Question about Dell W1700 17 in. HD-Ready LCD Television
Turning on tv
When turning on, or trying to turn on the tv screen, I must turn the monitor on and off over and over again in order to change the channels. Most of the time I am spending five minutes or more turning the monitor on and off just to get the thing to change channels. Please help. By the way, I already had to buy and install the component to get the picture to work. shawn
  • shawn anderson Jun 25, 2007
    Even when I try to turn on the tv without the remote, I still have the problem. What is a tactile switch and where is it located?
    thanks,
    shawn
    New Friend:
  • 129 Answers
It sounds like a tactile switch stuck causing the problem . it is the remote control working?
Posted on Jun 20, 2007
  • Luis Amado Jun 27, 2007
    One of the function buttons could'be stuck..
    what exactly is the component. that you already install? in order to help you better I need more information. have a good day
SOURCE:
Why does the screen shut down after 1 sec while sound continues
It sounds like bad luck to me. You cannot change any settings on a TV by connecting a computer to it. In theory you can damage any monitor by setting the screen resolution of the computer higher than the monitors maximum res. The Sharp 26" has a resolution of 1366 x 768 (1080i) so (again in theory and I have never seen it happen) if you set the output to 1920 x 1024 (HD - 1080p) it can kill the screen. Perhaps this is what has happened. You will need to take it to a Sharp service centre.
May 29, 2014 | Sharp LC-26SD1E 26 in. LCD Television
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
After 2 seconds my monitor HP w1907v is switching off itself and there's no way to bring it back to life again. If i switch off and on again the monitor shows images for 2 seconds and then dies. I...
Well the monitor obviously works, so I see no reason to open the case on the monitor especially because there are no user serviceable parts within the case. my sugestion is to try the monitor on another PC if that yeilds the same results then I am wrong and the problem lies with the monitor. I believe the are two types of connections for this monitor shane_barnha_2.jpg VGA and DVI shane_barnha_0.png
Next step is to try the one that you have not tried yet if that fixes it then the problem lies in the output conection on the back of PC the input connection on bottom of monitor or the cable itself. If there isn't a second connection like I think then the next option would be to try another monitor, which if you do not have available can be achieved by using most new flat screen TV's If you have a TV With the same conection Just move the PC or TV close enough to try, Use your remote to change TV input to PC then turn TV off connect cable turn TV on and start up your PC if this works you will need to have your monitor repaired or replaced.
Thumbs Up if helpful, Feedback is Appreciated!!!
Good Luck!!!
Jun 18, 2011 | HP w1907 LCD Monitor
Monitor black with green light on
did you changed frequency of that monitor? if it is out of factory setting that could be the problem, try to connect it again as secondary and set Hz to default, if that does n't work try same settings on both monitors? i have connected two monitors i had same problems , my secondary monitor was clone for tv if you are using secondary monitor for clone to ty (with s-video or whateever) if tv is old it must be 60HZ 800x600...
Apr 27, 2009 | Computers & Internet
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Invalid format message when trying to use the RGB(PC) port
Honestly, that sounds like one of two things happened. Either the resolution of your computer video card changed or (I'm not sure with your specific TV) the TV's resolution changed.
If through the TV menus you can adjust PC resolution, I would try changing the resolutions. In the LG 47LB5DF TV, press Menu, then go to Picture, then go down to Screen. On the screen menu, you will see Resolution, Position, Size, Phase, and Reset. First try adjusting the Resolution to some of the options you see. If that doesn't work, try to reset the screen settings.
If adjusting those settings on your TV does not help, then you will have to change the resolution through the computer. Try connecting a monitor to the computer. If you get a picture through the monitor, on the desktop right click and select Properties. If using XP go to the setting tab, if using Vista/7, select Display Settings. Lower the resolution to something you think the TV will be able to handle, then connect the PC to the TV again. If you are using an HDMI connection to the TV, you may have to turn off the computer, connect the cable, then turn the computer back on with the TV on the correct input.
If the monitor doesn't show the picture or if you don't have another monitor, you can try adjusting the picture in safe mode, by pressing F8 after you press the power button, before you see the Windows loading screen. Press if multiple times if necessary. You should see a screen that gives you a few startup options. Select Safe Mode. After Windows boots up, you should still see the screen as the resolution would have been reduced. From there try changing your display settings.
Hopefully that info has helped. I noticed that you asked this question 2yrs ago, so I hope you have already figured out how to fix your problem. I simply wished to post this in case it would help you or anyone else had a similar problem. Good luck and take care.
Dec 15, 2008 | Philips Magnavox 42MF521D/37 Television
Helpme please
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 25, 2008 | Philips 150S4FB 15" LCD Monitor
Westinghouse ltv-19w6 source won't change
Have you tried to click the source button on the tv? It is the second button from the bottom on the right hand side of the screen.
I doubt your tv/monitor is turning off, it just isn't getting any input. D-Sub is the "pc monitor part".
Try clicking that button, give it sec, the hit it again. It will go through all of it inputs. If TV is what you are trying to find, it is directly after the Video input (green letters, top right hand side of the screen.) Keep hitting the button until TV shows up.
Good Luck!
Oct 23, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Dell W1700 17 in. HD-Ready LCD Television Logo
49 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
