Question about Asko Washing Machines
Motor not running in Asko 10504 washing machine
Checked belt - ok. Checked brushes - making good contact, plenty left. Checked main connector to motor and brush connectors - all ok.
Runs through cycle normally apart from no motor movement - fills and empties ok.
  • kbke66 Jan 17, 2009
    Thanks for your reply. I have already fixed it, but you were right. It turned out to be a bad solder joint on the main control board - at the connector leading to the motor. I re-soldered the joint and it worked ok.
  • 68 Answers
The motor might have burned out. Another possibility would be a partially fried control board.
Posted on Jan 17, 2009
Lavamat 74620 pumps out and does nothing no error codes? Door locks drain pump does nothing and no water fils motor does not spin. Is it the main control board? Brushes look ok on motor fan belt ok
Have you checked for anthing that has gone into the drain filter, there should be access to the filter via a small access way at the front of the machine either left or rihgt side at the bottom. Your instructon manual would give directions on how to access the filter location to check the filter is clean and should be checked regularly to keep your machine running correctly.
Dec 13, 2016 | Washing Machines
Tip
Washing machine motor issues with brushes and carbon dust read this if your...
due to carbon dust build up around the drum motor in most washers that have non linear motor that have carbon brushes
you can get a state of error i call a ghost error
as its just due to the build up of carbon powder around the motor its connector and stator coils {speed pickup}
as the brushes deplete you end up with a pile of it building up between the brush contact and the motor housing leading to electricity leaking to earth of the motor metals
so a stiff dry new paint brush and give the motor a good brush around to remove the conduction path the dust creates
this effects the low voltage sensors in the motor like its speed control etc
leading to the mcu controller board miss diag the motor as bad and you get a E or F motor error
also this can and will trip your homes MCB detector and ECLD mains power switch
as i say its a ghost error and easily solved
any engineer worth his salt when fitting new brushes or even looking at this fault
will do this first to try to clear the fault if the brushes are aok
before he condems the controller board ... as bad
a new set of brushes should be part of a service you should carry out
much like an mot when its outside its warrenty period
and brushing out the old dust
should be done anyway when new brushes are fitted when needed
or there condition checked as still ok
basically brushes should be about at least 3/4 " long for a life left of about a year
and have enough preasure on the armature to ensure good current flow too it via the stator
if you have motor F or E fault conditions or a machine that trips your mains on spin etc
this prob needs done anyway
a set of brushes it cheep and a brush is also cheep
so give it a good brush out
then reset the machine
you power off at the mains
you hold in a button or two
you power on at the mains
ive read some machine need the program switch to be placed and then dialed like a safe to reset the main board from some types of motor fault
caused by carbon dust build up typical candy auto washers.. and others
they make it hard to make people money
on Dec 04, 2014 | Washing Machines
My Kenmore he5t washer does not spin the clothes dry I always have to ring them out and try to get the water that's left in the machine out what wrong???
Almost every machine I've seen that doesn't washes but doesn't spin had the same problem, the drive belt is greasy making the belt slip, it takes five minutes to fix no parts needed. Take the back off. Spray the belt with any soapy cleaner, take a stiff brush and hold it onto the side of the belt that is in contact with the motor. Turn the belt, while holding the brush against it. Should turn easily if you pull it either direction in line with the way it normally moves. It will run over a large pulley wheel, scrub the edge of the wheel which contacts the belt, there should be plenty of space, the belt only goes over the top and sides. Put the back on leave it to dry for 15-20 minutes, it should spin fine.
Nov 08, 2016 | Kenmore Washing Machines
My Asko 10504 has started making what sounds like a metal on metal grinding sound when it spins. It's as if the whole drum assembly is moving more than it should and coming into contact with something,...
COULD BE THE TRANSMISSION SPRING OR TRANSMISSION BEARINGS. EVEN UR TUB BEARINGS IN THE TUB, A BAD MOTOR COUPLER HOWEVER U WOULD NOT GET ANY SPIN OR AGITATION IF THE COUPLER WAS BAD. BAD BREAKING SYSTEM WOULD NORMALLY MAKE NOISE BUT WHAT U WOULD GET THEN IS A COMBINED SPIN AND AGITATION DURING SPIN CYCLE,
Mar 23, 2015 | Asko Washing Machines
I compair it to a gas motor with a miss.
Could be a few different things. Have you checked the motor brushes? Check they have plenty carbon left on them and that the spring is in good condition. Make sure they slide through the Brush Housing smoothly. Sometimes a sticking brush or bad contact can cause intermittent power loss.
Jul 22, 2014 | Pride Revo 3 Wheel Scooter
My wasmachine (asko 10625) doesn't spin at all Not
either motor winding is failed or motor brushes or no power to motor. needs to be tested with a multimeter
Jan 31, 2010 | Asko T711 Electric Dryer
Asko 10505 not agitating or spinning
not a solution, I have had the same problem due to family members overloading the machine, in fact I have it now which is why I am on here. Previously I fixed it by cleaning the deposit left on the rotor caused by the brushes. It worked before but not this time maybe the brushes are now too worn. This is my second set of brushes I replaced a set after about 10 years of use. From memory there is not a huge difference between a completely new motor and a set of brushes so I may go that way now as the machins is around 15 years old
Aug 02, 2009 | Asko W6021 Front Load Washer
Operation manual
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/10504-_E
I think this web site has a PDF of your manual. If not try to googe ASKO 10504 washer manual
good luck
Jan 30, 2009 | Asko W6021 Front Load Washer
Bosch Classixx WVF2402GB motor will not run
Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Dec 09, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
278 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
