Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Coincidence? IC chip burn out
I was programming my new Cable box remote to activate my Tv when the code that should operate it would not work so I used the "philips" default find a code program that comes with the remote when I entered it nothing happened, so I entered it a few times no go after a few tries I noticed my convergence was off and it will not respond now. Does any one beleive that the new remote caused this? Also can any one tell me a cost estimate to have the IC chips/board reaplced?
I agree 100% with what premtech says, but don't be put off. Make sure you know where the cables go. It took me 20 minutes to have everything disassembled and good to replace. When you take the ic's off save yourself some grief and snip the leads then take the stubs out one at a time. Also, clean the fireproof 1watt resistors with rubbing alcohol after they are replaced so you don't leave oil on them. Oil CAN (no it isn't a myth) allow high voltage to arc over them and to a degree bypass them and cause weirdness or cause them to burn up again.
Posted on Feb 24, 2008
  • 934 Answers
I doubt seriously that the remote had anything to do with the problem you're describing. That is a DPTV305 chassis and uses two STK392-120 ICs for convergence amps, designated IC7044 and IC7045. In that unit I would HIGHLY recommend using the Philips OEM part which is p/n#932212344682 to keep from having tint problems down the road... After replacing the amps you should also test and/or replace all the 6.8 ohm/1w bias resistors down front. Parts are not too expensive, under $100.00 bucks - but the labor might be a little spendy since that unit is not a light box and the teardown alone is estimated at 2.0 hours. Like the old Chilton auto manuals that's 2.0 hours for a qualified CET, with every tool needed at his fingertips. It will probably be closer to 2.5 hours - then come re-assembly. I'd strongly recommend finding a good reputable shop and take it to them.. Hope this helps. Bill
Posted on Jun 20, 2007
SOURCE:
RCA TV Converter Box DTA800B1. Codes for roku tv
For a Cablevision cable Provider the remote controller Model Number is UR2-CBL-CV04 and its remote device unique codes for Roku TV become 031, 081. To get a Charter Cable Provider the remote control Model Number is usually UR4U-MDVR-CHD2 and its remote control codes for Roku TV be 11756, 11602. The user on find their respective remote controller code, have to activate their Roku account using enter Roku activate code to get started on streaming their recommended shows.
For a new Cox Communications Cable Provider the remote control Model Number is URC-8820-MOTO and its remote control codes for Roku TV be 1756, 2360. For the DirecTV Cable Provider the particular remote control Model Number will be RC65 and its remote control codes for Roku TV be 11756, 10818. For a Dish Network Cable provider the handheld remote control Model Number is 21.1 IR/UHF and its remote control codes for Roku TV be 535, 556.
The ONN Cable Supplier the remote control Type Number is ONA12AV058 in addition to its remote control rules for Roku TV are 3851, 3201. Once the consumers remote controller are programmed with the respective codes then the user also have to activate their Roku accounts using enter Roku activate code to start out enjoying their preferred streams.
Hope you find your own appropriate code for your cable providers. For any help on adding the RCA Roku TV codes call our technical support staff members through toll-free numbers +1-855-804-1313 or visit them at roku.com/link
Dec 16, 2014 | RCA (DTA800B1) Video Converter
Why won't television turn on with remote control?
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 12, 2014 | Sanyo DP26640 LCD TV
Need directions 4 rca rcu 800b [rcu800-or rcu403 to program code
RCA TV Codes: 000,006,011,019,027,034,038,044, 046,088
RCA Cable Box Codes: 000,027
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
Special Notes:
RCA, GE and Proscan Brand Devices:
Many of these devices (TV's and VCR's) will not need to be programmed. In the event that programming is required, the code search method is suggested.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Sep 07, 2009 | RCA Universal Remote Control
Need to program a new remote for RCA TV
  • TV-000
  • VCR-000
  • Cable Box-000
For more info, copy and paste this link in your address bar so you can get codes for you remote:
http://www.thompsontv.com/rcarc.html
Aug 24, 2009 | RCA Universal Remote Control
I need the RCA remote code for Durabrand tv
Since the Funai code does not work, you have to use the CODE SEARCH feature.
The remote may already be set up to operate your brand of TV, VCR, Laserdisc, Satellite Receiver, Audio Equipment, or Cable Box. It is pre-programmed with the following codes: TV-000, VCR1-000, AUDIO-003, and SAT•Cable Box-000. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD, SAT•CABLE, or AUDIO).
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
7. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond,
repeat steps 1-7.
Nov 17, 2008 | RCA Universal Remote Control
RCA Universal Remote set to my Emerson TV
  • TV-000
  • VCR-000
  • Cable Box-000
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Oct 12, 2008 | RCA 257003 Remote Control
Codes to operate a cable box with TV remote
Try code 038. If that doesn't work try 039.
Aug 05, 2008 | Televison & Video
RCR3273 Remote Control code for 8607 Scientific Atlanta cable box
These are all of the codes I have for the RCA universal remote.
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 24, 2008 | RCA Universal Remote Control
Universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
  • TV-000
  • VCR-000
  • Cable Box-000
Apr 07, 2008 | RCA Universal Remote 3 Device Remote...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
