Jan 17, 2009
    it all started with a conversions problem. we replaced the vertical IC, which fixed the conversion... now the remotes don't work
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Most of these sets have the remote sensor located either on the front keyboard or inside the set(behind the screen) If the keyboard has the sensor check to make sure none of the wires got ripped out of the plug that goes there---if it is behind the screen it will be located in front and above the three large lens on a tiny circuit board--follow the wires from that and make sure the plug where they connect to the main board is not pulled out or off. If the wires got pulled out of the plug someone is going to have to repair them or replace the unit---most of the time it can be fixed.
The more information you give me the better the chance that I can help you.
Reply here if you have questions
SD TECH
Posted on Sep 04, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
There are some tests that you can do to verify the functioning of the remote. If you view the transmitting end of the remote with a camcorder, or mobile phone camera, you should be able to observe light coming from it when you press a button. Cameras are able to pickup the infrared light(not seen by the naked eye) that the remote uses to transmit its signal to the TV, you will see the flashing of the infrared LED if it is working. This will verify that the remote is at least transmitting something.
Posted on Jan 17, 2009
  • 2 more comments
  • Rylee Smith
    Rylee Smith Jan 17, 2009
    If nothing appears to be transmitted by the remote, and you feel up to a relatively straight forward repair, I can guide you through steps to fix the remote. If it does appear to be transmitting, then I would suspect the receiving end at the TV is the problem. To be sure the remote is not confused, remove the batteries for 10 mins and try again.
  • Rylee Smith
    Ask for any clarifications.
  • Rylee Smith
    And, if it doesn't work the you can purchase a factory replacement from Toshiba parts (at a hefty price) or you can buy a universal from the department or electronic stores that will do the trick - they run $5 to $10.
    Just make sure it has the menu and a/v select feature on the remote and it should have all the capability that you need.(When you buy it online thet will tell you whether it is compatible with your tv or not)
    Thanks
    Rylee
  • Rylee Smith
    Have you tried cleaning the contact pad? Just open the remote, and you will find the contact pad. it is like a rubber sheet with contact terminals matching the locations of the various buttons.Just take a clean cloth and clean the contact points.
    Re-assemble the remote, put in new batteries. And it should work now.
    Genius:
  • 1,199 Answers
I would recheck the wires that got switched first and make sure they are right!
Only two front speakers are working
http://safemanuals.com/user-guide-instructions-owner-manual/AKAI/CD3000XL-_E owners maual ......... you need to change the settings on it for suround sound
Oct 21, 2008 | Akai DHT300 System
Lost remote trying to use a universal remote made by rca need a code to get it to work
I would be more than happy to find a remote code for you, but I must first know what type of remote control you have. You said it was made by RCA, do you know the model number or name of this remote? It is usually listed on the packaging the remote came in, or possibly on the remote itself. I would also need to know the type of television you have, but simply the name of the manufacturer should be fine.
In the meantime, check out this website:
http://www.thompsontv.com/rcarc.html
I don't know that this guide will work for your remote, but it can't hurt to try.
If you can get more information about your remote/TV, I can provide more help.
Jul 18, 2011 | Televison & Video
I have connected the hand held remote control to me Celestron NexStar 80GTL and nothing happens. The remote will not power up. Don't know if the problem lies with the remote or is a more major...
Are the batteries fresh? You can also try a new hand controller cable maybe the one you have is broken which is a common problem.
Beyond that you can try to borrow another hand controller and try it. If none of these work, then you have a blown circuit inside the telescope. It will need to be returned to Celestron for repairs.
May 27, 2011 | Celestron NexStar 4 SE Telescope
2007 TOYOTA SOLARA DASH LIGHTS SHUT OFF WHEN CAR IS IN DRIVE .
Don,t know why this problem happens....but to get the dash working again remove the dash cluster. There are two white plugs in back of the cluster. In the larger of the two which is dead center on top of the cluster, cut the wire which is in pin #2. It will either be a black/white for the convertibles or a black for all others. It will be next to a white/red wire. Just tape off each end then tape up the harness. No connections are made. Don' t know why this works but it does. Problem seems to happen when remote starts are installed.
Jun 29, 2010 | 2007 Toyota Solara
Logitech Z-5300 Turns off and on by itself
Hi...
Im not sure if this will help u but check ur Remote's power botton.
Maybe its stuck?
It happened to me before... Was wondering y it turns itself on/off and found out later that the power botton on remote is stuck.
U should hear the clicking sound everytime u turn it on or off.
Otherwise... something else is wrong with the power switch on ur remote.
-Vash_Stepler
Sep 19, 2009 | Logitech Z-5300 Computer Speakers
My remote just stopped working on my technosinic home theatre. any way to reset the system?
Check if it is a remote problem or not:
-Using a digital camera you should see white vibrating light comming from the remote if it is OK.
- If nothing happens, remote problem.
1st: Change batteries.
2nd: Try to find a similar or universal remote for test. If your system is OK with this remote, your remote faulty. Take apart, probably some hit/drop broke the PCB inside.
- If you see white light through your camera, your device has some problem.
1st Check if your device is working (can operate with buttons/knobs in the device itself)
2nd Try in darker day period (no direct sunlight) and go close to the reciver.
Aug 28, 2009 | Audio Players & Recorders
LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Jun 24, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Wired remote control not working
You probably had the wire get pinched.  If it's not too hard, it might be a good idea to check your wire.  Otherwise it probably is a problem with the jacks on either end.  Things get screwed up in accidents.
May 29, 2007 | Infinity BASSLINK Car Subwoofer
Toshiba 53HX71 53" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
