Question about Microsoft Xbox 360 Console
Xbox 360 won't recgnize controllers
Have tried to get it to work using the correct sequence of buttons but it will not recognize the controllers, I sent the orginal xbox360 back because of red light issues and they sent me a replacement, this unit will not recognize my controllers. Thanx -doug
If it will recognise wired controlers but not wireless controlers then there might be a problem with the wireless chip inside the xbox my advice is to send it back to microsoft and ask for another or ask for your money back and go to game, gamestation, hmv,somewhere like that
Posted on Jan 17, 2009
Walmart controller not working on my pc
Set up a wired controller
Step 1: Install the Xbox 360 controller for Windows software
Use the installation CD that came with your Xbox 360 controller for Windows before you connect the controller for Windows to your computer:
  1. Insert the installation disc in the CD or DVD drive of your computer. If the Setup program does not automatically start, change to your CD or DVD drive and run the setup program.
  2. On the setup screen, click Install.
  3. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
If you don't have an installation disc for your Xbox 360 controller for Windows, you can download and install the software online:
  1. Go to the Software Downloads section of the Microsoft Hardware website.
  2. Select Gaming as the product type.
  3. Select Xbox 360 Controller for Windows as the product.
  4. Select the version of Microsoft Windows you are using on your computer, select your operating system language, and then click Download.
  5. Click Run.
  6. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
Step 2: Connect the controller to your computer
After you install the software, plug your Xbox 360 wired controller's USB connector into a USB 2.0 port on your computer.
Step 3: Test the controller
To test your Xbox 360 wired controller on your computer, follow these steps:
  1. On your computer, click Start, type Run, type joy.cpl, and then press ENTER.
  2. Select Xbox 360 Controller, and then click Properties.
  3. Test your Xbox 360 wired controller by pressing a button, pulling a trigger, or moving a stick on the controller. If the controller is functioning correctly, you will see the corresponding action light up in the application. If the application does not recognize your controller, see Troubleshoot your Xbox 360 controller for Windows.
Jan 06, 2014 | Microsoft Xbox 360 Controller
My left analog stick button won't work on my Xbox 360.
Try using the stick on the Xbox Dashboard. If this doesn't work, you need to use a different controller or attempt to repair your controller.
Jan 21, 2013 | Microsoft Xbox 360 Console
My xbox 360 will not sync with any controllers besides the one controller I've already had synced. I haven't had any problems with it until recently, and now it seems like the xbox won't...
If you have an xbox slim model then there is a button above the USB slots at the bottom. Press Start and Back on the controller until the center button lights up. Then press the button above the two USB solts and hold it for a couple secs.
If you have n old xbox there should be a simliar button some where.
Also if you bought one of the charging packs for the controller, use the cord that came with it.
Thank you for your time, Good luck and I hope it works.
Jun 05, 2011 | Microsoft Xbox 360 Console
I have a brand new controller which came with my new xbox 360 and i have put the batteries in the correct way as instructed but when i press the xbox guide button nothing happens. I have also tried to sync...
The guide button won't work until its synced,you need to push the button on the console to look for controllers then the button on the controller and it will sync it and then it should work fine. If that doesn't work then try hitting the button on the controller first then the one on the console.
May 18, 2011 | Microsoft Xbox 360 Controller
My xbox 360 will not let me play my games
If your Xbox 360 console can't play multiple game discs, try clearing your system cache. Here's how:On the console, go to My Xbox, and then select System Settings.Select Memory. Highlight any storage device, and then press Y on your controller.Select Clear System Cache. If Clear System Cache is not available, use the button sequence described in the following article:971755 How to clear the Xbox 360 console cache Try to play a game disc.
Dec 22, 2010 | Microsoft Xbox 360 Console
How do i fix the open tray problem on an xbox 360--it won't recognize discs
Clear the system cache:
1. On the console, go to My Xbox, and then select System Settings.
2. Select Memory.
3. Highlight any storage device, and then press Y on your controller.
4. Select Clear System Cache. If Clear System Cache is not available, use the following controller button sequence to clear the system cache: X, X, left bumper,right bumper, X, X Note If you don't see a system maintenance prompt on the screen, try pressing the button sequence again.
Try playing discs without the hard drive in:
1. Turn off your console.
2. Locate the hard drive on your console.
Press the release button on the hard drive and lift the hard drive from the console.
Turn on your console.
3. Try to play a game disc.
If this resolves the problem, you will need to replace the hard drive.If not, do the same thing for your memory units. If it works without them,they may be bad.
Thank you !!
Jul 05, 2010 | Microsoft Xbox 360 Console
My xbox will not recognize that i have a disc in the trey. ive tryed standing the xbox on its side but that didnt help.
I know this can be very frustrating. Here are some things you can try:
  2. Select Memory.
If not, do the same thing for your memory units. If it works without them, the they may be bad.
Let me know the results, and if I can be of further assistance.
Apr 01, 2010 | Microsoft Xbox 360 Console
Consul will not recognize games
This means that there is a problem with the lens on the disc tray. here are the steps you need to try
1. Select memory -> Select Y button for device options then press the following sequence on your controller
X,X Left Bumper, Right Bumper, X,X
You will see a message that goes like this " This will perform maintenance on your xbox 360 storage device, would you like to continue? Select Yes
2. If this steps doesnt work and still continue to get the message " OPEN TRAY"
3. Call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty ( 1-800-4MY-XBOX )
Apr 03, 2009 | Microsoft Xbox 360 Elite Console
Wireless controller position
Try this:
Under heading "How can I change the screen positions for my wireless controllers?"
http://www.xbox.com/en-US/support/systemuse/xbox360/resources/supportfaq.htm
To reset the screen configuration for an Xbox 360 Wireless Controller:
  1. Turn off your Xbox 360 console and any connected Xbox 360 wireless controllers.
    (To turn off your wireless controller, power down the system and wait for the lights around the controller's Xbox Guide button to disappear.)
  2. Manually turn on your Xbox 360—don't use your controller's Xbox Guide button.
  3. Press the connect button on the front of your console. This is the small button just to the right of (or below, if your console is on its side) the port for Memory Unit B. The lights around the console's power button will flash as the console searches for a wireless controller.
  4. Press and hold the Xbox Guide button to turn on the wireless controller that you want to assign to slot one.
  5. Once the controller is on and the lights are still circling the power button on the console, press your controller's connect button, located just to the right of the charge port.
    When the lights on your controller stop spinning, the wireless controller is configured to slot one and the upper-left quadrant light will glow.
  6. Select the controller you want in slot two and repeat steps 4 and 5. You can configure up to four wireless controllers.
Sep 01, 2008 | Microsoft Xbox 360 Controller
Xbox 360 won't recognize my controller!
If your controller is just blinking you must press the small button on your xbox and at the same time press the small button on the back of your xbox controller and the xbox will pick controller signal.
Jul 06, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Console Logo
43 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
