Question about GE Televison & Video
Need user manual for GE Universal Remote Control RC94930-h
Need a path to find this manual on line
    Problem Solver:
  • 18 Answers
Can't find the manual for my Iberna Upright Showcase. Model: GD350 and No. 201205. The temperature is much higher than it is meant to be and I can't adjust it.
a UK brand
probably discontinued
cant find a user manual on line for it
my guess is you need to replace the thermostat or the control pad
contact this company
http://www.partmaster.co.uk/iberna/fridge-freezer/catalogue.pl?shop=iberna&path=499408
Apr 30, 2016 | Freezers
Configuration settings PIN code
Try Hard Reset your Phone
or
Here's a hints on how to repair or fix Nokia 5800 XpressMusic Digi Mic Knopfler problem issues.
A guide picture below which I included an schematic diagram shows each every components and line paths for quick test and check up procedures.
Digi Mic Knopfler Pin configuration:
1. L/R - microphone's left and right audio signals groundings
2. CLK - Audio Clock data
3. Data - Digital Microphone data
4. VDD - Power supply voltage
http://2.bp.blogspot.com/_8JZhVVmpICU/TBnMEY2FYyI/AAAAAAAAAiI/KWb0ERKLIPE/s400/digi+mic+knopfler+schematic.jpg
Locate and trace each and every components, line paths and corresponding connection as shown on a picture. The red highlighted components and line paths is for the power supply voltage which came from Power management IC (AVILMAS) Vsim2- approximately 2-3 volts.
Test and check this components and track the supply voltage from C220 to C2170 then through the digi mic knopfler pin 4.
http://4.bp.blogspot.com/_8JZhVVmpICU/TBnNuXjiK5I/AAAAAAAAAiM/zRyjq5oSGEA/s400/nokia+5800+xpressmusic+digi+mic+knopfler.jpg
The pink highlighted components and line paths is for Audio Clock data signal, which is came from the Audio Codec IC (Avilmas) then flow across R2201 and R2170 (valued 100ohms each) then to the Digi mic knopfler pin number 2. Check also the C2173 valued 22p Clock filter capacitor for possible damaged.
I included step by step procedures on the images like as follows:
* Check each components and line paths.
* Replace if found open or shorted
* Jumper the line paths if found open or cut
* Check or replace the digi mic knopfler for a quickest step might as possible.
http://4.bp.blogspot.com/_8JZhVVmpICU/TBnUknz7xAI/AAAAAAAAAiQ/McXux--YsDc/s320/nokia+5800+xpressmusic+digi+mic+knopfler+repair+gu ides.jpg
The microphone's digital data signals has also a line paths connected to the front side of the Printed circuit board, check and trace also this line paths which is connected to digi mic knopfler's pin 4
Feb 17, 2011 | Nokia 5800 XpressMusic Smartphone
Replacement manuals and charger
You can download a PDF version of the manual and order a battery charger from http://www.kodak.com/global/en/service/products/ekn032921.jhtml?pq-path=11249/11251 for the M853 and http://www.kodak.com/global/en/service/products/ekn034144.jhtml?pq-path=11254 for the M883.
May 15, 2010 | Kodak EasyShare M853 Digital Camera
White stripe on right as if black toner needs
You probably got a piece of paper or something in the image path or the paper path. If it is a nice clean line it is more likely to be in the image path, if it is smudgy line it something may be scraping the toner off the paper before it gets to the fuser. Check the paper path.
Dec 26, 2009 | Dell 3010cn Laser Printer
Looking for a user guide and cd for kodakzi6 video camara
Hi
There is an on-line user guide at this link http://www.kodak.com/global/en/service/publications/urg00919toc.jhtml?pq-path=13245
You can download the software and drivers that are on the CD for free from this link.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=164/150&pq-locale=en_GB
If you wish to get the actual CD you will need to email Kodak directly to order the disk.
Many thanks for using FixYa.
Nov 20, 2009 | Kodak Cameras
Printing won't work.
Good day sir/maam, hi, when you test print it usually prints letters and no lines are printed. try first if the printer is setup to economy/draft or pictures, if lines are faded, the ink cartridges maybe dirty. manual cleaning is needed, the ink path starts from the ink cartridge to the cradle or carrier then to paper. so any dried ink that blocks the path can affect the printout. you can use warm water to loosen dried ink. remove the cartridges and cradle from the printer as you clean them.
Oct 27, 2009 | Office Equipment & Supplies
Will not start
you dont need a manual. you need competent troubleshooting knowledge.
do you have an ignition spark? if you do then it will fire up on WD40 or StartingFluid sprayed in the opened carb. if it does and you have a clean fuel supply flow. clean the carb paths.
If no ignition spark present, check wiring, meter the coil for possible open circuit,
Mar 11, 2009 | Garden
Need service manual for Canon DR 3080C Scanner
GO ON LINE AND TYPE INTHE FOLLING INFORMATION.
CANON DR 3080C SCANNER SERVICE MANAUL.
ONLINE TO CANON USA.COM
ROD
Feb 09, 2009 | Canon DR 3080C Path-Through Scanner
Fit text to path
Use Text--> Flow Text around object
Jun 04, 2008 | Corel Print Office
Humming noise thru my speakers
You are getting engine noise through your amplifier. To solve this problem you will need to install a filter in-line with the DC path, or install a voltage regulator in-line with the DC path.
Sep 08, 2007 | Phase Linear UPA424CS Car Audio Amplifier
Televison & Video Logo
3,679 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
