Question about Motorola Mobility C261 Cellular Phone
Multimedia set up
My multimedia setting is not working. when I try to open the browser messages it appear network down or requiest time out. also I can not send or open my reveived MMS what can I do to get my multimedia set up and be able to read my browse messages and also be able to send and receive MMS?
  • Anonymous Mar 01, 2009
    when trying to recieve a mms it says try again later
Make sure you have activated your GPRS (contact your operator. If you are sure the GPRS is active, reset your phone and then try to connect to internet using your browser or send an MMS. Hope it will help
Posted on Aug 23, 2007
SOURCE:
Having problems getting on social network sites since installing BT Infinity
This can happen due to many reason
  • First of all close all your browser,check your Date and Time of your Device for mismatch, if it is incorrect, change it . and reopen any social networking sites on new browser tab.
If still same problem, It could be because of Anti Virus. I am assuming your anti virus is Kaspesky.
  • Close all internet browsers. Open your antivirus control panel. In my case, it was Kaspersky antivirus.
  • Click on "Settings". Go to "Advanced Settings" tab and click on "Network".
  • Under the "Encrypted connections scan", uncheck the "Scan encrypted settings".
  • Click Apply and OK.
  • Now, relaunch your browser and open the desired website.
  • Right click on the Shortcut file of Google Chrome( assuming your browser is Google Chrome) at your desktop.
  • Choose Properties. A new window will appear on your screen.
  • You would see a field named "Target". Just Tweak that i.e modify it. Add the below code in front as show in the below image.-ignore-certificate-errors-.
Hope one of the above step will work for you.
Apr 11, 2015 | Facebook Social Network
How can i fix multimedia problem,im unable to send or receive multimedia messages ?
check the operator settings MO send MO to your Mobile operator and you will recieve settings just save it thats all and enjoy
May 14, 2014 | Nokia E5 Cell Phone
I cant download pictures messages
Here are a couple of things you can try:
You need to see if your MultiMedia Messages (MMS) are set correctly.
1. Go to messages and click on Settings.
2. Scroll down to find Multimedia Message (MMS)
3. Set Auto Retrieve to OFF
If that doesn't work try this:
1. Go to Settings
2. Go to Mobile Network Settings
3. Click on Access Point Names (APN)
4. Tap on Menu - (lower left side of phone)
5. Click on Reset
Try both these things and that should fix your problem.
Good Luck
Apr 01, 2014 | Samsung Galaxy Cell Phones
How do i change my apn settings on my eternity so i can use the straight talk network
From the main screen of your phone open you menu, then messaging, then messaging settings, then multimedia message, then MMS profiles. from there create a new profile and fill in these settings:
Set Name: Straight Talk
Access Name: att.mvno
Auth Type: Normal
User ID: *leave blank*
Password: *leave blank*
Protocol: HTTP
Home URL: http://mmsc.cingular.com
Proxy Address: proxy.mvno.tracfone.com:80
Linger Time: 300
*leave advanced settings alone*
Save your profile and select it using the square on the right of the screen. You should now beable to recive multi-media text messages. Exit out to your phone main screen.
Press menu, then Media Net, then Browser Settings, then Browser Profiles, then select the profile named straight talk by pressing the square on the right side of the screen. You should then be all setup to use all forms of data and messaging on your new Straight Talk plan. I hope this was helpful!
May 02, 2012 | Samsung Eternity Cell Phone
My phone wont recieve any multimedia msgs HELP!! :O
To make your
multimedia messages working you should first need the settings for it.You cannot set it.Your network provider should give the default gateway address for it.Then only you can use it.
If you already have set the setting and now if it is not working because the network service provider would have changed the gateway Ip address.You have to again set the new one.
Please call your network service provider and ask him to send the
multimedia messages settings for your mobile.He/she will ask for the mobile model and send you the appropriate multimedia messages setting.You will get the settings as an SMS.go to inbox and save the setting...
Now you can work with it.Your phone has no issues with
multimedia messages.Only network service provider has to give the correct settings.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Sep 01, 2010 | Cell Phones
How to activate & send mms in samsung s8000 mobile
you need to configure the mms settings from your internet menu... but you need the right configuration from your network provider to the settings..
to give you an idea, here's how you may do it.. from your phone, press menu select internet select browser profiles to lead you to internet profile settings.. from your settings, press create.  then create the mms profile your network preferred.  once created, press save and exit the settings for internet profiles..
to make the mms profiles be the default settings for your mms, do thes steps... from your phone, press menu select settings select phone applications select messages select multimedia from multimedia menu, select profiles assign the mms profiles you created for your multimedia. press save and exit the setup...
now to check if it's working, try sending a multimedia message to your own number to check if your phone can send and receive mms. once you successfully send it and received it, it means that your phone mms is already set and working...
take care..
