Question about Amana 24 in. DWA33A Built-in Dishwasher
Dishwasher finished cycle, but still full of water
Last night I installed a new disposer. During that installation, I noticed that the drain hose from the dishwasher was low - the loop only halfway up to the height of the washer.
I heard that a drain hose is supposed to be as high as you can get it in order to prevent siphoning. Apparently not in this case?
It's an Amana DWA33A.
Thanks in advance.
  • dk518 Jan 17, 2009
    Thank you. But the dummy that was helping (did I mention I was working solo?) forgot to take out the dishwasher drain plug!!!
    Problem Solver:
  • 15 Answers
Take some drainig liquid and let it sit in there over nite if that does not work take out the drain and take out the old grub manualy (i think what u want to put in the dishwasher is vinagear or draino something
Posted on Jan 17, 2009
When cycle is finished there is still water in the bottom of the dishwasher
Hi and welcome to FixYa I am Kelly.
Water in the bottom of the unit is a sign of drain problems that are usually external to the dishwasher. You probably have noticed cloudy or spotted dishes post cycle lately also. Since I suspect a drain problem here is what you should do:
  • Start at the sink connection and remove the hose. Then clean out the port at the sink or garbage disposal connection. Reconnect the hose. (Clogged garbage disposal ports are the 2nd highest reason for dishwasher drainage problems.)
  • Next if you have an Air-Gap installed pull off the upper/outer cover and NOTE the position of the internal cap and nut. The cap with the inner inverted U will only install correctly in one position. Remove the nut and lift off the inner inverted U cap. (This is were most clogs are found.) Clean out any debris found. Use a flash light and inspect the lower outlet hose port for obstructions. Remove the lower outlet hose to the sink / garbage disposal connection if necessary to clean the outlet port.
  • Lastly... If after doing the above and you still have water in the dishwasher post drain cycle then TURN OFF POWER to the dishwasher and remove the lower kick panel. The remove the drain hose from the pump and inspect the port for obstructions. Clean as necessary. Re-install the removed hoses. (Check all) Install the lower kick panel.
TURN ON POWER and test the drain cycle after filling with water. This should make it work properly again unless there is a problem with the pump impeller blades or something inside the sump housing blocking the drain port. If you have done all of the above and you still have the same water in the sump post drain cycle problem... Just respond here and I will explain what to do next.
Thanks for choosing FixYa,
Kelly
Feb 27, 2011 | Bosch 24 in. SGS43C12 Classixx...
DW just installed. Water doesn't drain when cycle is finished.
is this brand new ? if so check where the D/W drains...it should drain into sink through disposal or sink drain adapter ..was the plug removed from the disposal ?for the dishwasher to drain ?remove drain hose from disposal or sink adapter.put in bucket turn on to see if it drains ..if so remove the plug from disposal or clear debri from hose or disposal /drain adapter..let me know..good luck/joe/
Aug 28, 2010 | Bosch Evolution 800 SHE58C05UC Stainless...
Water is not draining after wash. What might be the cause?
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit ( there are others, this is just an example )
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Apr 01, 2010 | Jenn-Air 24 in. DW861 Built-in Dishwasher
The dishwasher wont stop drying to drain . The darin is not blocked
check the following:---- Check for hose kinks or food plugging drain hose. Start at the drain port exit
  1. Check the check valve and drain hose for debris.
  2. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  3. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  4. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  5. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  6. Check pump impeller for damage.
  7. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
    thanks.
Oct 10, 2009 | Dishwashers
Dishwasher full of water
Check all areas stated below to address this issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/Control
Replace if defective (note: uncommon problem).
Jun 18, 2009 | Electrolux Dishwashers
HI i have an electrolux dishlex dishwsher that is brand new and just installed. Ive used it a few times an dhave noticed that there is water at the bottom of the dishwasher, thats not draining, I thin
there is always a little water in all dishwashers. Sounds like to me that you may have a kinked drain hose or maybe the way you have hooked the drain up. The drain hose should go to a vacuum break that is mounted on the sink flange and then another hose goes to the disposal. If you have the hose hooked directly to the disposal you may be getting water back from the sink to the dw. raise the hose up as high as possible and attach under the sink so there is a high loop in your hose so water cannot drain back from the sink
May 29, 2009 | Dishwashers
Standing water in bottom of dishwasher...didn't drain.
hit the cancel drain cycle. Often times the dishwasher drain hose is not installed properly. It must be routed up as high as the dishwasher as soon as it comes out of the unit. May be also that there was a little regular soap or something that made it sudds up. vegetable oil poured into the dw tub will remove the sudds. Try to wash again after cleaning out the sudds and run it again. Thanks
Apr 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
My dishwasher does not completely drain after a wash. what do i do?
  6. If you have recently installed a new garbage disposal, check knock out plug at connection.
Jan 08, 2009 | GE Nautilus 24" Built-in Dishwasher
I have a whirlpool water softner. After regenerating, the water is still hard and the tank is about half full of water. I have cleaned the venturi.
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
Dec 06, 2008 | Whirlpool Dishwashers
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Amana 24 in. DWA33A Built-in Dishwasher Logo
240 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
