No Signal There are stations in our area Broadcasting Digital already. But, I am still getting a no signal after following the setup per instructions for my Magnavox DTV Digital to Analog Converter.
I give up trying to get this to work. This thing is a joke. We will just go purchase an American made Digital tv today. The "800" that came with the DTV converter was answered by someone who didn't give a **** about helping anyone. What a waste of time and money.
Posted on Jan 17, 2009
How do I get free local TV over-the-air stations?
The Quasar VV-2002 only has an NTSC (analog tuner). Very few stations with NTSC transmitters are still broadcasting. Only low-power stations were allowed to continue broadcasting an analog signal. Unless you are very close to one of the transmitters, your TV will not tune in the station.
You'll need to connect the TV to a digital-to-analog over the air converter box. (The low-end ones that were free or cheap with the government coupon are harder to find; a few models are still available.) These convert the ATSC (digital) signal to NTSC. Then use an appropriate antenna and follow the instructions to tune in the available OTA signals. Send these to the TV either on the RF or composite Line-in. Set the TV to the appropriate input and use the converter box to change channels.
I hope this helps.
(20" TVs weren't required to have an ATSC tuner until 2007. Since there are reviews for the VV-2002 from 2004, it obviously is an older set.)
Nov 19, 2015 | Quasar VV-2002 20 in. TV/VCR Combo
How to get analog channels on my Toshiba?
The problem is probably that your antenna can't pick up any of the remaining analog stations in your area. Only low-power stations are still broadcasting an analog signal. If you are using an indoor antenna, you might the signal with an outside antenna with an amplifier. (Check a site like tvfool.com to get the direction to any nearby analog station and make sure that your antenna is oriented correctly. This site or antennaweb.org will also help you orient your antenna for the digital stations in your area.)
You need a set-top digital tuner or a converter box to translate the OTA digital signals (ATSC) and translate them to the analog NTSC format. Low end converter models with only SD output are harder to find but still available. However, there are some converter boxes that have HD output as well. This one, http://www.solidsignal.com/pview.asp?mc=03&p=3500STB&d=iView-HD-DVR-ReceiverConverter-Box-for-TV-Antenna-QAM-(3500STB)&c=Digital%20Converter%20Boxes&sku= , lets you attach an external drive (USB flash drive or hard drive) . It connects via component video or HDMI. (We've had good luck with our model with a portable (2.5") external hard drive. It replaces the SD converter box and DVD recorder.)
I hope this helps.
(In my area, there is only one low-power station still broadcasting. Its transmitter is nearly 40 miles and can only be picked up with the external antenna and amplifier. If the weather is bad, we will lose that signal. Beware: an amplifier can become damaged and block the signal. The usual check for this removing the amplifier and attaching the antenna directly to the TV. For low-power stations, this test doesn't often help.)
Dec 21, 2014 | Toshiba 50H82 50" Rear Projection...
There is a message on the screen that says "Weak or no signal".
Tv it is not getting the tv stations broadcasting incomming signals.Make sure the ur pay CABLE or free AIR incomming broadcasting tv stations signal sources are good and than go in ur tv menu go into SETUP pick AIR or CABLE and rescan channels again.U should have no more weak or no signal message anymore.
Jul 31, 2011 | Samsung HL-67A510 67" DLP HDTV
No matter where I position the system, I can not get any DAB radio stations to scan. So the signal always shows 0 and consequently never finds any stations. Please help
You can visit the link below to find out more on this Digital Audio Broadcasting issue
and to see if your area has any proper broadcasting as well ?
Please remember to rate me too.."Thumbs up "
Thanks
http://en.wikipedia.org/wiki/Digital_Audio_Broadcasting
Jun 17, 2011 | Audio Players & Recorders
I purchased the PT902/37B and charged it of course. Turned it on for the first time and the instructions say I have a no/weak signal, I reconnected the antenna and still nothing. Can you help? Thank you,...
U follow the tv owner manual instuctions for scanning for the DTV free over the air broadcasting by the tv stations signal yet.Do that first,still have a message weak or no signals.Buy a newly design Digital antenna or have a roof antenna already hook it up to the tv,follow the owner manual rescan it again will have all DTV free over the air broadcasting tv channels.
Jun 13, 2011 | Philips Televison & Video
Tv comes on cannot get a picture nor sound. followed instructions in manual regarding source , enter , picture, enter , channel, enter.etc., I can get to the menus but nothing else. It is not on cable...
