Question about HP PSC 1600 InkJet Printer
Setting default How do I set the printing default to black and white rather than color? I have a HP PSC 1600 all-in-one printer. Somehow the b/w default command is now a color default. thank you
    President:
  • 623 Answers
  1. Go to START>PRINTERS AND FAXES
  2. Right-click on your printer and choose "Printing Preferences".
  3. Choose the Color tab and set it to "Print in grayscale"
  4. You can also set it to use the b&w cartridge only for true black & white prints.
Posted on Jan 17, 2009
I can't correctly print color and black at the same time.
check it property setting for cattradge selection in setting
Jun 06, 2013 | HP PSC 1209 All-in-One InkJet Printer
My HP 1315 still prints black and white just fine; however, it no longer prints in color. I have replaced the color cartridge, removed the celophane from the cartridge, cleaned the printer, and alligned...
Open printer properties.
Start --> Printers and Faxes --> (Right-click your printer and select properties)
Check whether you have selected 'Black & White' option for Color property in 'Printing Preferences' (in General tab) and 'Printing Defaults...' (in Advanced tab).
Set it to Color option.
Best of luck!
Aug 31, 2011 | HP PSC 1315 All-In-One InkJet Printer
Hi,how do I change setting from color to print black and white on HP PSC 1410 ALL IN ONE PRINTER?
Hi there nothing to do in printer. When you print some thing go in print preference and select the B/W print option. Then it will come as B/W print. Thanks & waiting for your feedback.
Mar 17, 2010 | HP PSC 1410 All-In-One InkJet Printer
My Hp 1401 or 1400 all in one printer's software will not work on my new vista computer. I somehow changed the color to print a black and white photo, can't remember how I done it. Now everything prints...
  1. If you need to change settings, click the button that opens the Properties dialog box. Depending on the software application, this button might be called Properties, Options, Printer Setup, Printer, or Preferences.
  2. Select the appropriate options for the print job by using the features available in the Paper/Quality, Finishing, Effects, Basics, and Color tabs. (Color Tab should allow you to change from only Black printing)
  3. Click OK to close the Properties dialog box.
Nov 28, 2009 | HP PSC 1401 All-In-One Printer
Instead of printing to paper, it wants to print (save) to a file
Make sure that you have it set as your default printer. You can do so through the printer section in your Control Panel.
May 12, 2009 | HP PSC 1610 All-In-One InkJet Printer
Set printer to greyscale as the default
hi..that you can set the colour of the print to black
and white both in the printer and the computer.
check it out..
thank u..
rate me..
Apr 08, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP Officejet 7110 won't print black and white w/o color cartridge. I never print in color; yet the machine will not print in just black and white without having a color cartridge with ink in it. Why would...
I've used HP Inkjet/Officejet printers for years. Many HP inkjet printers also use the color cartridges to some extent to create 'black' in slightly different shades, that can be un-noticeable to the eye.
To print using only black ink, try doing as follows:
When you click on 'Print' from your browser, the printer properties (or preferences) page opens.
You must first set the printer to not print in color (color is the default setting). Then you must set the printer to use 'black ink only' by using the 'advanced settings' as follows:
1. In most browsers there will be a box on the lower right of the printer properties page that says 'advanced'.
2. Click on that box to get the advanced settings page to open.
3. Once open, the feature you need to check is called 'print in grayscale'. (It is usually at the top of the list) It is set to 'off' by default. Just click on it and a menu box drops down and one of the choices is 'Black Ink Only'.
4. Click on that and then 'save' or 'apply' those settings.
Then your printer should be using black ink only.
You will probably have to set that each time you want to start a new printing job, as the default settings on these printers are tilted toward using the color cartridges in order to sell you more colored ink.
Also, if you are using Windows 10 and the 'Edge Browser' that comes with it, you cannot get to the 'grayscale' option. So either use a 3rd party browser, or use good old Internet Explorer, (which is still included in Windows 10) to open and get to the page you are trying to print.
I hope this helps. If not, go to HP.com and type in the model number of your printer and then do a search from there for detailed instructions for your printer model (which might be slightly different than what I have shared here.
Apr 28, 2017 | HP OfficeJet 7110 All-In-One Thermal...
Can't print in color
Hi there!
Problem with your print settings.
Go to Control Panel > Printers and FAxes > Right Click on your printer and click Printing Preferences
Depending on your model, the preference page would show a drop down control or simply an option that says something like :
Print in : Black & White /Grayscale
or most models would say:
COLOR: [ ]BLACK [ x] COLOR
Now, set it to colored.
Hope this gives you an idea!
-levibit-
Mar 18, 2009 | HP PSC 1610 All-In-One InkJet Printer
I can't print in color
There are several possibilities here:
1) The default printer settings in your OS (operating system) were set to black only. If you are in windows, go to the windows control panel and choose the printers icon. Find your printer and modify the settings to allow color.
2) The application is overriding the default print settings. Look for something under the application's menu system like "File...Print Setup", or "File...Printer Settings" and change the print mode there to color.
3) The application's page setup is set to black or greyscale only. Look in the application's menu system for something like "File...Page Setup" or "Format...Page" and make sure it's not set to black only.
You will probably get better answers to your question by providing more info like what OS, or version of Windows you are using and what program you are trying to print from.
Dec 19, 2008 | HP LaserJet 2840 Printer
HP PSC 1600 InkJet Printer Logo
190 people viewed this question
Seeker5211
Seeker5211
