Question about Fujitsu 24C1 Air Conditioner
Fujitsu AOT24PMAL not working
Help! I have a split system inverter that has blown the cap off the three way valve, I guess with total refridgerant loss, why so? what gives?
    President:
  • 267 Answers
There is NO reason for this . that said i have seen this before the brass is cheep and the can snap or leak just useing it in normal service . i have removed the broken valve and made my own bridge and port , there does not need to be a valve there just a port for service . this is nothing for a homeowner to do , you will need to call for service ...... good luck please rate this answer , i am new here and need the reviews so i can stay here , thanks
Posted on Jan 17, 2009
My fujitsu mini split is tripping the circuit breaker on heat mode after a few minutes of operation. the a/c works fine. It makes a lot of noise just before tripping
If I had to guess you have a bad reversing valve. valve sticking, compressor not being able to pump refrigerant, then drawing high amps, overheating and tripping the breaker. If you have tools and experience, try tapping on the valve gently to free it up while switching.
Dec 24, 2017 | Fujitsu Heating & Cooling
A four year old Fujitsu split system works fine in all modes except the heat mode. Have turned off the main power source for 45 seconds, no change. Can you help please.
the heating function feeds power to the reversing valve to enable heating the valve coil should be electrically tested, pos opened circuit (burn out )
Sep 02, 2017 | Fujitsu Heating & Cooling
A four year old Fujitsu split system works fine in all modes except the heat mode. Have turned off the main power source for 45 seconds, no change. Can you help please. Model # AST30RBA-W
As stated, sounds like a reversing valve issue, likely need a technician. What exactly happens when in heating? Does it run, still cold, just warm not hot???
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
My fujitsu asya12lgc mini split system cycles off before reaching the correct temp. then comes back on about 10 min later.
Can you please help me? I has a fujitsu ASYA12LGC, and blinking the timer led (orange one) three times...
we have 2^ celcius and we have broblem with it...
Oct 29, 2013 | Fujitsu Heating & Cooling
It happens at random maybe after turned on for a couple of days, maybe after a couple of hours. More than three quaters of the screen just goes black, the other bit is still working fine.
Inspect the caps in the power supply and solder joints.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Fujitsu 24C1 Air Conditioner Logo
333 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
