Question about Nintendo Wii Console
I get a can't read disc message with my wii fit
All my other discs work with no problem. I have cleaned the disc . There is a small scratch but nothing deep. Any suggestions? The disc worked for about two months but is not now. Thank you.
  • Craig Underhill
    Craig Underhill May 11, 2010
    Do you have the label on the disc facing to the right?
    Have you checked the disc under a light to make sure there aren't any smudges?
  • 903 Answers
Even small scratches can cause disk read errors. Try cleaning it again with a little white spirit using a soft cotton cloth then dry it off with a soft cotton cloth. If it still does not read, a lot of 'game' shops repair scratched disks for about £3.00.
I hope this helps
Posted on Jan 17, 2009
Wen i ensert the disc the message is unreadable
The disc may be scratched. Look for scratches on the disc and if there are clean it with a disc cleaning solution. Only outward strokes. Not circular strokes.
May 05, 2011 | Nintendo Wii Console
My wii fit plus disc reads cant be read when inserted in to the wii help please can it be fixed
Hi lyned1,
If the Wii is having trouble with a disk, it means there's either a problem with the disk or the Wii. If your Wii can't read any disks then you'll want to contact Nintendo. Otherwise you need to investigate your disk.
If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. Use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) If the disk looks good, put it back into the Wii and see what happens.
A scratch is more problematic. If it's a game you just bought, try exchanging it where you bought it. Otherwise you can try polishing out the scratch.
Some older Wii units also have trouble with dual layer discs, If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. And also you can try to use a different disk to check if your system will be able to read it. then try the Wii Fit Plus If after all that, your Wii still can't read the disc, it's probably just a bad disc.
Thanks for using Fixya.
Jan 28, 2011 | Video Game Consoles & Games
When we insert game discs in our wii, it will let us play for about 2 minutes, then give us a message that reads, "disc cannot be read, please refer to wii ooperations manual." I ordered the wii...
Check to see if there are any scratches on the disc. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating "Disc Read Error" or something to that effect. With some scratched discs, the data cannot be read and the game console may not even recognize the discs at all, giving you error messages etc. Best remedy for starters, is to try clean the discs and make sure there are no smudges or dirt marks left on the play-side of the discs. If there are any scratches on the discs, they will need repairing.
Most Game Discs, DVD's and CD's can be fixed quite easily back to "As Good As New Condition". Some home remedies or cheap repair kits may help with some light marks or very light scratches on some discs, but a professional disc repair service is usually required to repair any discs with anything more than very light scratches.
For further help on disc repairs, visit: Get Scratched Discs Repaired Back to "As Good As New Condition".
Check the "More Info" & "FAQ" Sections for further details on game disc repairs and related matters.
If you tried some home remedies and they have not worked, try sending the disc off for repair. Contact the site above for advice on repair and shipping.
Hope this Helps!!!
Dec 06, 2010 | Nintendo Wii Console
Wont read game discs
Hi. Try Cleaning the lens using a q-tip and alcohol. Is there any error message appeared on the screen?
Sep 04, 2010 | Nintendo Wii Console
My wii console turns on and when I place the wii fit or wii sports CD in the console, everything looks fine. I then get the menu on the screen. But when I press the wii fit -nothing happens. When I place...
if by doesnt begin you do you mean doesnt read disc or fails to start game because if its doesnt read disc look for scratches on the disc if its doesnt initialize then it could be the disc drive itself is bad then go to
Jan 16, 2010 | Nintendo Wii Console
Disc doesn't work when I change from body test to training on Wii
Wii Fit? The problem can be that your Wii is modded (IF ITS MODDED), or that the disc contains scratches.
Nov 21, 2009 | Nintendo Wii Console
My wii fit disk wont work
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 27, 2008 | Nintendo Wii Console
Wii Fit
This is really very frustrating when you face such kind of problems. You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Jun 26, 2008 | Nintendo Wii Console
The disc is unreadable
Is it just dusty, or are there scratches?
If it is just dust, clean is with something soft- t-shirts work quite well ni the abscence of anything else.Make sure to clean from the middle to the edges in lines, not circles.
For small scratches, a sometimes very useful solution is toothpaste.Put some toothpaste by the scratch and rub it it, then wash of excess toothpaste and dry the disc.The toothpaste fills in the scratch, leading to a temporary fix.
May 16, 2008 | Video Game Consoles & Games
Nintendo Wii Console Logo
172 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
