Question about Sony KP-53S65 53" Rear Projection Television
What is the root cause of capacitor C514 to fail?
This is a problem that alot of people ive seen have been having with this model tv. the small disc capacitor labeled C514 on the G board blows out.  now, some people say that the root cause may be a fault in the power supply. one thing is for sure, theres something else going wrong that causes this capacitor to fail. this is the answer that cant be found anywhere. can someone please help here?
    Genius:
  • 1,199 Answers
I would first suspect the Flyback unit on the D board of causing this (this regulates the power the the other boards and the rest of the TV!
I think that is where to look!
Please rate my response
Thank You!
Posted on Jan 17, 2009
Turn the tv on..logo comes up.tv turns off
power supply is turning the tv back off because there is a problem..start with the power supply..check the capacitors to see if they are swollen..ive seen them cause this problem
Mar 06, 2014 | Insignia Televison & Video
Candy c514-80/1 washing machine troubleshooting
it could be that the pressure switch is not clicking off and will only allow the machine to drain the pressure chamber could be blocked take the small pipe off the pressure switch and blow down the tube to see if clear and blow into the pressure switch to see if it clicks it might reset if no click faulty pressure switch no joy let me know
Nov 30, 2011 | Hoover Washing Machines
HI I HAVE SEVERAL LITEON POWER SUPPLYS MODEL NO. PA-1201-1 THAT HAVE WENT DEAD. IT SEEM THAT THIS POWER SUPPLY FAILS ALOT. I WAS WONDERING IF THERE WAS SOME WAY I COULD FIX THE UNITS THAT I HAVE. DO YOU...
Most power supplies have a fuse in them. That is most likely the problem. Otherwise, if you open them up, you can see which capacitor has gone bad, 'cause they will have obviously ruptured.
May 12, 2011 | Lite On Computers & Internet
Channel change automatically....
Ive seen 2 problems that can give this effect. The first is infared interference from another light source. The other is an electronic problem in the front panel where a small filter electrolytic capacitor has given up. Ive only seen the latter problem in pretty old gear so id say the best test would be to put black tape or block the infared reciever on the front of the telly and see whether it still does it. If it does then it is in no doubt a filtering issue likely caused be a failed electro cap.
May 06, 2009 | HP PL4260N 42 in. Plasma HDTV
Trying to identify a capacitor on the power supply board
IF you have the G BOARD part #A-1316-367-A it's:
1-162-133-00 CERAMIC 390PF 10% 2KV
IF you have the G BOARD part #A-1316-422-A it's:
1-161-754-00 CERAMIC 0.001MF 10% 2KV
Jan 04, 2009 | Sony KP-53S65 53" Rear Projection...
Bright Screen/ Color Flicker. /Burn in?
Good Day, radiovisuals;
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040. It’s recommended that all of the capacitors identified be replaced (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.) CAPS: cx178, cx221, cx230, cx241, cx250, cx261, cx270, cx541, cx670 & c514, c5030.
Good Luck, Big Irish.
Jun 19, 2008 | Toshiba 42H81 42" Rear Projection...
Sony kp-53s65 rear projection
C514 is a ceramic capacitor its ratings are 390PF 2KV @10% tolerance
Jun 07, 2008 | Sony KP-53S65 53" Rear Projection...
Green screen
if it is "C514" it is capacitor. maybe the green section from the crt board is dead, try to test the transistor from its circuit or resolder it.
Jan 18, 2008 | RCA 20V500T 20" TV
Sony KP-53S65 53" Rear Projection Television Logo
157 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
