Re: Removing the upper fuser roller assemble.
Dear Archman50
Need your help, I already removed the plasic backing from the copier and it seems that there are 2 tall black legs that sits between the upper fuser roller assemble, please help me and tell me what I need to do next. I already got the part just need some more assistance.
Please write me back,
ars7777
    Novelist:
  • 148 Answers
I am not sure what the black legs do but they problably support the heater lamps....if there is a wire going to the legs then the black legs need to be removed. the key is to d isassemble any drive chains, brackets etc that support the fuser rollers the black legs could also be support for stripper fingers
just dissasemble all components holdng the fuser roller from both sides
best of luck
Posted on Jan 17, 2009
The paper is crumpled in the lower part of the paper.
Maybe you have problems with the upper fuser roller, open the back door and try to see the upper fuser roller and lower pressure roller if you see any wrinkles or damage in any of the rollers that's is the problem, you can replace them just the upper fuser roller and the lower pressure roller but it will need advanced skills, the other option is change all fuser assembly but at higher price
Nov 26, 2013 | Brother HL-5250dnt Laser Printer
I have copier ir 400s sir i am getting error when i started the machine the error is E014 thank you
This is an indication that the fuser ( hot rollers on left side of copier ) are not turning. This could be caused by several things. Try turning the green knob behind front door. Does it move smoothly? If it doesn't then remove the left side fuser door and remove the fuser assembly. The bearings for the upper and lower rollers could be bad. If the fuser moves easily, then it could be a white gear that is located on the upper right of the fuser assembly. This is the drive gear for the fuser. The gear tends to wear out over time and has to be replaced. This should get you in the right direction to solve the problem.
Mar 28, 2011 | Canon imageRUNNER 400S Copier
The printer make noise while it is printing
Hewlett Packard P3005 Fuser
Its all about the gears in the fuser drive assembly and the bushing in the fuser.
The HP P3005 fuser is located at the back of the printer.
The fuser has a thin film upper roller which can be torn, some symptons can be "Wrinkled Pages","Poor Fusing", "Toner Rubs Off the Page", "Pieces of black Plastic Come Out".
*** The printer should be unplugged from any power source before any servicing is performed ***
The rear cover can be taken off by removing 2 screws. Once the cover has been removed the fuser can be removed by taking out 4 screws and 3 electrical connections.
Part Number and purchasing link below
RM1-3717-020
Feb 23, 2011 | HP Laser Jet Printer P3005dn
We are getting some markings on the printed pages. All of the rollers have been cleaned except the top one. What is the best process for getting into the top end of the printer to access the rollers...
The problem is weared hot roller. It is a steel sleeve with teflon coating, rolling around a ceramic heater. You have to replace it. To reach it you have to remove the back cover, side covers and the upper cover. It is possible with some bending to take out the upper cover without removing the other covers, but you will have to remove them later anyway. To remove the upper cover, remove the grey plastic part first. There are four screws under it that hold the cover. There is a flat cable to the control panel. Remember to attach it when assembling.
The fuser unit is under the cover.
Disconnect the wiring and remove the screws of the fuser. Then remove the entire fuser unit. Take it to another table and dismantle it.
Cleaning this roller will not help. Replace it or don't bother to dismantle if you will not.
Aug 11, 2010 | HP Color LaserJet 2600n Printer
Replacing upper fuser roller
there really is no need to remove the cleaning web when replaceing the upper fixing roller.... it stays in place and will not present a problem apon replacement
Jun 04, 2010 | Canon imageRUNNER 5000 Copier
Sharp AR-M700N damaging fuser rollers. I just replaced both rollers, Upper and lower, the cleaning rollers as well and when I installed on the machine it bacame so hot it rip off the skin of the lower...
it sounds to me like you have some severe fuser thermistor and thermal fuse problems ...i would look into getting an entire fuser assembly sharp part number DUNTW7305DS** last digits depend on your location and power supply
Feb 06, 2010 | Sharp AR-M700N Copier
if it is a repair manual it will have a diagram if it is owners manual it will not
Jan 18, 2009 | Office Equipment & Supplies
you do not need a lot of lubricant on the gears if you do any just take your finger and dip into vasoline(petroleum jelly and dab a little bit on too much grease attracts dirt wipe any excess with a cloth
Jan 17, 2009 | Office Equipment & Supplies
Upper (gray) fuser roller needs replacing, (tear on 1 side).
If you are handy it is not hard to replace the upper fuser roller you will need a small phillips screwdriver and pliars
the fuser lamp goes through the fuser roler so youmust disconnect the power leads to the lamp and remove the lamp
You do have to release the back side of the drive
gear on the fuser roller
when you install the new roller be sure to put some silicone fuser oil on the cleaning pad
take your time good luck
Jan 04, 2009 | Office Equipment & Supplies
Paper dents
I believe you have two problems. One the dent you are talking about unless I see it I don't know for sure but I believe this is minor and something you need to live with. The paper goes through a fuser which uses a teflon sleeve over a heater surface and a lower pressure roller made of rubber. It may be that you need a new lower pressure roller they get little cuts in them sometimes. Two the spots are probably from a faulty toner cartridge. It has a leak.
Feb 13, 2008 | Canon imageCLASS D761 Copier
62 people viewed this question
k24674
