Question about HP 2175 All-In-One InkJet Printer
PROBLEM WITH 2175 HP ALL IN ONE
THE PROBLEM I AM HAVING IS THAT I PLUGGED MY HP BACK IN AND HAVE HAD CLUNKING NOISE ALL THE TIME IT WONT DO ANYTHING I HAVE PRESSED SEVERAL BUTTONS BUT NOTHING WORKS CAN ANYONE HELP?
  • davidh1 Jan 25, 2008
    When I turn the printer on, it starts to self test, but then the scanner light seems to get stuck and it just makes this clunking noise like it's going back and forth. Sometimes if I turn it off and then on again it seems to fix itself, othertimes it doesn't. I wish I had a video camera to show you the problem! The OTHER problem is that I'll put things in the print que and they won't print. I called Hewlett Packard and they walked me through solutions, unplugging the printer, starting it up again, but nothing helped. Their final solution was for me to buy a new printer. It seems like such a waste. This printer isn't that old. Can anyone help me??? Thanks!
    Scholar:
  • 35 Answers
Sounds like your encoder strip is out of alignment. The encoder strip is a thin clear plastic strip that runs along the back side of the print head. It feeds information to the print head during the print process. If it it out of alignment or is missing, the printer will make a violent clunking noise during startup and will fail its self test. If it is out of alignment and still mounted, push back on it with your thumbs, then push down gently. Finally, pull it toward you with your index fingers and up into the groove behind the print heads. If the encoder strip is unmounted or totally removed from the printer, check it for damage. If there is so much as a bend or kink in it, it will have to be replaced. New strips can be purchased from HP for around $60. You will have to determine whether it is cost effective to replace the strip or replace the printer. Now if it is undamaged, you can remount it. There is a hook on each side of the print track where the strip hooks into. Be careful because the strip will not hook in easily because once you get one side hooked in, it is difficult to keep it hooked in while you connect the other side. Once you get both sides hooked in, align it as stated above. Hope this helps. Good luck.
Posted on Jun 20, 2007
SOURCE:
Hp pinter 2175 noise
open the back cover and re insert it.
Aug 28, 2012 | HP PSC 2175 All-In-One InkJet Printer
I hear a clunking noise each time i run over a bump in the rear end of my car.
Well if your spare is in its place got and tight and you don't have anything in your trunk that could make the clunking noise it sounds like your rear struts need to be chaanged,well at least one if you know what side the noise is coming from and it is better to change both at the same time and when you have the struts changed figure in a four way alignment.When you align the back most alignment machines are set up to do only front or all four not just the back.That way you don't wear out your rear tires prematurely.
Apr 19, 2010 | 2004 Toyota Camry
HP PSC 2175 Printer reverts to "default printer" on PC re-boot
click on start ---settings----printer and faxes now from here u can make a default printer just right click on the icon of that print which u want to use and set it as a default print. or if u just want to revert back the current one just uncheck the option by right clicking on the icon
Oct 23, 2009 | HP PSC 2175 All-In-One InkJet Printer
When turning steering wheel - either way, clunking sound.
Sounds like you have a bad CV joint, this will make a clunking or clicking noise like you described only when turning, and varies with vehicle speed.
Have it repaired before it breaks and leaves you stranded, or damages anything else.
Apr 02, 2009 | 2002 Cadillac Deville
HP 2175 Printer won't align new ink cartridges.
press 'setup' and 'options' buttons at same time to overide
Mar 19, 2009 | HP PSC 2175 All-In-One InkJet Printer
Printer flashes self test
GO ON LINE AND TYPE THE FOLLOWINF INFORMATION IN THE ADDRESS BAR:
HP PSC 2175 ALL-IN-ONE INKJET PRINTER FLASHS SELF TEST MODE OVER AND OVER
ENTER
SEE IF ANYONE ELSE HAS EVERY SEEN THIS PROBLEM BEFORE
Mar 07, 2009 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2175 All-In-One Will not print anything
Try this HP utility which solved my problem...it works for vista and has a link for XP users too
Print Jobs are Stuck in the Print Queue and Will Not Print with a USB Connected Printer in Windows Vista
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00843712&lc=en&dlc=en&cc=us&lang=en&rule=23624&product=90809
Oct 24, 2008 | HP PSC 2175 All-In-One InkJet Printer
Scanner wont intialize
probably the scanner can't determine his position because of a "dirty" scannerglass. How you can clean the glass is explained on te hp site.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00553775&dlc=en&product=90809
Sep 03, 2008 | HP PSC 2175 All-In-One InkJet Printer
MY HP 2175 IS NOT WORKING
Someone might be able to help you. ask a question.
Aug 29, 2007 | HP PSC 2175 All-In-One InkJet Printer
Troublesome Printer
I'm sorry to say this, but with those symptoms it sounds like the power supply was slowly becoming defective which sometimes happens. This is also probable if the machine would work when first turned on and then quit after a few minutes. Heat builds up and components begin breaking down with more heat. Best bet is to take it to a repair shop.
May 19, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP 2175 All-In-One InkJet Printer Logo
130 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
