Children inserted two dvds into the dvd player of our sansui 26 in lcd +dvd. how can they be removed?
  • 716 Answers
Youll Have To Unplug The Unit Then Remove The Outer Casing Of The Dvd Player And Then You Should Be Able To Get Them Out.
Sorry
Posted on Jan 17, 2009
Converting vcr tape onto dvds.
DVD-R recording must be finalized before it can be used on other DVD players.
Feb 11, 2012 | Sansui VRDVD4005 DVD Player/VCR
I have had Sansui vrdvd4005 for many years. now i put in a dvd that i have been able to play in the past but it says 'reading' and never runs the dvd. help. i bought a cleaning dvd but that did not...
Cleaning DVDs that look like a DVD with a small brush on them will rarely work. After unplugging unit try opening unit and using a Qtip and rubbing alcohol try VERY GENTLY cleaning the optic on the player. If this does not work player will need to be replaced.
Mar 01, 2011 | Sansui VRDVD4005 DVD Player/VCR
Sansui lcdvd200 some of my dvds work on this
Open your unit and clean the lens of your dvd using cotton bud. If that did no work, try to adjust the trimmer located at the pcb of the lens.. There are 2 trimmers whose function is to focus the alignment of the lens. Adjust the right trimmer minimal only using a mini plastic screw clockwise or counterclockwise direction. Be very careful when adjusting the trimmer. Too much adjustment may cause your dvd to not recognize all the discs that you will insert.
May 04, 2010 | Sansui LCDVD200 20 in. TV/DVD Combo
New Sansui cuts off tops of heads
Check the remote for a button labeled "aspect" or "zoom" or "format".
Feb 09, 2009 | Sansui HDLCD-2600 26 in. LCD Television
Won't play DVDs or CDs at all. Reads error code C-104.
Sansui VRDVD4005 will record DVDs provided they are DVD-R NOT DVD+R. I have one of these for 3 going on 4 years and I took it apart and cleaned the dust off the magnetic hub and that worked for awhile but (2-3 months) now I'm having trouble finalizing again. Someone on this site said it needs 8x NOT 16x disks ... 'cause it's an older unit ... I'm checking it out in the users manuel.
magicbbs
Oct 19, 2008 | Sansui VRDVD4005 DVD Player/VCR
DVD player won't play
Make sure you have inserted the correctly; the label faces away from the TV/DVD player.
Oct 18, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
NO SOUND FROM DVD
Try different sound settings in the dvd menu.
Oct 15, 2008 | Sansui HDLCD-2600 26 in. LCD Television
SANSUI HDLCD2600 TV W/DIGITAL TUNER
This is likely your DVD player, not the tv.
First go into the setup menu of your DVD player and make sure "subtitles" are turned off.
Next, put a DVD into the player and when it gets to the menu, go into the audio setup.
If subtitles are turned on, turn them off. If subtitles are turned off, turn them on and exit the menu, then go back into the menu and turn them off again. I've seen this reset this same problem on some DVD players.
May 06, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Sansui video/dvd player recorder
What is model number of unit? Are you sure it records dvds?
Feb 22, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
