My Dell Dimensions Desktop is only 1 year and 1 month old. I tried to turn it on and the screen comes up and says 1.analog 2. analog placing in safe mode. At first I thought someone accidently put it in sleep mode and it wouldn't wake up. But, now I am having such problems with it. At this point I am using an old computer to get on line. I am running Windows Vista in the new one and have NEVER had a virus...please help me. Some "kid" at Circuit City said it was my mother board..just looking for an easy fix
    Problem Solver:
  • 15 Answers
Your video drive is not installed or is corupted. try bootimg in VGA Mode by pressing F8 When the computer boots or get an old monitor and connect it to your computer and install the Video driver. To download the drive go to dell .com and click dowload drivers and find your computer and dounload the video driver and install it then put your regular monitor back.
Posted on Jan 17, 2009
Message on monitor says " no analog signal".
If you are getting no post display on boot up (dell spash screen, and windows loading screen):
First step is to plug a different monitor into the computer. If this works you most likely have a bad monitor. If not then it is a hardware issue with the video card on the computer.
If you getting the post screen then you may have your resolution set to high, boot in safe mode (F8 on the key board right after the post screen) and chose safe mode. once windows comes up, right click the back ground and chose a lower resolution setting.
Hope this helps
Oct 17, 2011 | Dell OptiPlex GX620 PC Desktop
Inspiron 1520-before finishes loading desktop screen goes black..
if it works fine in safe mode you should try a system restore . most of the time a problem that gos away in safe mode is driver related . IE software don't think you have a hard ware issue. you can call dell if you do not have the disk . 1-866-751-6079 call this number it's dell's Spanish tech support number but this is the fastest way to reach a real person at dell . just ask them to speak English and they will.
May 12, 2010 | Dell Inspiron 1520 Motherboard
Windows xp screen appears on Dell dimension 3000 desktop. It tries to boot up but then the screen goes black and just sits there. How do I fix this? I need to just get my data files off.
When you first turn on your computer, start pressing the F8 key about once every 1/2 second until you get to the boot menu. From there, select "Safe Mode" or "Safe Mode with Networking" (if you want to transfer files via network connection). The rest should be pretty self explanatory.
-Dan
Cartier Consulting, LLC
Mar 15, 2010 | Dell Dimension 3000 PC Desktop
My dell diminsion 8300 will not turn on a flat screen monitor only turns on a old analog crt
could be the moniter has packed in try a freinds one and if it works its the moniter if it doesint then you need a new gfx card
Mar 12, 2010 | Dell Dimension 8300 PC Desktop
Screen flashes on for around 1-2 seconds before turning off
Your TV has a defective component on the power supply section. Need service by electronics technician.
Jul 27, 2009 | Computers & Internet
Goes On ..Then Goes Black Screen I have 2 GX280s. One failed the other day after 2 years use. The BIOS screen appeared then it all went black. About every 10th attempt to get it going, it works and boots...
have you tried booting in safe mode? When it starts press F8 and select "Safe Mode" or "Last Known Good Configuration.". On that 10th try you do get it to come up make sure you install all updates for your computer. Then you can put int he Optiplex disk from Dell and run some diagnostics.
May 28, 2009 | Dell OptiPlex GX280 PC Desktop
Dell E228WFP two months out of warranty -monitor on and off
if your purchase just the monitor on 2/28/200, normally dell gives 3 years warranty for the monitor If purchased Separately.
OK.. try doing this call Dell.. 18004563355.. JUST give them the serial number of the monitor ONLY they'll check it out then if your lucky they'll send you a replacement.
Apr 23, 2009 | Dell E228WFP LCD Monitor
Desktop screen won't stay on
how old is your screen, if its older than 2-3 years mostly its gone and you need to replace it. If its in warranty then contact dell customer support. Life of screen can be around 3 years after that i may not work.
Another test is to connect it to some other computer and see if its working, then we can focus on some output issue from the CPU.
Apr 15, 2009 | Dell Dimension 2400 PC Desktop
Inoperative monitor
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
http://support.us.dell.com/support/edocs/monitors/1703fps/en/controls.htm
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Sep 29, 2008 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Gateway FPD1960 TFT works with laptop, not desktop
Elbtax,
Click start > right click on "My Computer" > Properties > Hardware tab > Device Manager button > Display adapters > Right click on your device and select uninstall and re boot your computer. Windows should pick up your adapter and re configure it automatically. This method should Fixya!
Good luck, and let us know how it goes.
Mar 18, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