Mar 30, 2010 | Samsung Jet S8000 Cell Phone
I can't recieve or send picture message on my rogers lg shine unlock phone.
i got a unlocked phone lg shine with rogers to.just got it fixed through att.if you have att then ill tell you how to fix.you must type in exactly how i do if its a capital put it in and do it in the order i put down.
go to menu/settings/connection/network profile.
hit new
connection title:
User Defined
authentication:
PAP
username:
[email protected]
password:
CINGULAR1
APN:
wap.cingular
exit out to menu
go to internet
settings/browser settings/accounts
hit option button
new
account name:
MEdia Net
home page:
http://home
connection mode:
TCP with Proxy
proxy address:
wireless.cingular.com
proxy port number:
80
security:
non-secure
time out:
300
network profile:
User Defined
no go out and back to your menu to messages
message settings/picture setting or multimedia settings/message center.
hit option button again and new
name:
AT&T MMS
mmsc url:
mmsc proxy:
mmsc port:
80
connection mode:
TCP with PROXY
network profile:
User Defined
save
will take you back to message center screen
hit activate n done
i tried all the code on this site nothing worked.this one does work for changeing roges settings to att
Jul 25, 2009 | LG Shine (CU720) Cell Phone
HELP, LG SHINE 970
Internet Setting Cingular:
Profile Name: Cingular
GPRS setting:
APN: wap.cingular
User Name: WAP @ CINGULARGPRS.COM
Password: CINGULAR1 (ALL UPPERCASE)
Time Out: Off
Primary Gateway IP: 66.209.11.61
Port: 9201
Secondary Gateway IP: 0.0.0.0
Port: 0
DNS Server:BLANK
CSD setting:BLANK
Dial in number NONE
Query at Logon: (NO CHECK MARK)
User Name
Password
Baud Rate Auto
Line Type: ISDN
Time Out Off
DNS Server:
Then go to your browser and enter the following settings:
Profile Name: MEdia Net
Homepage: device.home
Network Link: Cingular
MMS Settings:
Profile Name: MMS over HTTP
MMSC: http : //mmsc.cingular.com/ (No Spaces)
Max Sending Size: 30K
Network Profile: Cingular
Internet Setting T-Mobile
T-MobileWeb Settings:
Primary IP Address: 216.155.165.050
Secondary IP Address: (Blank)
Access Point Name (APN): wap.voicestream.com
Data Bearer: GPRS
Profile Name: GPRS
Username: (Blank)
Password: (Blank)
Home Page: http://wap.myvoicestream.com
Picture Messaging Settings:
Multi-Media Service Center (MMSC) Address: http://216.155.174.84/servlets/MMS
Validity Period: 72 hours
Hide ID option (if option exists): set to off, no, or disabled
Internet Setting FIDO
Profile name: FidoWAP
GPRS setting:
APN: wap.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.11
Port 8080
Secondary Gateway IP: (blank)
Port: (blank)
DNS Server: (unchecked)
CSD Setting:
Dial in number: (blank)
Query at logon: (unchecked)
Username: (blank)
Password: (blank)
Baud Rate: Auto
Line type: Modem
Timeout: Off
DNS server: (unchecked)
Then press Save.
To get MMS working (what I haven't included are the blanks and all boxes should be unchecked unless specified)
Setup-->Data Network
Profile Name: Fido MMS
APN: mms.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.13
Port: 8080
Baud Rate: Auto
Line type: Modem
Timeout: off
Then click SAVE.
THEN
Messages-->Service Setup-->Multimedia Message
Default profile: FidoMMS
(all other settings are to your preference)
Tap the box beside Default Profile and ensure that FidoMMS is the default profile.
Settings for MMS profile goes
Profile name: FidoMMS
MMSC: http://mms.fido.ca
Max Sending Size: (your preference)
Network Profile: Fido MMS
Internet Setting Rogers
Proxy Name: Rogers MMS
Proxy Address: 172.25.0.107
Access Point: Rogers MMS
Home: ((Set whatever page you like here))
Port Number: 8080
Authentication Type: HTTP-BASIC
User Name: media
Password: mda01
Access Point Name: Rogers MMS
APN: media.com
Authentication Type: PAP
User Name: media
Password: mda01
DNS: <>
Linger Time: 180
MMS Accounts (Main Menu -> Messaging -> Messaging Settings -> MMS Settings)
Profile Name: Rogers MMS
Proxy: Rogers MMS
Relay Server URL: http://mms.gprs.rogers.com
Master Reset
Dial the following 2945#*#6 or 2945#*45#
Feb 14, 2008 | LG Shine KE970 Cellular Phone
Smasung g600
do you have the network providers configuration?
contact network provider to configurate your settings, they will send you the setting after that, then install it to your phone.
Jan 24, 2008 | Samsung SGH-D500 Cellular Phone
Motorola Mobility C261 Cellular Phone Logo
75 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
