Question about HP OfficeJet 7410 All-In-One InkJet Printer
Scanner bar seems jammed, printer shows busy, all docs cancelled
After numerous attempts to fax docs (redial mode) the printer/fax jammed. Now the scanner bar does not move more than 1/2 inch. The printer status shows busy, despite the fact that I cancelled all docs. The printer screen shows a constant hour glass symbol.
Open the printer and pull paper. It might come in pieces then shut down printer to reboot it and that should make the symbol go away and youshould be able to start over. At least when I had a problem thats what fixed it. Hope it helps
Posted on Jan 17, 2009
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
Fax is always busy when sending, have the line into the phone line port and into the telephone jack, fax scans and dials and even redials but it never go through, prints out receipt that says busy/no...
Has it always done this, or did Fax once work? Sadly, Windows XP Fax has many shortcomings, not the least of which is that it won't work with many modems still in common use. Modem incompatibility is not apparent during installation or the initial setup. It only becomes apparent when you try to send or receive a fax. The Fax Service will dial or will answer an incoming fax but then fail with any of a number of unhelpful error messages such as "Line is busy," "There is no answer," or "Reception error." There will be nothing in Event Viewer to give a clue as to where the problem might lie.
These errors have been nearly impossible to track down. To do so requires enabling both PSS and debug logging of fax transmissions, both of which require fairly extensive registry changes. For the time being, the best advice is to attempt to use XP Fax only if you have a modem that is listed on the Windows XP Hardware Compatibility List and using the latest drivers.
Hope helps.
May 09, 2010 | Brother MFC-5840CN All-In-One InkJet...
We receive numerous complaints that the faxes we send do not go thru. Why if a line is busy does our request not go into a queue? any idea??
If the line is busy on the other end, your machine will put it in redial state and will try again. However, the redial function will depend on the setting how many try it will make. If the setting is 2 as an example, it will redial twice only and if it is still a failure it will treat the transaction as "NO" or "NG". You can check this in the transaction list of your machine. As you said, there are numerous complaint, check if the complaint is with the same receipient, if so most probably the end machine is having some problem. If from different destination please have your machine checked by the local service provider.
Dec 30, 2009 | Brother IntelliFax-2820 Laser Fax
HP Officejet 6210 will not copy, scan or fax. It will print documents from the computer. Any attempt to do the other 3 functions results in it being "busy" and cannot cancel, have to power it off.
Well if it is printing,the drivers are working fine.The copying,faxing and scanning mechanism use the same scanner to copy the image.It seems to be a problem with the scanner mechanism on the printer.Try a reset using the # and 6 buttons while plugging in the power cord.If it works well and good.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Sending fax error message "low memory"
Try reading these:
General fax problems
Issue Cause Solution The document stops feeding in the middle of faxing. The maximum length of a page that can be loaded is 381 mm (15 inches). Faxing of a longer page stops at 381 mm (15 inches). If no jam exists and less than one minute has elapsed, wait a moment before press Cancel . If a jam exists, remove the media. If the item is too small, it can jam inside the automatic document feeder (ADF).
(HP LaserJet 3015 all-in-one) The minimum paper size for the ADF is 74 x 105 mm (2.9 x 4 inches).
(HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one) The minimum page size for the ADF is 127 x 127 mm (5 x 5 inches). If a jam exists, remove the media. The fax activity logs or fax call reports are printing at inappropriate times. The fax activity log or fax call reports settings are not correct. Print a configuration report and check when the reports print. Set the appropriate log or report printing times through the control panel or the HP Toolbox. The volume for sounds that the device emits is too loud or too soft. The volume setting needs to be adjusted. Set the appropriate sound volume settings through the control panel. Fax send troubleshooting Use the information in the following table to solve problems that might occur when sending faxes: Issue Cause Solution Faxes stop during sending. The fax machine to which the fax is being sent might be malfunctioning. Try sending to another fax machine. The telephone might not be working. Do one of the following:
  • Turn up the volume on the device, and then press Fax/Send on the control panel. If a dial tone is heard, the telephone line is working.
  • Disconnect the device from the jack in the wall, and then connect a telephone to the jack. Try to make a telephone call to make sure that the telephone line is working.
A communication error might be interrupting the fax job. Change the redial-on-communication-error setting to On.
See the electronic User Guide on the CD-ROM that shipped with the product. The device is receiving faxes but is not sending them. If the device is on a PBX system, the PBX system might be generating a dial tone that the device cannot detect. Disable the detect-dial-tone setting.
