Question about Nokia 5500 Sport Cellular Phone
Ring tone wont load
I have put my own ring tones on my phone but every time i save it the phone turns itself off and back on again but the ring tone isnt set?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 42 Answers
There might be something wrong with that file.
Posted on May 23, 2009
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
Tip
BlackBerry Tour: How to make it ring and vibrate for incoming calls
You can customize your BlackBerry Tour so that either it rings when you get a phone call, or it vibrates -- or both. To make your phone both ring and vibrate when you get a call, go to your BlackBerry's sounds and ring tone options, which you can get to by either of the following two ways:
#1 - Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
#2 - On the main screen, press the BlackBerry button (the one with the seven dots) to take you to your Home folder. Scroll down to the Options folder (it's usually toward the bottom, and it has a wrench icon) and click on it, then select Sounds and Ring Tones.
From this scren you can select the ring tone that you want and adjust the ring tone volume. Then scroll down to Vibration and set it for On.
There is also an option for Vibrate with Ring Tone. If you turn this option on, the phone will both ring and vibrate at the same time when you get a call. If you turn it off, the phone will vibrate first, then ring. Either way, you'll get the ring and the vibration -- it's just a matter of whether they happen together or not. To see the difference between the two options, use the "Try it" option at the bottom of the screen.
When you've made the selections that you want, exit out of the options screen, but be sure to choose Save rather than Discard to save your changes.
on Jul 10, 2010 | RIM BlackBerry? Tour 9630 Smartphone
My phone will not ring out loud and vibrate at the same time.
To turn on a ringtone and vibration, go to your BlackBerry's sounds and ring tone options by either of the following ways:
1. Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
2. In the Home folder, go to your Options folder (usually toward the bottom, has a wrench icon) and select Sounds and Ring Tones.
Select the ring tone and volume that you want, and for Play Sound select Always. Scroll down to Vibration and set it for On.
There is an option for Vibrate with Ring Tone -- set that to on in order to make your phone both ring and vibrate at the same time, then save the settings when you cancel out, and you're all set.
Jun 21, 2010 | RIM BlackBerry? Tour 9630 Smartphone
I had purchase a new nokia 1650 wont ring or vibrate
just fomat your phone first then try to change your tone settings
Mar 11, 2010 | Nokia 1650 Cell Phone
How do I down load ring tones off my computer I
The easiest way is to get a microSD memory card and a USB card reader. Put the memory card in the reader and plug that into the PC. Copy your ring tones onto the card, then put the card into the RAZR.
Alternately, you can get USB drivers here, then when you connect your phone to your PC (with a cheap $5 micro-USB cable) you can put your ring tones on to the phone directly.
Jan 11, 2010 | Motorola Mobility RAZR V3
I just got a verizon b.b. 8703e and I can't figure out how to turn on the ring tone
A ring tone can be set for specific contacts on a BlackBerry smartphone that has 32MB or more of flash memory.
To set a ring tone, follow the steps below:
1) Click the Address Book icon on the Home screen
2) Select the contact that a custom ring tone is being added for.
3) Press the Menu key and click Edit.
4) Press the Menu key again and click Add Custom Phone Tune.
5) Select the ring tone from the list of available ring tones.
6) Press the Menu key and click Save.
Nov 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
Audio folder but it wont let me sat them as ring tones
cuz they r too big for a ringtone. if its bigger than a certain size it wont let u set it as a ringtone
Aug 28, 2009 | Pantech Matrix Cell Phone
Motorola Razr V3 wont delete
Have you updated the firmware lately? Some of the newer versions wont let you delete your ringers once they are stored. Do you know how to use bitpim? If not shoot me an email and i can walk you through it. It is really easily to use. Good Luck!
Jan 03, 2008 | Motorola Mobility RAZR V3
Ring File corrupted
use a different ringtone or try to put the ring tone in a different folder and if that donsent work then do a hard reset
Nov 22, 2007 | T-Mobile MDA
Nokia 5500 Sport Cellular Phone Logo
65 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