If you have an antenna, you are trying to receive off-the-air broadcasting. Remember that a couple of years ago the US switched to digital broadcasting and analog stations went off the air. Your TV does not have a digital tuner, so you need an digital-to-analog adapter if you want to receive anything.
The US government had a program before the switch to help pay for the adapters, but that's long past now. Radio Shack sells them as do other retailers, and you can find them online as well.
The adapter picks up the digital broadcasts and converts them to a channel 3 or 4 TV signal that the analog tuner in your TV can receive. Some models of converter also feature video and audio jacks so you can connect it as an AV source like a DVD player. Once you've hooked the antenna to the converter and the converter to the TV, you'll be able to watch your local channels again. Maybe, that is.
The trouble with digital broadcasting is that signal strength makes a huge difference in reception. With analog, a weak signal would still give you a fuzzy but watchable picture. A weak digital signal may not even be detected, or you might get a picture that breaks up (pixelation) or freezes on the screen. You don't say what kind of antenna you have, but unless you're in or very close to a large city or near the station's transmitter, simple rabbit-ears may not be enough. Many people found after getting an adapter that they needed a better antenna, even something on the roof. In some areas (valleys, remote areas, places surrounded by many tall buildings, for instance) people found they could never get any channels. If you do in fact have a digital converter already (you didn't mention one), this could be the reason you can't get anything.
Hope this helps you figure out what's wrong. Thanks for using Fixya!
Dec 04, 2010 | Craig CTV-41331 13" TV
I want to hook up to air frequency with an antena. out side but i cant get a signal help?
If you're trying to get off-the-air reception here in the US, remember we switched to digital broadcasting and the old analog stations are off the air. This means that if you have an older analog-only tuner, you'll need a digital converter box to pick up the new broadcasts. Before the switch, the US government offered coupons to help pay for the boxes, but that's long since gone and you'll have to pay the full price. Radio Shack, Wal-Mart and Best Buy all carry the converters, and you can find them online as well.
Be aware that even with a converter, you may still not get a signal. With the new digital broadcasting, signal strength is critical. With older analog broadcasts, a weak signal could still give you a watchable picture. But with digital, weak signals may not even be detected. People living in some areas have found that they get no off-air channels or far fewer channels than they did before the switch.
Much of the trouble is because of the line-of-sight nature of the new digital system. With the switch to digital, broadcasts moved to new higher frequencies that don't spread out or follow the Earth's curve like the lower analog channels. Many people have found they needed to put up rooftop antennas pointed toward the station so they could pick up a signal. This is especially true if you live in a valley area or where there are many tall buildings between you and the broadcaster.
Good luck with your reception, and thanks for using Fixya!
Nov 25, 2010 | Symphonic Televison & Video
No antenna signal nor found channels for my area.
You'll need a better antenna to solve your problem. With the new digital broadcasting, signal strength is everything. With analog, a weak signal would give you a watchable but fuzzy picture. A weak signal with digital gives you nothing, or possibly a picture that freezes up or breaks into blocks (pixellation). The only cure is a better antenna, either an amplified indoor antenna or something outside.
Sad to say, there's no guarantee that will work. If you live too far from the station, or have hills, buildings or other obstructions that block the signal, you just may not be able to pick up some channels. In some areas people have found they get no reception at all.
At www.antennaweb.org there's a tool that will tell you what stations are around your area and how far. It's designed to help you figure out what kind of antenna you might need.
Jun 15, 2009 | Insignia IS-PDVD10 Portable DVD Player
I PURCHASED A MAGNAVOX TB110MW9 CONVERTER BOX FROM WALMART. I HOOKED IT UP. IT SCANNED THE CHANNELS BUT IT KEEP SAYING NO SIGNAL.
I have a Magnavox TB110MW9A converter box that has worked fine for the last 8 months. Now you turn it on, the light blinks 31 times, stays on and there's nothing on the screen! The remote does nothing. (yes, I put new batteries in)
Jan 25, 2009 | Televison & Video
Not getting signal for some of the channels in the area.
What is the source of your signal? ie cable, sat, or antenna?
If it is rabbit ears or antenna you may not have a strong enough signal.. With digital you have to have a preaty strong signal or it will come back with "weak signal or channel not found" You could try a signal booster.
Jan 23, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Televison & Video Logo
209 people viewed this question
Top Televison & Video Experts