See the electronic User Guide on the CD-ROM that shipped with the product. A poor telephone connection might exist. Try again later. The fax machine to which the unit is sending to might be malfunctioning. Try sending to another fax machine. The telephone line might not be working. Do one of the following:
Outgoing fax calls continue to be dialed. The device automatically redials a fax number if the redial options are set to On. Press Cancel to stop the redials while the device is dialing.
To cancel a pending fax job, see "Canceling a fax job" in the electronic Users' Guide on the product CD-ROM.
See "Changing the redial settings" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent are not arriving at the receiving fax machine. The receiving fax machine might be off or might have an error condition, such as being out of paper. Call the recipient to make sure that the fax machine is on and ready to receive faxes. The originals might be incorrectly loaded. Make sure that the original documents are correctly loaded into the automatic document feeder (ADF) input tray or flatbed scanner (not available with the HP LaserJet 3015 all-in-one). A fax might be in memory because it is waiting to redial a busy number, other jobs that are ahead of it are waiting to be sent, or the fax is set up for a delayed send. If a fax job is in memory for any of these reasons, an entry for the job appears in the fax log. Print a fax activity log and check the Status column for jobs that show a Pending designation. All of the numbers of a long fax number cannot be dialed. The maximum number of digits of characters that can be entered into a fax number is 50. Try manually dialing the fax number. Faxes that are sent include a block of gray shading at the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent have data missing from the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM.
Jul 16, 2008 | HP LaserJet 3030 All-In-One Printer
Compaq a1500 printing probs
ok you might have tried printing a doc/app out earlier and it might have failed so while you trying to print out this present app/doc the printer still might be focused on that failed or it might be confused. Now to stop this follow these instructions. Go to the start bar click control panel. Then once that window pops up ( control panel ) click printers and other hardware. Then once that window pops up ( printers and other hardware ).  Click Printers and faxes and that page will have all the printers and faxes ever installed to your computer. Now click on the printer thats yours and then a smaller wider window will appear you will that window will have all the doc/app you have ever tried printing out. the status bar will show what is going on with each doc/app. Now you should first stop all the doc/apps and refresh. To do this you should highlight all the doc/app and then go into the document tab ( there are several tabs in this window such as document , printer, view and help) then click cancel and cancel all the doc/apps. last step is to go into the view tab and click refresh and it should work :-). If not contact your printer manufactor.
Jul 09, 2008 | Compaq A1500 All-In-One InkJet Printer
Won't print
Ok I just solved a persons problem that is very similar to yours. OK So I'll just paste what I told the other person. You might have tried printing a doc/app out earlier and it might have failed so while you trying to print out this present app/doc the printer still might be focused on that failed or it might be confused. Now to stop this follow these instructions. Go to the start bar click control panel. Then once that window pops up ( control panel ) click printers and other hardware. Then once that window pops up ( printers and other hardware ).  Click Printers and faxes and that page will have all the printers and faxes ever installed to your computer. Now click on the printer thats yours and then a smaller wider window will appear you will that window will have all the doc/app you have ever tried printing out. the status bar will show what is going on with each doc/app. Now you should first stop all the doc/apps and refresh. To do this you should highlight all the doc/app and then go into the document tab ( there are several tabs in this window such as document , printer, view and help) then click cancel and cancel all the doc/apps. last step is to go into the view tab and click refresh and it should work :-). If not contact your printer manufactor.
May 26, 2008 | Compaq A1500 All-In-One InkJet Printer
Fax problem
Pending faxes are faxes whose transmission has been delayed either deliberately or unintentionally. Normally, when a fax cannot be sent at the first attempt, the fax machine will redial the recipient's number. If you choose to delay sending a fax, the machine will send it at the time you select for transmission. During the delay period and at any point up to completion of the call, you can cancel the delayed transmission by deleting the fax from the Pending Faxes queue. To do this:
Press the Fax button on the operator panel and then press Options (once only). The Pending Faxes menu will be displayed.
Press Select. If a fax is pending, the printer will display Cancel Fax (the fax number you dialed appears below these words).
Press Select to delete the pending fax.
In response to the Are you sure? prompt, press 1 for Yes ( 2=No).
Press Options (once only). The Pending Faxes menu will now display None.
Feb 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Redial
Go into the admin mode or user mode to reset the default settings. Procedure should be in the op manual.
Nov 15, 2007 | Minolta MF1600E Plain Paper Laser Fax
HP OfficeJet 7410 All-In-One InkJet Printer Logo
99 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
