Question about Whirlpool LSR6334LQ Top Load Washer
How do you get to the pump?
    New Friend:
  • 129 Answers
Order at partstore.com go by brand and model
Posted on Jun 20, 2007
  • Luis Amado Jun 21, 2007
    remove the two screws at the bottom of the console panel, remove the 3 wire connector .atached to the cabinet block terminal, with a flat screwdriver remove the two gold color clips at both sides, lift the metal cabinet from the clip's side you'll find the pump at the front bottom ,atached with two black clips to the transmision block
Timer not working
Sounds like a bad timer motor. The entire timer will need replacing.
Jun 25, 2014 | Whirlpool LSR6334LQ Top Load Washer
The washer quit spinning, I can get it to work in wash mode but when it comes time to spin out it won't do anything,
themobilian_2472.jpgIf it won't puthemobilian_2473.jpgmp out the water or spin that is the lid switch. If it pumps out the water but does not spin then that is the motor coupling. How to get into the machine.
How it works: 4 videos and a service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 21, 2011 | Whirlpool LSR6334LQ Top Load Washer
All the water does not spin out of the clothes & at times it doesn't even seem like it is spinning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 07, 2011 | Whirlpool LSR6334LQ Top Load Washer
How do u take the back off the washing machine
You don't take the back off. You flip the control panel up and pop the s-clips then the cabinet comes off. themobilian_829.jpgthemobilian_830.jpgthemobilian_16.gifthemobilian_831.jpgthemobilian_832.jpgthemobilian_833.jpg
4 more videos and a service manual are HERE
Thanks for using FixYa
Jan 10, 2011 | Whirlpool LSR6334LQ Top Load Washer
How to open a whirlpool lsr6334lq0 model to replace the connector switch?
remove the moldings on the upper left and upper right corners theres a philips screw under there that you take out and the complete cover tips off towards you.
Jan 09, 2011 | Whirlpool LSR6334LQ Top Load Washer
Doesn't agitate
Check this out
May 21, 2010 | Whirlpool LSR6334LQ Top Load Washer
Washer Doesn't move from cycle to cycle
this washer has a problem with the lid hinge screws coming loose. check the left hand hinge and you will find the screws loose.
this cause the lid switch to not engage and then nothing will happen until it thinks the lid is closed.
try to tighten the screws and listen to see if the switch "clicks" when you open and close the lid.
that should fix it until the screws come loose again.
Jan 30, 2009 | Whirlpool LSR6334LQ Top Load Washer
Whirlpool washer type 111
we have a whirlpool LSN1000AQ0 and machine wont spin on its own without turning it by hand to get it started.
Sep 15, 2008 | Whirlpool LSR6334LQ Top Load Washer
Washer only fills
it sounds as if its your lid switch. on some top load whirlpool washer it will fill even if the lid is open. if you open the control panel and open the jones plug you can check for continuity on the lid switch
Jul 22, 2007 | Whirlpool LSR6334LQ Top Load Washer
Whirlpool LSR6334LQ Top Load Washer Logo
70 people viewed this question
Sal De
Marvin
Marvin
jimorris77
