Question about General Electric WHDRE526EWW Top Load Washer
How do i get to the belt on a ge top loading washer
  • 700 Answers
Pop off the controll panel by removeing the screws on the bottoem of the controls. After that there are two clips that hold the outer skin to the washer. pop off and there you are. their are several connectors that have to be disconnected and be sure to shut off the power first.
Posted on Jan 17, 2009
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
Ge washer will only spin with no load
Your washer has a 2 speed clutchless motor. If it spins with no load I would first look at the belt. You can remove the front of your washer by inserting a putty knife about 4" on the right and left top of the front panel and push in. This should release the front panel so you can see what is going on. If the belt is worn replace.
Apr 17, 2013 | GE WBSR3140DW Top Load Washer
GE WASHER BELT TOP \DSR LOAD WHDSR316G1WW
put the belt on the motor pulley then start with the other end on the drum pulley and turn it with your hand , i hope this makes sense . the object is to let the pulley do the work of stretching the belt into position
Feb 24, 2013 | GE Washing Machines
Machine wont spin out items are full of water
Take the belt off and run the washer to see if the motor will turn without a load.
Newer style GE - long history of transmission/brake issues with these. Best course of action is explained at this link:
http://www.big-boys.com/articles/gernadewash.html
Mar 31, 2010 | GE WBSR3140DW Top Load Washer
Ge washer top load wlse4000goww not washing/spinning only pumps
Your type of washer usually has a belt theat runs the agitator and spins the tub. The pump is hooked by a direct coupling. If you are still pumping that tells me the motor works but the belt is probably broken or worn so badly that it no longer drives.
Have the belt replaced or do a search for "appliance parts" and then enter your model number. You will get a parts menu to order a new belt from for your unit.
Belt replacement for some of these units can be a major chore... then again some are relatively easy, but consider yourself warned if it is a real project....
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 05, 2009 | GE WDSR2080D Top Load Washer
Front loading GE washer making noise when the drum turns. sounds like a belt but I don't have the manual and don't know how to get the top off.
there should be two screwws in the door jam on the front panel, they hold the top down
once you remove those slide the top backwards then lift up
let me know if its the belt
Oct 19, 2009 | GE WSXH208A Front Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
Jun 08, 2009 | GE WBSR3140DW Top Load Washer
GE washer model #wle4000b1ww won't spin
This is joyce
You have a bad belt it wont pull the load.
thanks,
joyce
Feb 04, 2009 | GE WPRB9220D Top Load Washer
GE top load washer will drain but not spin
you both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
Apr 01, 2008 | GE WBB4500EWW Top Load Washer
General Electric WHDRE526EWW Top Load Washer Logo
85 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
