Hisense TL2020 LCD TV used as PC Monitor - Need drivers
I have a Hisense TL2020 LCD TV that I use as my PC Monitor through VGA connection and just not clear enough to be able to read the text.
Do I need drivers and where can I find them or could it just be a setting /.
  • FUCKHISENSE Mar 07, 2009
    I cannot display at 1280 x 800, even though the TV is 1410 x 900 res, I assumed it was a driver thing with my PC cause it calls the Hisense a default monitor with no drivers loaded, so I wanted to find drivers for it and the only drivers on the Hisense site are USB drivers. Hisense = Epic Fail for computing, but OK for HD TV
4 Suggested Answers
is it in demo mode
Posted on Dec 29, 2007
SOURCE: My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON 2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
Posted on Jul 11, 2008
SOURCE: Hisense TL2020 LCD TV
Try turning the main power switch on the back of the tv off.
Then hold the menu button and push that switch back on while still holding the menu button.
Keep holding the menu button until the setup menu pops up.
Next, be sure your input is set correctly(air or cable).
Next, do an auto channel search.
That did it for me. After I shut it off I had to do it one more time but it did the job. A friend of mine gave me the tv for free because nobody he new could figure it out. I took it home, got lucky, and figured it out in about ten minutes.
Posted on Sep 03, 2008
Hisense tl2020 sound doesn't come on
What we call a thermal problem----if a 17 inch likely not cost effective to repair and company who made it in China does not really sell parts.
Mar 18, 2012 | Hisense TL1700 17 in. LCD Television
My pc wont recognise my tv as a second monitor - conected with VGA cable
the video card you used have a capability for dual 1st thing that you need to do is to make sure that the computer recognized the 2nd monitor and activate dual monitor capability on the nvidia panel..after that on your tv select the proper source(like VGA, HDMI1 etc.) on which you'll be able to see the the video from the computer to your TV..
Jan 31, 2012 | Dell Computers & Internet
What kind of cord do i need to watch a movie on my tv from my laptop
You'll need a VGA cable ,the one you normaly use for a desktop computer from your tower to your monitor,surely your LCD supports that,Though you'll have to get your sound from your laptop still since this connection only transmit picture.Good luck...
Sep 01, 2011 | Hisense TL2620 26 in. LCD Television
Are there any drivers I can download to help get my hisense model TL2020 tv to be use as a monitor. If so where can I find them , thank you ,,,, JPetrocine of Florida
If it has a VGA connection, hook it to your computer using a VGA cable. If it doesn't have the VGA connection, it can be connected via a S-Video or a Composite or component cable if your PC supports that sort of connection.
Anyway, no driver needed.
Nov 03, 2009 | Televison & Video
Hisense tl2020 will not power on
power supply issue..may be some bad capacitors simply replace them....dada....your prob solved
happy to help
Aug 18, 2017 | Hisense TL1700 17 in. LCD Television
Hisense Remote Control won't work
In trying to program a universal remote for my Hi-Sense TV, the TV locked. How can I unlock it?
Oct 23, 2008 | Hisense TL1700 17 in. LCD Television
Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
Sep 16, 2008 | Hisense LCD1504 15 in. Television
Hisense TL2020 TV repairing
To unlock your Tl2020 with a universal remote just go into the menu and select V chip setting. The password from the factory is four zeros (0 0 0 0 ). Once you get in you will the letter "B" nect to everything. Set everything to the letter "U". Then, turn off the television. The set should be unlocked now. Good luck !
Sep 15, 2007 | Hisense TL1700 17 in. LCD Television
Televison & Video Logo
3,246 people viewed this question
Top Televison & Video Experts
