Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hoover Windtunnel spits dirt back out the back
I have checked every filter and the belt. My Hoover Windtunnel U5767 will not pick up from the bottom, although the hose cleaner has a great suction. I am at my wits end with this thing!
Any help is appreciated.
  • 1 more comment
  • mjfallert Jan 17, 2009
    Thanks. I changed the belt which was somewhat stretched but found the problem in the very bottom of the unit where the hose goes into the unit. There was a very large amount of "stuff" clogging is up. Thanks.
  • Anonymous Mar 14, 2014
    where is the dirt sensor on a Hoover Windtunnel anniversary edition vacuum
  • Anonymous Mar 24, 2014
    The attachment hose works fine but the floor vac picks up and blows dirt and dust out the back.
  • 294 Answers
Your problem sounds to be an obstruction in the foot (lower body) of the windrummel. Most all windtunnel's have a second cavity for suction to go over the top of the roller. When you remove the bottom plate, next remobe the belt and roller, under the roller will be a removable cavity, take it out. remove the dirt and clean out any debris. also check the suction path connecting hose. if your belt has not been changed in the last 12 months, I would recommend changing that as well.
Posted on Jan 17, 2009
My Hoover windtunnel has very little suction. I have cleaned the entire vacuum. Cleaned filters. My Hepa filter is a little torn, don't know if that could be issue. After cleaning it does suck a tad bit...
Is the belt still intact?
Does it has a wand tool, normally they are connected at the bottom of the machine,if it gets plugged up with gunk, that will greatly reduce your suction.
Aug 31, 2013 | Hoover WindTunnel Purely Pet Vacuum...
I have the bagless hoover windtunnel and it doesn't pick up anything and it is very hard to push. Changed the belt and The rollers are spinning and the filter has been changed. What else can I do?
It sounds like there are dirt and hair wound around the wheel axels cousing them not to spin freely. You have to remove all hair and carpet fiber. Then drop a drop of lubricant oil on the axel.
Change the filter.
You should even Check the floor nozzle for clogged dirt.
BR
Bruce
Aug 27, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover self-propelled windtunnel U6430-900 flat belt gets hot & becomes hard to push. It has a filter bag. Purchased 8/2/01. Took one plate off bottom. Used a compressor to blow out dirt & dust. ...
Belts get hot when fibers from carpet get wound arounf the belts mounting shaft. Best to take a razor and cut off any fibers so the belt doesn't get hot again
Aug 10, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Bag was not on good, resulted in dust,dirt, dog hair everywhere...have cleaned pretty thoroughly but vacuum does not have any suction. After taking apart did find that the larger wide belt is broke but I...
Greetings from GoVacuum,
There are two things that you should check on this vacuum after running it without a bag inside. The first thing you should check is the filter that is underneath of the vacuum bag. This filter is underneath of a bracket, and the bracket can be removed by pulling straight up on the bracket. The bracket and filter are directly below the vacuum bag inside the vacuum bag housing. If the machine was run without a bag (or the bag fell off) then this filter is most likely going to be extremely clogged. You can simly remove the filter, and run it under hot water until clean. Make sure the filter is 100% completely dry before putting it back in the vacuum and using it. Running the vacuum with a wet filter will destroy your motor.
Now in terms of the belts. Where as the belts don't directly control the suction of the vacuum cleaner, they certainly facilitate the pick up of dirt and debris on the floor. Many people assume that since the vacuum is not picking up from the floor, then the vacuum doesn't have suction. You can test this by pulling out the attachment hose and feeling for suction, is there suction at the end of the hose? If yes, then the reason the vacuum is not picking up on the floor is because of the belts. If you don't have suction at the end of the hose, then you have a clog, some where or a dirty filter.
The belts actually are what spin the brush, and the brush basically sweeps the carpet, and throws the dirt and debris into the suction port, and when the dirt and debris are near the suction port, the suction then takes over and takes it to the bag.
There are two belts on this model, it's best to replace both of these belts at the same time. If you replace just one, then the other belt will wear out quicker. It's always best to replace these two belts in conjunction.
The two belts that are used on this vacuum are:
Hoover Windtunnel V-Belt Part 38528034
Hoover Windtunnel Flat Belt, Hoover Part 38528035
Once you have the belts, and you're ready to replace them, here's a great video that we shot here at Govacuum.com that shows you exactly how to replace these belts, as well as some basic maintenance on your roller brush;
I really hope that my repair solution was helpful to you in fixing your vacuum cleaner. If you have any further questions about this repair, or any repair, feel free to contact me at chris.jones@govacuum.com, or request a clarification here on Fixya.
If you did find this repair solution helpful, please kindly rate this repair helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of this solution.
Thank you very much,
Chris Jones
GoVacuum.com
Mar 19, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
The windtunnel vacuum has suction but does not pick up the dirt. I'm puzzled as to what might be the problem. Help!
The problem is that the belts are stretched and worn and slip instead of turn the brush when it is put against the resistance of the carpet. You simply need to replace the belts. Here are the (2) belts you need and the manual with instructions:
Hoover self-propelled windtunnel belts
Manual
Jan 02, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum is spitting dirt and debris out the back--what can I do?
the first thing you should do is clean out the container then check the filter if it looks dirty with a lot of dust it probably needs replacing.
check the hoes for dirt that might stick up.if the problem continues it needs a service.
Jul 30, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
My self-propelled windtunnel bagless hoover does not pick up.
Remove the dirt cup.
Remove the filter screwed in at the top of the dirt cup opening.
Remove the hepa filters on the side of the machine.
Clean all filters and re-install them.
Feb 21, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
DOESN'T PICK UP THE DIRT
try changing the belt and washing the filter. check for clogs and if you belts have been on there for more than 6 months then i would change it. hope this helps
Sep 22, 2008 | Hoover U5780-900 Windtunnel Cyclonic...
Self-propelled windtunnel bagless
Either the inlet down by the brush roll is clogged, or the hose is clogged. Check that out and if you still have a problem, then take it to a warranty repair shop, you have a 1 year warranty on this. Take your sales slip as proof of purchase.
Feb 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
826 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
