Question about Sanyo Microwave Microwave Oven
Turntable doesn't spin
Our Sanyo mircowave with the model number EM-D975 won't allow the turntable to work I'm just wondering how I could fix it without sending it to the factory.
    Problem Solver:
  • 16 Answers
Well the table might not be on the revolving piece- that is what happened to my microwave oven, or the revolving piece might have to be connected to a belt inside that turns it
Posted on Jan 17, 2009
How do i fix a sanyo microwave
call ser. tch. ur motor might be spoiled already . its a added function mabe of the unit if ur turntable motor not wroking so does ur microwave
Feb 21, 2015 | Sanyo Microwave Ovens
Turntable won't revolve
Inspect the turntable base wheels and guides. If they are gummed up with food or other gunk, they will not turn and the turntable will not rotate. Clean as needed.
Remove the microwave case by unscrewing the casing screws with your screwdriver. Locate the turntable motor which will be directly beneath the oven floor.
Inspect the belt that connects the motor to the rotating table. If the belt is broken, replace it.
Touch the probes of a continuity tester to the electrical contacts on the motor. If the tester lights up, the motor windings are good, which means the motor is functional. If there is no light, the motor needs to be replaced.
Check the wires leading from the cord to the motor itself. Look for any breaks in the wire, or a wire that has been pulled off of any electrical connection. Any connection that has been compromised can be soldered back into place, but if the cord is damaged at all, it needs to be replaced.
Attempt to spin the motor by hand if the continuity is good and the belt is in place. It should spin freely, but if it is difficult or doesn't move at all, you will need to lubricate the bearing. Either apply spray or bearing lube to the motor axles to solve this problem, and allow the motor to spin freely once again.
Oct 04, 2011 | Microwave Ovens
Em-s3577s uk 2 wont turn
Remove the turntable plate and check the motor coupling gears underneath, if motor coupling is fine, then replace the turntable motor.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 19, 2009 | Sanyo Microwave Ovens
Turntable mechanism is not working
you will have to take it off the wall. There should be three screws in the cabinet above the unit . 1. unplug unit 2 place a large towel under unit to protect stove or cabinet 3 have someone support unit while u remove threee phillips screws 4 the back will hang on the wall rotate down lift and remove. the turn table is usually ran by a rubber belt and motor. Hope this was helpful please rate me
Jan 12, 2009 | Sanyo EM-S8000 Microwave Oven
Turntable on my sanyo EM-C6786V MICROWAVE OVEN do not turn wilst cooking
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find Sanyo UK support, parts and authorized servicers here.
Nov 04, 2008 | Sanyo Microwave Ovens
Microwave turntable does not turn
I have the exact microwave you do (ems8000w), the motor failed and I found this one worked perfectly as a replacement.
The original is impossible to find.
https://microwaveglasstrays.com
1 x 120v Microwave Turntable Motor 6RPM 4W # F63265G60AP (F63265G60AP) = $14.99
Good luck.
May 02, 2008 | Microwave Ovens
SANYO EM-D9550. Turntable turns when off but not when cooking.
That's sounds pretty strange!
Since I don't have any service data on Sanyos, I'd have to speculate.
I would guess that one scenario that could cause it would be if the turntable were turned off via the control panel, but there was a switch or switch mount problem.
I would refer you to their support people:
http://sanyoservice.com/
Dec 08, 2007 | Sanyo EM-D1100 1100 Watts Microwave Oven
Sanyo Microwave Microwave Oven Logo
352 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
