Question about Kenmore 15212 Mechanical Sewing Machine
Difficulty sewing quilt blocks
When sewing two layers of material with batting between, my machine seems to push the top layer of material ahead of the bottom layer. I've tried adjusting the tension, width and stitch length and I can't seem to fix the problem. Thanks for any help.
Try using a "walking foot" presser foot. It has feed dogs on the top to help all the layers go through evenly. A generic brand usually fits most all machines. :)
Posted on Oct 24, 2012
  • 22 Answers
This is because the feed dogs grab and carry the bottom layer, the top layers glide along.  There are several solutions. #1  pinning, pinning, more pinning #2 support the layers by holding the piece in front of the machine with one hand and behind the machine with the other hand.  if you're left handed and try to do this, bless your heart, it's tough #3 use a walking foot or a roller foot or an even feed, depending on your machine #4 it is possible to reduce the tension on the presser foot while you work on this piece.  just remember to put it back before you start to sew on the next project!
there are more tricks but this should get you started.  Happy Stitching!
Posted on Jan 17, 2009
HV sapphire 930 not feeding properly
When stitching together a quilt sandwich, it is recommended to use a walking foot on your machine. The walking foot moves the upper fabric in conjunction with the feed dogs. Sometimes, if the quilt sandwich is not too thick, a roller foot can also help but may not be sufficient for a quilt sandwich.
What is Walking Foot Sewing Tips for Beginners
How To Use Walking Foot
How to Use Roller Foot
You may also check the presser foot pressure on your machine. This regulates the amount of pressure the presser foot applies to the fabric and the feed dogs. If the pressure is too strong, it will tend to push the upper layers of fabric, creating a bubble look. If the pressure is too loose, there is not enough pressure for the feed dogs to physically pull entire quilt sandwich under the presser foot.
(The pressure is adjustable depending on the types of fabric and thicknesses being sewn.)
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
http://makeitsew.biz/presser-foot-pressure
Oct 01, 2016 | Sewing Machines
Why do stitches bunch when using walking foot on 3 layers of quilting fabric?
make sure that the thread tensions are correct for the thickness of material
remember that only the bottom foot walks and draws the material through so it may need a help and be pulled as it sews.
I find that women in sewing shops just love to talk about problems and how they can help so find a shop and discuss any problems with them
May 08, 2015 | Brother PC420-PRW Project Runway...
Having trouble missing stitches while quilting with walking foot.
Might try changing the needle. Try a top stitching needle. Sometimes needles bend slightly piercing 2 or 3 layers of fabric plus batting, so using a larger, sharp needle penetrates better.
Mar 07, 2015 | Sewing Machines
The walking foot is too aggressive on material, causing it to claw rather than pull through nicely.
Walking foot may not work well on thin material or normal sewing, it is meant for quilting and is applied on several layers of material.
Oct 15, 2013 | Reliable 2000U-33 Mechanical Sewing...
My zig zag stitch is puckering fabric. I even went to the multiple zig zag, same problem. I decreased tension. What should I have double. Note: this was on single layer, along edge of fabric so I could...
Check the bobbin tension too. It could be too tight. Make sure you are using the right size needle for the material as well. Sheer, thin fabric needs a smaller needle, thicker material requires bigger needles. Bobbin tension is the typical problem as most think to adjust the top tension but don't check the bobbin tension.
Is your quilt peices cotton? Cotton shouldn't cause as much trouble sewing along the edge but don't use too long of a stitch length else it will seem to gather up. Puckering side to side however is a tension problem usually. With sheerer fabrics that cause a problem sometimes you can put thin paper underneath, sew through both and then pull the paper off after sewing. (thin like the iron on type interfacing type fabric but like paper).
Mar 25, 2011 | Janome Sewing Machines
Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Oct 14, 2009 | Husqvarna Huskylock Computerized 905
I have a White 955 machine and I am trying to quilt with it. It works just fine when I am sewing just one piece of material to another but when I want to sew the layers of the quilt together the stitches...
I know this is strange, but make sure the pressure foot is down. When I quilt sometimes, after getting the bulk under the needle, I forget to put the pressure foot down or it get's knocked back up by the quilt and causes the same problem. Good luck.
Jan 04, 2009 | White Sewing 955 Mechanical Sewing Machine
Machine does not cut more than one layer at a time
The upper blade most likely needs to be replaced or sharpened.
Sep 16, 2008 | Brother 1034D Mechanical Sewing Machine
Brother sewing machine
Sounds like the feed is your problem. Most likely you need a different foot. Check the bottom of the foot - it should be quite smooth to allow the dog feed to move the denser layers along smoothly. Hope this helps.
Feb 07, 2008 | Sewing Machines
Kenmore 15212 Mechanical Sewing Machine Logo
197 people viewed this question
Top Kenmore Sewing Machines Experts
Bargain Box
Bargain Box
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
